Scraping / File Stacking failures
KIWIJUNGLIST
Post Wed Apr 20, 2016 5:41 am
Thanks for the great software, I have a large library (12,000 video files). I tried mezzmo and found serviio better. I primarly use MediaPortal (I am a supermod for MP Forum), however I've installed serviio for accessing my movies over the network as my wifi can be a bit slow for remux sometimes.
In the interests of improving the application I'd like to list a few folder/filename combinations that failed to group the files as a single movie in the videos->movies list in the web mediabrowser. Some of these maybe known issues, so I apologize for those ones.
He's just not that in to you -> listed as 2x entries
G:\MOVIES [SD]\He's just not that into you (2009)\dmd-hjntiya CD1.avi
G:\MOVIES [SD]\He's just not that into you (2009)\dmd-hjntiya CD2.avi
G:\MOVIES [SD]\He's just not that into you (2009)\dmd-hjntiya CD1.nfo
G:\MOVIES [SD]\He's just not that into you (2009)\dmd-hjntiya CD2.nfo
G:\MOVIES [SD]\He's just not that into you (2009)\folder.jpg
The history boys -> listed as 2x entries
G:\MOVIES [SD]\History Boys (2006)\original-hb1 CD1.avi
G:\MOVIES [SD]\History Boys (2006)\original-hb1 CD2.avi
G:\MOVIES [SD]\History Boys (2006)\original-hb1 CD2.nfo
G:\MOVIES [SD]\History Boys (2006)\original-hb1 CD1.nfo
G:\MOVIES [SD]\History Boys (2006)\folder.jpg
The Fly II -> listed as 4x entries
G:\MOVIES [HQ]\The Fly 2 (1989)\folder.jpg
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS.nfo
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VIDEO_TS.BUP
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VIDEO_TS.IFO
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VIDEO_TS.VOB
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_01_0.BUP
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_01_0.IFO
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_01_0.VOB
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_01_1.VOB
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_01_2.VOB
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_01_3.VOB
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_01_4.VOB
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_02_0.BUP
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_02_0.IFO
G:\MOVIES [HQ]\The Fly 2 (1989)\VIDEO_TS\VTS_02_1.VOB
PS: When is 2.X expected to come out, is it less than a year away or >1 year till this comes out.
Kiwi
Post Wed Apr 20, 2016 1:04 pm
Re: Scraping / File Stacking failures
Did you enable file stacking in the console (and do you have Pro or still evaluating it at least?)
KIWIJUNGLIST
Post Fri Apr 22, 2016 8:07 am
Yes I have stacking enabled in the console and I am using trial version (12 days remaining).
Post Fri Apr 22, 2016 6:39 pm
Can you post an image of MediaBrowser showing the duplicates?
KIWIJUNGLIST
Post Fri Apr 22, 2016 8:50 pm
Stacking setting
The Fly II
KIWIJUNGLIST
Post Fri Apr 22, 2016 8:55 pm
KIWIJUNGLIST
Post Fri Apr 22, 2016 9:05 pm
Some movies are stacking correctly.
KIWIJUNGLIST
Post Tue Apr 26, 2016 11:50 am
Let me know if you require anymore info.
Post Thu Apr 28, 2016 9:41 am
Post Tue May 31, 2016 8:44 pm
So for the VOB set,
according to https://en.wikipedia.org/wiki/DVD-Video
Serviio will match
into one file (the main video I assume).
Then there are
.. not sure what that is, but it's outside of the stack.
And this is probably some side video
and tis is the main menu
So 1 stacked video and another 3 videos that represent menus, etc.
Post Tue May 31, 2016 8:50 pm
And for the AVIs, I suspect the have different resolutions, or similar. Cpould you post ffmpeg -i of the 4 AVI files?
