Serviio 1.6 - Synology NAS install does not work! - SOLVED!
Mart360
Post Tue Apr 12, 2016 9:03 pm
Sorry guys, there is clearly something wrong with this version.
I made the upgrade from 1.5 to 1.6 and the mandatory Java update too
Nothing works.
According to the Synology package the java has a hotspot & serviio shows as running.
Installed the PC console (mac version) and attempted to set the library
Problem 1) The console does not easily identify network shares ... you need to know the syntax to get to your NAS - OK if your a Linux / windows command line genius, not so for us mortals
Problem 2) When you do eventually find the correct syntax for linking to your drive SMB:/DISKSTATION/Films/ (is this correct? who knows!!) and save it, nothing happens
Problem 3) When you go back to check your library, Is shows a warning triangle and says the drive / location is not available - the location syntax has changed to /smb:/DISKSTATION/Fims/
Rolled back to V 7 java - no difference ... tried to fins a working Serviio V1.5 with no success
Tried installing the synology V6 & V7 Java releases , no change
Following advice from the forum, i tried again on a windows machine ...
V1.6 does not work with XP !
Using a Win 7 machine, i installed the PC package without the server ... big mistake... error the server does not seem to be running and a white box
uninstalled and reinstalled with the server and i get the program to start .... specify my NAS location using the syntax... and it gives the same error drive / location not ready / available
So windows console doesn't work & Mac console dosent work .
Is it the NAS package or the NAS Java?
So where do i go from here??
1.4 & 1.5 worked ... 1.6 clearly dosent.
Can we have an archive we can use to allow us to get somthing up and running .
Mart
Post Wed Apr 13, 2016 8:16 am
Re: Serviio 1.6 - Synology NAS install does not work!
if you install it on NAS, you should just add a path that is local to the NAS (not sure how it's on the Synology, but perhaps something like /share/xxx or wherever the folders are), not a SMB path. Does the Browse.. button not work?
If you install only the console on WIn, obviously it won't find the server - you didn't install it on the machine.
Mart360
Post Wed Apr 13, 2016 4:39 pm
If i recall, under 1.4/5, there was the specific option instruction
About not installing the server , only the console if the the server was installed on a NAS
there was then the edit of the config.mops?? file that would point to the NAS IP
i will get some screen shots of what i get under the synology set up
Mart
Post Wed Apr 13, 2016 6:16 pm
The remote console now works differently: http://serviio.org/component/content/article?id=21#q2
Mart360
Post Wed Apr 13, 2016 6:33 pm
OK .. pictures
Error for folder location this is from the NAS Serviio
This is the folder structure from the NAS Serviio
The volume 1- is the USB HDD attached to my desktop mac not the NAS
It does not see or seem to allow access to the NAS folders ..
using the format 192.168.1.250/Films as the location does not work either
Mart
Mart360
Post Wed Apr 13, 2016 11:18 pm
Re: Serviio 1.6 - Synology NAS install does not work! - SOL
Solved :)
I uninstalled Serviio on both Mac & NAS
Unplugged the external HD from the MAC
Reinstalled Serviio & Java 8 on the NAS, and ran it from there....
Set up the file locations as before which still showed an error
Using the Wiki, it said the file location on the NAS is located in Volume 1/
Sure enough using the browse function Vol 1 was there, and i could see my media folders below that.
I set the file paths to this and saved and refreshed. the original file path's still showed errors, buth the Vol1 path showed as OK
Deleted the errored path and went back into the home page,
Files were showing in the display ...
Sparked up the Xbox and did a server search... serviio / disk station found that's an improvement
All sub-folders found Even Better
All files within the folder played :)
I then reconnected the External HDD to the NAS ,,, no change files on the server seen & still play
I will have a look and see if loading the program on the MAC gives any issues
Only thing i have noticed, is that some of the films now seem a bit pixelated... but i cant say if this is due to the way there are streamed now
Mart
Al
patters
Post Tue Apr 26, 2016 7:27 pm
Mart360 wrote:The volume 1- is the USB HDD attached to my desktop mac not the NAS
This is where you had gone wrong. On a Synology the local internal drive is /volume1. The instructions on the download page for the Serviio 1.6 Synology package mention this. I rewrote them for version 1.6 since quite a lot had changed, so it's always worth re-checking that page if in doubt in future. A USB drive connected to a Synology is usually mounted under /volumeUSB1/usbshare, which appears in DSM as just "usbshare1".
Users browsing this forum: Baidu [Spider] and 15 guests
