Media Player Problem with Library Update/Customization
noemon
Post Thu Apr 14, 2016 2:47 pm
Greetings,
The media files in the media browser stop loading everytime time the library changes and new data are added or removed from it. The tokens are no longer valid. So every time I update the library I re-install serviio and this fixes the problem, but it is a little bit off-putting to having to do that every time. Is there a fix around this, my library is quite massive and it can be accessed here:
http://noemon-movies.ddns.net:23424/med ... r/#/browse
temppass: serviio
Some other questions that I would like to ask:
Can I customize the login page of the mediabrowser? Not the media files in the browser but the login page? And how can I do that?
Post Mon Apr 18, 2016 9:04 pm
Re: Media Player Problem with Library Update/Customization
Adding files should have no effect on the session token. Can you post a detailed log showing this behaviour?
Users browsing this forum: Bing [Bot] and 49 guests
