Password for WebConsole in Serviio v1.6.1
Ronar85
Post Mon May 16, 2016 9:01 am
Serviio is such a nice streaming server - i've just upgraded to version 1.6.1.
But - one thing - is is possible to set a passwort on the WebConsole? Because in the default setup, everybondy is able to access the WebConsole and is able to change the settings.
Is there a passwort feature?
Thanks,
Post Mon May 16, 2016 12:14 pm
Re: Password for WebConsole in Serviio v1.6.1
There is no password at this time. It has been suggested, but no idea what the timeframe might be for implementation. I'm not certain Zip has even decided to add it.
Ronar85
Post Mon May 16, 2016 4:45 pm
thanks for your reply. Hopefully this feature will find a way to be implemented ;) - otherwise the Management of the Streaming Server would be a little bit more complicated.
Should i add a Feature-Request?
Thanks,
Post Mon May 16, 2016 10:34 pm
I think there's already one (or more) there. :D
