Transcoding for Samsung D Series
mrmrmrmr
Post Sat Apr 09, 2016 3:41 pm
I have a Samsung D series TV.
The following media can not be played directly. It says "video codec not supported"
Unique ID                                : 196518972683263188782988929014719064863 (0x93D82D6AF1C15B708619165236602B1F)
Complete name                            : \\192.168.254.3\d$\movies\movie\Film\Kiralik Ask Blm 41 HDTV 1080p x264 AC3 - BTRG.mkv
Format version                           : Version 4 / Version 2
File size                                : 4.90 GiB
Duration                                 : 2h 12mn
Overall bit rate                         : 5 274 Kbps
Movie name                               : Kiralık Aşk Blm 41
Encoded date                             : UTC 2016-04-08 21:10:11
Writing application                      : mkvmerge v9.0.1 ('Obstacles') 64bit
Writing library                          : libebml v1.3.3 + libmatroska v1.4.4
DURATION                                 : 02:12:58.784000000
NUMBER_OF_FRAMES                         : 249337
NUMBER_OF_BYTES                          : 191490816
_STATISTICS_WRITING_APP                  : mkvmerge v9.0.1 ('Obstacles') 64bit
_STATISTICS_WRITING_DATE_UTC             : 2016-04-08 21:10:11
_STATISTICS_TAGS                         : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Format profile                           : Main@L4.0
Duration                                 : 2h 12mn
Bit rate                                 : 4 977 Kbps
Height                                   : 1 080 pixels
Frame rate                               : 25.000 fps
Scan type                                : Interlaced
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.096
Stream size                              : 4.62 GiB (94%)
Title                                    : BTRG HDTV
Language                                 : Turkish
Duration                                 : 2h 12mn
Bit rate                                 : 192 Kbps
Stream size                              : 183 MiB (4%)
Title                                    : BTRG HDTV
Language                                 : Turkish
So I want to transcode this media for my TV.
I edited profiles.xml under C:\Program Files\Serviio\config
under the correct profile (ID 7 for Samsung series C/D)
I put this under transcoding section
         <Video targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="matroska" vCodec="*" profile="*" />
but it did not transcode.
what am I missing ?
Post Sun Apr 10, 2016 1:07 am
Re: Transcoding for Samsung D Series
Firstly you don't need: vCodec="*" profile="*". If you leave these out it will match against all video codecs and profiles anyway (plus "profiles" is specific to h264 and shouldn't be used for other codecs).
Secondly you must have a target container type (I'm surprised Serviio started? After changing profiles you must restart your PC/Serviio Service).
So your code should probably look more like:
         <Video targetContainer="mpegts"  targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="matroska"  />
This however will now transcode all MKV files, even when it's probably not needed. My reading is that this file should be playable on your device - if it's only one file that's not I'd re-encode that file rather than transcoding all mkv's.
mrmrmrmr
Post Sun Apr 10, 2016 2:21 pm
thanks for the explanation.
so what should I do to re-encode only this format ?
btw, you say that this file should be playable on Samsung D series TV.
how are you sure about it ? my TV says that the video codec is not supported.
Post Wed Apr 13, 2016 9:38 am
If it's only this file, try remuxing it using the command (assuming your a Windows user):
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "oldfilename.mkv" -c copy -map 0 "newfilename.mkv"
and see if the new file plays (it probably won't, but this is a quick thing to try). If not then you will need to grab a tool like "XMedia Recode" and recode your video.
Only based on what I read and see in the profile. The problem is that there are so many settings when the video was encoded. These setting can change everything from the frame rate to the compression and codecs used - if there was a setting that your TV doesn't like it will reject the file (although all other files work even though on the surface they appear to be same).
