Qnap 1.6 Serviio support
Post Tue May 17, 2016 4:32 pm
Re: Qnap 1.6 Serviio support
I'm not sure if the bluray subtitles option is actually supported. Post ffmpeg -i of the bluray rip file.
Ekomax
Post Wed May 18, 2016 3:37 pm
How do i do this? sorry.
DEJ710
Post Sun May 22, 2016 2:43 am
Hi zip,
Great work with the Serviio console and the QNAP app.
I am having problems with the auto indexing of files. It works if I force a refresh, but doesn't seem to do it automatically.
Please advise if you need log files or similar.
Jason
LG 86UM7600PTA 4K TV Sony KD-75X8500D 4K TV Panasonic DP-UB820 4K BluRay NVIDIA Shield TV Pro Onkyo TX-RZ3100 Windows 11 x64 Draytek Vigor2860 Router ASUS Lyra Dual Band Wireless MESH QNAP TS-464 x64 4 Bay NAS 98 TB QNAP TR-004 4 Bay Expansion
akira666
Post Wed May 25, 2016 8:06 pm
Same Problem here, running 1.6 on my Qnap TS-559.
Post Thu May 26, 2016 7:55 am
What paths do you use as your shared folders?
DEJ710
Post Thu May 26, 2016 10:37 am
Hi zip,
/share/tv shows
/share/movies
akira666
Post Fri May 27, 2016 11:01 pm
3 shared Folders with the indexing Problem:
/share/Download
/share/Multimedia/Filme
/share/Multimedia/Anime
Xmantium
Post Sat May 28, 2016 7:32 pm
I have the same issue, not automatically indexing files but i have script in sabnzbd after a file is downloaded
#!/usr/bin/env python
import httplib
connection = httplib.HTTPConnection('192.168.1.5:23423')
body_content = '<action><name>forceLibraryRefresh</name></action>'
headers = { "Content-type": "text/xml" }
connection.request('POST', '/rest/action' , body_content , headers)
result = connection.getresponse()
if result.status == 200:
    print "Updated Serviio"
else :
    print "Updating Serviio Library Failed"
Theres a bug with Serviio though - if Serviio's autodetect add the file to library and the script runs, it adds the same video file twice to the library
Serviio should not add the video twice to library when manually refreshed at the same time Serviio detects the file
ianfretwell
Post Sun May 29, 2016 5:51 pm
Regarding the automatically indexing new files...my preferred option is to do this manually...
However, I have two identically configured Qnap NAS's - an ARM based TS531p and an AMD (so x86) based TS563.
Serviio on both is setup identically with NO automatic indexing - regardless of which the ARM based one does it anyway - I can't stop it. The x86 one works as expected and I have to force the refresh.
Thought this might help narrow it down slightly if there is a bug somewhere.
Post Tue May 31, 2016 6:46 pm
It works for me on the Intel based build. I'm sharing
/share/Multimedia/Videos
Do you have the latest Java package installed?
Also, what does the detailed log say after you start the service?
ianfretwell
Post Tue May 31, 2016 7:35 pm
Java on both is the latest that's available from the Qnap app center.
Just to clarify - the Intel build does work as it should, i.e. if I turn off the automatic indexing it stops automatic indexing.
The ARM build automatically indexes new files regardless of what it's set to.
I'll try to get the detailed logs from the ARM NAS for you ASAP.
Previous
