General DLNA profile or specific Panasonic profile?
bijlevel
Post Mon Apr 25, 2016 12:26 pm
I did not change the standard profile in the serviio console, so it is still on the General DLNA profile. So far my content plays OK, but is it safer/better to use the Panasonic Viera (2013) profile? I have a TX-55CX800 Panasonic Viera.
bijlevel
Post Sun Jun 05, 2016 6:51 pm
Re: General DLNA profile or specific Panasonic profile?
234 people looked at or did read this post. Does nobody have an answer??
Post Mon Jun 06, 2016 3:01 am
The Generic Profile does not transcode anything. Using it is fine if you only have files in your media library that are supported natively by your Panasonic.
If you start to add files to your library that are not supported by your TV then you will need to use a different profile (for example, h265 video is not supported by your TV, nor is the old DivX codec or some HD audio codecs. You will find files using these codecs will not play on your TV unless you transcode them, which requires a different profile to be set).
If you do need to use another profile, the Panasonic Viera (2013) profile is fine, but you may also want to add your own Panasonic Viera (2015) profile. Have a look at viewtopic.php?f=7&t=21909 for my profile and some feedback from a CX800 user.
bijlevel
Post Mon Jun 06, 2016 8:30 am
Thank you so much for your answer! I will have a look at the profile you mention and if needed will try to learn how to make a custom profile. Thanks again!
Return to Panasonic
