Serviio Not refreshing content database
papple
Post Thu May 05, 2016 9:21 pm
Im experiencing issues with Serviio not refreshing its content database. Is there logging in place for debug? Better yet, how do I simply drop the database and begin anew.
Thanks,
-Paul
Shred
Post Mon May 09, 2016 11:48 am
Re: Serviio Not refreshing content database
What OS are you running Serviio on? Does a manual "Force refresh" work?
msfaulk
Post Tue May 24, 2016 1:15 am
I am having the same issue with Serviio not auto refreshing when I add a video. It started doing this about 3 weeks ago. I can manually refresh and it finds everything; I am running Windows 7. I haven't changed anything on this PC to include updates. It just stopped working one day. Any Ideas?
Mike
spacemutron
Post Sun Jun 05, 2016 10:25 am
same to me. 1.6.1 pro
force refresh works
Auto refresh - not
is there an DOS command to start the refresh manually? then i will make a schedule......
Post Sun Jun 12, 2016 9:49 am
there is an API for invoking the force refresh functionality. http://docs.serviio.apiary.io/#reference/0/action
You could also try to switch to the poller mechanism. http://wiki.serviio.org/doku.php?id=lib ... er_scanner
