TUBE+ (series only, not for movies)
JAB_98
Post Tue Apr 19, 2016 10:14 am
Re: TUBE+ (series only, not for movies)
amnarciso wrote:Features on version 1.0:
- You can select only one season or load the entire series (although it might not be a good idea, since it will take forever to load)
- Currently for each episode, it will use the first link from a host that is compatible with the plugin
- List of compatible hosts: [gorillavid.in], [vidbull.com], [movshare.net]
have you checked if the show you are trying to get has on of these 3 host [gorillavid.in], [vidbull.com], [movshare.net]?
bsdboy
Post Thu Apr 21, 2016 3:42 am
Yup, the season is on vidbull.com. Check it out yourself, here's the URL: <http://www.tubeplus.me/player/2173747/The_Blacklist/season_3http://www.tubeplus.is/player/2173747/The_Blacklist/season_3>
JAB_98
Post Tue Apr 26, 2016 9:14 am
bsdboy wrote:Yup, the season is on vidbull.com. Check it out yourself, here's the URL: <http://www.tubeplus.me/player/2173747/The_Blacklist/season_3http://www.tubeplus.is/player/2173747/The_Blacklist/season_3>
try this <http://www.tubeplus.is/player/2173747/The_Blacklist/season_3>
bsdboy
Post Wed Apr 27, 2016 3:31 am
I changed the season URL as you suggested, still no joy -- "No titles found".
JAB_98
Post Fri Apr 29, 2016 7:20 am
try the original program that was posted
bsdboy
Post Mon May 02, 2016 2:13 am
Against which URL?
Previous
Return to Available plugins
Users browsing this forum: Baidu [Spider] and 1 guest
