[Solved] Serviio 1.6.1 "the Server has been stopped"
compi
Post Mon May 30, 2016 6:24 am
Serviio Console run but the Medienserver don`t run.
I use Ubuntu 14.04 , Serviio 1.6.1
Please help me
compi
lars@ubuntu:/usr/local/serviio/bin$ java -version
java version "9-ea"
Java(TM) SE Runtime Environment (build 9-ea+119)
Java HotSpot(TM) 64-Bit Server VM (build 9-ea+119, mixed mode)
2016-05-30 08:11:31,514 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2016-05-30 08:11:31,515 INFO  [MediaServer] ------------------------------------------------------------------------
2016-05-30 08:11:31,515 INFO  [MediaServer] Serviio DLNA media streaming server v 1.6.1 (rev. 34f326d2b259)
2016-05-30 08:11:31,515 INFO  [MediaServer] Petr Nejedly 2009-2015
2016-05-30 08:11:31,515 INFO  [MediaServer] http://www.serviio.org
2016-05-30 08:11:31,515 INFO  [MediaServer] Java 9-ea-Oracle Corporation amd64
2016-05-30 08:11:31,515 INFO  [MediaServer] OS Linux 4.2.3-040203-generic
2016-05-30 08:11:31,515 INFO  [MediaServer] File encoding: UTF-8
2016-05-30 08:11:31,516 INFO  [MediaServer] Headless mode enabled: true
2016-05-30 08:11:31,516 INFO  [MediaServer] User: lars
2016-05-30 08:11:31,516 INFO  [MediaServer] User home dir: /home/lars
2016-05-30 08:11:31,516 INFO  [MediaServer] Temp dir: /tmp
2016-05-30 08:11:31,516 INFO  [MediaServer] ------------------------------------------------------------------------
2016-05-30 08:11:31,530 DEBUG [MediaServer] Runtime params: -Xmx512M, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dderby.system.home=/usr/local/serviio/library, -Dserviio.home=/usr/local/serviio, -Dffmpeg.location=ffmpeg, -Ddcraw.location=dcraw
2016-05-30 08:11:31,534 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-05-30 08:11:31,554 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2016-05-30 08:11:31,555 INFO  [DatabaseManager] Using DERBY database language
2016-05-30 08:11:32,140 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2016-05-30 08:11:32,141 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2016-05-30 08:11:32,141 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2016-05-30 08:11:32,142 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2016-05-30 08:11:32,142 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2016-05-30 08:11:32,143 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2016-05-30 08:11:32,143 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2016-05-30 08:11:32,144 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2016-05-30 08:11:32,144 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2016-05-30 08:11:32,145 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2016-05-30 08:11:32,145 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2016-05-30 08:11:32,146 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2016-05-30 08:11:32,146 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2016-05-30 08:11:32,146 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2016-05-30 08:11:32,147 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2016-05-30 08:11:32,148 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2016-05-30 08:11:32,149 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2016-05-30 08:11:32,149 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2016-05-30 08:11:32,149 DEBUG [DBLogDAOImpl] Checking if script 'script-1.6.sql' has been run
2016-05-30 08:11:32,190 INFO  [WebServer] Socket buffer set to 65535 bytes
2016-05-30 08:11:32,191 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2016-05-30 08:11:32,192 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2016-05-30 08:11:32,193 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2016-05-30 08:11:32,194 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2016-05-30 08:11:32,322 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2016-05-30 08:11:32,322 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2016-05-30 08:11:32,322 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2016-05-30 08:11:32,323 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2016-05-30 08:11:32,338 DEBUG [LicensingManager] Updating license
2016-05-30 08:11:32,339 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2016-05-30 08:11:32,346 DEBUG [LicenseValidator] Validating license file (368 bytes)
2016-05-30 08:11:32,369 INFO  [MediaServer] ------------------------------------------------------------------------
2016-05-30 08:11:32,369 INFO  [MediaServer] License: PRO (NORMAL, id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxx)
2016-05-30 08:11:32,371 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth1-0
2016-05-30 08:11:32,373 INFO  [Device] Created UPnP Device with UUID: 36d95559-bb69-3be1-972f-5675e2569ceb, bound address: 192.168.178.43
2016-05-30 08:11:32,596 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2016-05-30 08:11:32,598 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2016-05-30 08:11:32,633 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-05-30 08:11:32,634 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2016-05-30 08:11:32,642 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-05-30 08:11:32,642 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2016-05-30 08:11:32,643 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-05-30 08:11:32,643 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile kirch
2016-05-30 08:11:32,644 INFO  [ProfilesDefinitionParser] Added profile '(Kirchner)' (id=kirch)
2016-05-30 08:11:32,644 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2016-05-30 08:11:32,644 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-05-30 08:11:32,644 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ps4
2016-05-30 08:11:32,645 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2016-05-30 08:11:32,645 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2016-05-30 08:11:32,645 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-05-30 08:11:32,645 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2016-05-30 08:11:32,652 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-05-30 08:11:32,652 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2016-05-30 08:11:32,653 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-05-30 08:11:32,653 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_j
2016-05-30 08:11:32,654 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2016-05-30 08:11:32,654 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2016-05-30 08:11:32,654 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-05-30 08:11:32,654 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2016-05-30 08:11:32,655 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-05-30 08:11:32,655 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2016-05-30 08:11:32,655 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-05-30 08:11:32,655 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2016-05-30 08:11:32,656 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-05-30 08:11:32,656 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2016-05-30 08:11:32,657 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-05-30 08:11:32,657 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2016-05-30 08:11:32,657 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-05-30 08:11:32,657 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2016-05-30 08:11:32,658 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-05-30 08:11:32,658 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2016-05-30 08:11:32,658 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-05-30 08:11:32,658 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2016-05-30 08:11:32,659 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-05-30 08:11:32,659 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2016-05-30 08:11:32,659 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-05-30 08:11:32,659 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2016-05-30 08:11:32,659 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-05-30 08:11:32,659 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2016-05-30 08:11:32,659 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-05-30 08:11:32,660 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2016-05-30 08:11:32,660 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-05-30 08:11:32,660 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2016-05-30 08:11:32,660 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-05-30 08:11:32,660 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2016-05-30 08:11:32,661 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-05-30 08:11:32,661 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2016-05-30 08:11:32,661 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-05-30 08:11:32,661 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2016-05-30 08:11:32,661 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-05-30 08:11:32,661 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2016-05-30 08:11:32,661 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-05-30 08:11:32,661 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2016-05-30 08:11:32,662 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-05-30 08:11:32,662 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2016-05-30 08:11:32,662 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-05-30 08:11:32,662 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2016-05-30 08:11:32,662 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-05-30 08:11:32,662 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2016-05-30 08:11:32,662 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-05-30 08:11:32,662 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2016-05-30 08:11:32,663 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-05-30 08:11:32,663 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2016-05-30 08:11:32,663 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-05-30 08:11:32,663 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2016-05-30 08:11:32,663 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-05-30 08:11:32,664 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2016-05-30 08:11:32,664 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-05-30 08:11:32,664 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2016-05-30 08:11:32,664 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-05-30 08:11:32,664 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2009
2016-05-30 08:11:32,664 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2016-05-30 08:11:32,664 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2016-05-30 08:11:32,664 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-05-30 08:11:32,664 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2016-05-30 08:11:32,665 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-05-30 08:11:32,665 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2016-05-30 08:11:32,665 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-05-30 08:11:32,665 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2016-05-30 08:11:32,665 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-05-30 08:11:32,665 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2016-05-30 08:11:32,665 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-05-30 08:11:32,665 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2016-05-30 08:11:32,666 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2016-05-30 08:11:32,666 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2016-05-30 08:11:32,666 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-05-30 08:11:32,666 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2016-05-30 08:11:32,666 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-05-30 08:11:32,666 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2016-05-30 08:11:32,666 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-05-30 08:11:32,667 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2016-05-30 08:11:32,667 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-05-30 08:11:32,667 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2016-05-30 08:11:32,667 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-05-30 08:11:32,667 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2016-05-30 08:11:32,667 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-05-30 08:11:32,668 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2016-05-30 08:11:32,668 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-05-30 08:11:32,668 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2016-05-30 08:11:32,668 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-05-30 08:11:32,690 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2016-05-30 08:11:32,690 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2016-05-30 08:11:32,690 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-05-30 08:11:32,690 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile android
2016-05-30 08:11:32,691 INFO  [ProfilesDefinitionParser] Added profile 'Android' (id=android)
2016-05-30 08:11:32,691 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2016-05-30 08:11:32,691 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-05-30 08:11:32,691 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2016-05-30 08:11:32,691 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-05-30 08:11:32,691 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2016-05-30 08:11:32,692 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-05-30 08:11:32,692 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2016-05-30 08:11:32,692 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-05-30 08:11:32,692 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2016-05-30 08:11:32,692 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-05-30 08:11:32,692 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2016-05-30 08:11:32,692 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-05-30 08:11:32,692 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2016-05-30 08:11:32,693 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-05-30 08:11:32,693 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2016-05-30 08:11:32,693 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-05-30 08:11:32,693 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2016-05-30 08:11:32,693 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2016-05-30 08:11:32,715 INFO  [PluginCompilerThread] Looking for plugins at /usr/local/serviio/plugins
2016-05-30 08:11:32,715 INFO  [PluginCompilerThread] Started looking for plugins
2016-05-30 08:11:32,715 INFO  [UpdateChecker] Checking if a new version is available
2016-05-30 08:11:32,719 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2016-05-30 08:11:32,724 DEBUG [ProcessExecutor] Starting ffmpeg
2016-05-30 08:11:32,751 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg
2016-05-30 08:11:32,752 INFO  [FFMPEGWrapper] FFmpeg details: [version=N-74276-g3c86522, libRtpmPresent=true, libAssPresent=true, libShinePresent=false]
2016-05-30 08:11:32,752 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path dcraw
2016-05-30 08:11:32,752 DEBUG [ProcessExecutor] Starting dcraw
2016-05-30 08:11:32,761 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-05-30 08:11:32,761 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: /temp/Serviio
2016-05-30 08:11:40,104 DEBUG [LicensingManager] Updating license
2016-05-30 08:11:40,104 DEBUG [LicenseValidator] Validating license file (368 bytes)
2016-05-30 08:11:40,125 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2016-05-30 08:11:40,133 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2016-05-30 08:11:45,398 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2016-05-30 08:11:45,403 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-05-30 08:11:50,377 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-05-30 08:11:55,372 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-05-30 08:12:00,371 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-05-30 08:12:02,419 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2016-05-30 08:12:02,428 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2016-05-30 08:12:05,374 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-05-30 08:12:06,348 DEBUG [LicensingManager] Updating license
2016-05-30 08:12:06,348 DEBUG [LicenseValidator] Validating license file (368 bytes)
2016-05-30 08:12:08,054 WARN  [ServiioStatusService] ServerUnavailableException occured. Returning error code 503 to the REST layer. Message: Server is not available
2016-05-30 08:12:08,054 DEBUG [ServiioStatusService] Detailed exception:
org.serviio.restlet.ServerUnavailableException: Server is not available
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:63)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:1014)
   at org.restlet.resource.Finder.handle(Finder.java:246)
   at org.restlet.routing.Filter.doHandle(Filter.java:159)
   at org.restlet.routing.Filter.handle(Filter.java:206)
   at org.restlet.routing.Router.doHandle(Router.java:431)
   at org.restlet.routing.Router.handle(Router.java:648)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:155)
   at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:211)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:84)
   at org.restlet.Application.handle(Application.java:384)
   at org.restlet.Component.handle(Component.java:406)
   at org.restlet.Server.handle(Server.java:516)
   at org.restlet.engine.connector.ServerHelper.handle(ServerHelper.java:72)
   at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:152)
   at org.restlet.ext.simple.internal.SimpleContainer.handle(SimpleContainer.java:80)
   at org.simpleframework.http.core.Dispatcher.dispatch(Dispatcher.java:121)
   at org.simpleframework.http.core.Dispatcher.run(Dispatcher.java:103)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(java.base@9-ea/ThreadPoolExecutor.java:1158)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(java.base@9-ea/ThreadPoolExecutor.java:632)
   at java.lang.Thread.run(java.base@9-ea/Thread.java:804)
2016-05-30 08:12:10,370 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
Post Tue May 31, 2016 8:05 am
Re: Serviio 1.6.1 "the Server has been stopped"
I takes about 30 seconds to start the server. After that the API should be up and MediaBrowser should work.
compi
Post Tue May 31, 2016 3:01 pm
nothing happens after hours
Gesendet von meinem Xperia Z Ultra mit Tapatalk
Post Tue May 31, 2016 6:57 pm
Just noticed you're using Java 9 early access... I haven't tested it with Java 9, so you should try it with the latest java 8.
compi
Post Wed Jun 01, 2016 6:23 am
java 8 and then it works, thanks!
