ServiiGo ChromeCast Icon
Rosales_Network
Post Mon Apr 25, 2016 3:57 am
I use the ServiiGo application most of the time instead of using the web based media browser.
Can the ServiiGo application support a plug in to add the chromecast icon on the app so it can be more easy to stream from your phone to any available chromecast.
Currently I use a third party app to perform this task.
All Cast searches for any available media server within your network and then finds any available chromecast to stream the video, but it sometimes lags on loading the video.
All Cast:
https://play.google.com/store/apps/deta ... cast&hl=en
it would be nice to bypass the middle man and go straight to the chromecast.
:ugeek: :ugeek: :ugeek: :ugeek: :arrow: :idea:
Android Sender App Development:
https://developers.google.com/cast/docs/android_sender
Post Tue Apr 26, 2016 6:35 am
Re: ServiiGo ChromeCast Icon
There is some experimental support built in, see viewtopic.php?f=17&t=6803&start=660#p96696 for how to turn it on.
Post Wed Apr 27, 2016 8:39 am
will wrote:There is some experimental support built in, see viewtopic.php?f=17&t=6803&start=660#p96696 for how to turn it on.
Is this being blocked by Serviio or something on the Android side? Can I do something to help you enable it?
Post Thu May 05, 2016 7:32 pm
It's mostly just a lack of time to work on it. Made worse by the fact that the last few times I've sat down to work on it there have been lots of library API changes to work though. I might get some time in a few weeks, but not sure.
Rosales_Network
Post Thu May 12, 2016 4:53 am
is it possible to add this feature?
Post Fri May 13, 2016 8:19 pm
Rosales_Network wrote:is it possible to add this feature?
Did you follow the instructions to enable it?
Rosales_Network
Post Wed May 25, 2016 5:26 pm
Yes I was able to get the chrome cast to show.
But it drops the signal within 5-10 minutes
Return to Feature requests
