SvtPlay
ottomatic
Post Fri Mar 11, 2016 11:33 am
Re: SvtPlay
Folks,
Responding to recent breaking changes of the markup at the site, I have now uploaded new versions of both the RSS feed plugin and the Web resource plugin.
Go to the top post in the thread and download your new versions!
Regards
/ O
Jools
Post Mon May 30, 2016 8:45 am
Re: SvtPlay
I think there has been a new format change on svtplay, at least all my feeds started becoming empty, on two of my machines.
Why are they always making these changes? Is it because they don't like that people can watch these streams without the adverts that come with them?
Here's the log if it helps: there are a bunch of entries like this:
2016-05-30 11:44:23,681 WARN [FeedParser] Plugin SvtPlayRss returned no value for resource item 'Tidernas största fest'
Edit: here's the actual log: http://pastebin.com/8Wve7T52
ottomatic
Post Mon May 30, 2016 10:04 am
Re: SvtPlay
Jools wrote:Hello,
No, I just think they are refactoring, making improvements, and they can't take into account the way a scraping plugin framework like Serviio uses their web pages.
Jools wrote:Here's the log if it helps: there are a bunch of entries like this:
Thanks. I'll look into it when I have the time. Right now I a m swamped with work.
Regards
/ O
Jools
Post Wed Jun 29, 2016 9:15 pm
Re: SvtPlay
That's understandable. I was wondering what this actually entails, just investigate the network with something like wireshark and update the feed format? Would it be any idea to put this on github so people can more easily contribute?
ottomatic
Post Thu Jun 30, 2016 8:48 am
Re: SvtPlay
Jools wrote:That's understandable. I was wondering what this actually entails, just investigate the network with something like wireshark and update the feed format? Would it be any idea to put this on github so people can more easily contribute?
At this point you probably won't need to inspect network traffic. It's usually just a matter of inspecting html source to find out the patterns of the markup, and update the regular expressions used to find the links to the stream definitions.
The plugin source is hosted at Bitbucket :
https://bitbucket.org/ottomatic/serviio-plugins
You should be able to clone it and submit pull requests.
Regards
/ O
Previous
Return to Available plugins
