Serviio 1.6.1 won't open
tmtd
Post Sun May 22, 2016 3:54 pm
i recently upgrade my Serviio to 1.6.1 version, unfortunately suddenly it won't open. So i checked if my Java Version was updated, so i upgraded to Java 8-91.
I am a MAC USER, under MAC OSX 10.9.5-
This is serviio.log
2016-05-22 00:21:52,481 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-22 00:21:52,520 INFO [MediaServer] Serviio DLNA media streaming server v 1.6.1 (rev. 34f326d2b259)
2016-05-22 00:21:52,520 INFO [MediaServer] Petr Nejedly 2009-2015
2016-05-22 00:21:52,520 INFO [MediaServer] http://www.serviio.org
2016-05-22 00:21:52,520 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2016-05-22 00:21:52,520 INFO [MediaServer] OS Mac OS X 10.9.5
2016-05-22 00:21:52,521 INFO [MediaServer] File encoding: UTF-8
2016-05-22 00:21:52,538 INFO [MediaServer] Headless mode enabled: true
2016-05-22 00:21:52,538 INFO [MediaServer] User: root
2016-05-22 00:21:52,538 INFO [MediaServer] User home dir: /var/root
2016-05-22 00:21:52,538 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2016-05-22 00:21:52,538 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-22 00:21:53,037 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-05-22 00:21:53,060 INFO [DatabaseManager] Using DERBY database language
2016-05-22 00:21:57,841 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@85ede7b, see the next exception for details.
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.jdbc.InternalDriver$1.run(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:270)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:78)
at org.serviio.MediaServer.main(MediaServer.java:119)
Caused by: ERROR XJ040: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@85ede7b, see the next exception for details.
at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
... 22 more
Caused by: ERROR XSDB2: Unknown container format at container null : 0
at org.apache.derby.impl.store.raw.data.FileContainer.readHeaderFromArray(Unknown Source)
at org.apache.derby.impl.store.raw.data.FileContainer.readHeader(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer.run(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer4.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.FileContainer.setIdent(Unknown Source)
at org.apache.derby.impl.store.raw.data.FileContainer.setIdentity(Unknown Source)
at org.apache.derby.impl.services.cache.ConcurrentCache.find(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openDroppedContainer(Unknown Source)
at org.apache.derby.impl.store.raw.xact.Xact.openDroppedContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.PageBasicOperation.findpage(Unknown Source)
at org.apache.derby.impl.store.raw.data.PageBasicOperation.needsRedo(Unknown Source)
at org.apache.derby.impl.store.raw.log.FileLogger.redo(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.startModule(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager$5.run(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase$5.run(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootServiceModule(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection$4.run(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.startPersistentService(Unknown Source)
... 19 more
2016-05-22 00:21:59,870 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
2016-05-22 17:32:29,586 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-22 17:32:29,638 INFO [MediaServer] Serviio DLNA media streaming server v 1.6.1 (rev. 34f326d2b259)
2016-05-22 17:32:29,638 INFO [MediaServer] Petr Nejedly 2009-2015
2016-05-22 17:32:29,638 INFO [MediaServer] http://www.serviio.org
2016-05-22 17:32:29,638 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2016-05-22 17:32:29,639 INFO [MediaServer] OS Mac OS X 10.9.5
2016-05-22 17:32:29,639 INFO [MediaServer] File encoding: UTF-8
2016-05-22 17:32:29,640 INFO [MediaServer] Headless mode enabled: true
2016-05-22 17:32:29,640 INFO [MediaServer] User: root
2016-05-22 17:32:29,640 INFO [MediaServer] User home dir: /var/root
2016-05-22 17:32:29,640 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2016-05-22 17:32:29,640 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-22 17:32:29,656 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-05-22 17:32:29,674 INFO [DatabaseManager] Using DERBY database language
2016-05-22 17:32:30,234 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 22 more
... 19 more
2016-05-22 17:32:32,257 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2016-05-22 17:50:15,529 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-22 17:50:15,530 INFO [MediaServer] Serviio DLNA media streaming server v 1.6.1 (rev. 34f326d2b259)
2016-05-22 17:50:15,530 INFO [MediaServer] Petr Nejedly 2009-2015
2016-05-22 17:50:15,530 INFO [MediaServer] http://www.serviio.org
2016-05-22 17:50:15,530 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2016-05-22 17:50:15,530 INFO [MediaServer] OS Mac OS X 10.9.5
2016-05-22 17:50:15,530 INFO [MediaServer] File encoding: UTF-8
2016-05-22 17:50:15,530 INFO [MediaServer] Headless mode enabled: true
2016-05-22 17:50:15,530 INFO [MediaServer] User: root
2016-05-22 17:50:15,530 INFO [MediaServer] User home dir: /var/root
2016-05-22 17:50:15,530 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2016-05-22 17:50:15,531 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-22 17:50:15,550 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-05-22 17:50:15,572 INFO [DatabaseManager] Using DERBY database language
2016-05-22 17:50:16,165 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 22 more
... 19 more
2016-05-22 17:50:18,196 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
And this is derby.log
Sun May 22 17:50:16 CEST 2016:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.12.1.1 - (1704137): instance a816c00e-0154-d928-e257-fffff4a463b2
on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@85ede7b
Loaded from file:/Library/Application%20Support/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.8.0_40-b27
user.dir=/
os.name=Mac OS X
os.arch=x86_64
os.version=10.9.5
derby.system.home=/Library/Application Support/Serviio/library
derby.stream.error.file=../log/derby.log
------------ Begin Shutdown Error Stack -------------
ERROR XSLA7: Cannot redo operation null in the log.
... 52 more
============= begin nested exception, level (1) ===========
============= end nested exception, level (1) ===========
------------ End Shutdown Error Stack -------------
Shutting down instance a816c00e-0154-d928-e257-fffff4a463b2 on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@85ede7b
Sun May 22 17:50:16 CEST 2016 Thread[main,5,main] Cleanup action starting
... 22 more
... 19 more
java.sql.SQLException: Unknown container format at container null : 0
... 19 more
============= begin nested exception, level (2) ===========
============= end nested exception, level (2) ===========
Cleanup action completed
Any Tips or Solutions?
THANK YOU!
Post Mon May 23, 2016 11:43 am
Re: Serviio 1.6.1 won't open
Try to uninstall and install again. See FAQ on how to do this on OSX.
tmtd
Post Mon May 23, 2016 5:58 pm
Ok the order of the commands that i launched is this:
sudo launchctl unload /Library/LaunchDaemons/org.serviio.server.plist
sudo rm -rf /Library/Application\ Support/Serviio
sudo rm /Library/LaunchDaemons/org.serviio.server.plist
and also this
sudo rm -rf /Applications/Serviio.Console.app
But there isn't no effect.
The difference between now and the previous test is that now i don't have any log!
tmtd
Post Mon May 23, 2016 6:16 pm
Sorry it's not true, there are derby.log and serviio.log
Mon May 23 20:05:50 CEST 2016 Thread[main,5,main] Cleanup action starting
ERROR XBM0A: The database directory '/Library/Application Support/Serviio/library/db' exists. However, it does not contain the expected 'service.properties' file. Perhaps Derby was brought down in the middle of creating this database. You may want to delete this directory and try creating the database again.
at org.apache.derby.impl.services.monitor.StorageFactoryService.vetService(Unknown Source)
at org.apache.derby.impl.services.monitor.StorageFactoryService.access$900(Unknown Source)
at org.apache.derby.impl.services.monitor.StorageFactoryService$10.run(Unknown Source)
at org.apache.derby.impl.services.monitor.StorageFactoryService.createServiceRoot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.createPersistentService(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.createPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.createPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection$5.run(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.createPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Unknown Source)
java.sql.SQLException: Failed to create database 'db', see the next exception for details.
Caused by: ERROR XJ041: Failed to create database 'db', see the next exception for details.
... 22 more
Caused by: ERROR XBM0A: The database directory '/Library/Application Support/Serviio/library/db' exists. However, it does not contain the expected 'service.properties' file. Perhaps Derby was brought down in the middle of creating this database. You may want to delete this directory and try creating the database again.
... 19 more
java.sql.SQLException: The database directory '/Library/Application Support/Serviio/library/db' exists. However, it does not contain the expected 'service.properties' file. Perhaps Derby was brought down in the middle of creating this database. You may want to delete this directory and try creating the database again.
... 19 more
2016-05-23 20:05:48,574 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-23 20:05:48,576 INFO [MediaServer] Serviio DLNA media streaming server v 1.6.1 (rev. 34f326d2b259)
2016-05-23 20:05:48,576 INFO [MediaServer] Petr Nejedly 2009-2015
2016-05-23 20:05:48,576 INFO [MediaServer] http://www.serviio.org
2016-05-23 20:05:48,576 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2016-05-23 20:05:48,576 INFO [MediaServer] OS Mac OS X 10.9.5
2016-05-23 20:05:48,576 INFO [MediaServer] File encoding: UTF-8
2016-05-23 20:05:48,577 INFO [MediaServer] Headless mode enabled: true
2016-05-23 20:05:48,577 INFO [MediaServer] User: root
2016-05-23 20:05:48,577 INFO [MediaServer] User home dir: /var/root
2016-05-23 20:05:48,577 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2016-05-23 20:05:48,577 INFO [MediaServer] ------------------------------------------------------------------------
2016-05-23 20:05:48,607 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-05-23 20:05:48,632 INFO [DatabaseManager] Using DERBY database language
2016-05-23 20:05:50,653 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 22 more
... 19 more
2016-05-23 20:05:52,659 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
tmtd
Post Mon May 23, 2016 6:47 pm
Question: there is a install log during the installation process?
Post Thu May 26, 2016 8:00 am
Ok, so you did remove everything and then installed Serviio again, right?
The log says the library is corrupted
So something in your installation didn't work correctly.
You can see installation log in the installer window (there is a menu I think to show the log, make sure to enable it at the beginning of the installation process)
tmtd
Post Thu May 26, 2016 8:12 am
Thank you for your effort zip, now it works suddenly, don't ask me why... :D
