MediaBrowser with multiuser support
I want to congratz for this nice software. It is really usefull.
I have 2 requests:
- Make the MediaBrowser Multiuser or disable user login.
- Possibility to peronalize the MediaBrowser.
Keep the good work.
Cheers
zachofalltrades wrote:Two points then:
1. Perhaps the API access to the configuration console _should_ be protected.
2. I believe my point about the renderer restrictions being analogous to user restrictions still makes some sense -- the server has some notion of "who can access what". The OP in this thread would like to see separate logins for the MediaBrowser (which would require some enhancement to the CDS API). I think that piggybacking on internal group support that is already there would make good sense.
millahjovich wrote:The problem here is that you if a person wants to share their library, they basically have to give out THE password that will also grant access to the configuration console (even though the user has to come in through a separate interface). The server already has some rudimentary access-level support in it where we can specify that certain DLNA renderers are limited or no-restriction. The server must already keep track of the multiple specific renderers -- so what we need is to extend or abstract out that logic to a web login so that the server keeps track of multiple web "users".
