syntax error near unexpected token
efekt
Post Thu Jun 09, 2016 5:07 pm
I cannot run any movie with subtitles on my setup:
TV: Sony KDL-40ex650
Profile: Sony Bravia TV (2012)
Serviio: Synology NAS DS214play
Serviio Version: 1.6.1
Probable cause
2016-06-09 17:50:34,064 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.mp4
2016-06-09 17:50:34,065 DEBUG [ProcessExecutor] Starting /var/packages/Serviio/target/bin/ffmpeg-wrapper-i686evansport.sh -threads 4 -i /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.mp4 -y -c:v libx264 -pix_fmt yuv420p -profile:v baseline -level 3 -preset veryfast -b:v 17000k -maxrate:v 17000k -bufsize:v 17000k -crf 25 -filter_complex [0:0]subtitles=filename=/volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt:original_size=1280x536:charenc=UTF-8[v1],[v1]pad=1280:720:0:92:black[v2],[v2]setdar=4:3[v] -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a ac3 -b:a 384k -ac 2 -map [v] -map 0:1 -sn -f mpegts /volume1/@tmp/Serviio/transcoding-temp-182607-sony2012-ORIGINAL-58958b3746b530a2bd2273fc792b8037.stf
2016-06-09 17:50:34,156 WARN [ProcessExecutor] Process /var/packages/Serviio/target/bin/ffmpeg-wrapper-i686evansport.sh has a return code of 2! This is a possible error. Detailed output follows.
/var/packages/Serviio/target/bin/ffmpeg-wrapper-i686evansport.sh: eval: line 77: syntax error near unexpected token `('
/var/packages/Serviio/target/bin/ffmpeg-wrapper-i686evansport.sh: eval: line 77: `/var/packages/Serviio/target/bin/ffmpeg -threads 4 -prefer_smd -i "/volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.mp4" -y -c:v h264_smd -pix_fmt yuv420p -profile:v high -level 4.1 -b:v 17000k -maxrate:v 17000k -bufsize:v 17000k -filter_complex [0:0]subtitles=filename=/volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt:original_size=1280x536:charenc=UTF-8[v1],[v1]pad=1280:720:0:92:black[v2],[v2]setdar=4:3[v] -r 24000/1001 -bsf:v h264_mp4toannexb -flags -global_header -c:a ac3 -b:a 384k -ac 2 -map [v] -map 0:1 -sn -f mpegts /volume1/@tmp/Serviio/transcoding-temp-182607-sony2012-ORIGINAL-58958b3746b530a2bd2273fc792b8037.stf'
2016-06-09 17:50:34,156 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
More output:
2016-06-09 17:50:30,013 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46462: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 702,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2016-06-09 17:50:30,014 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,017 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.100
2016-06-09 17:50:30,018 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,032 DEBUG [ContentDirectory] Browse() called for renderer KDL-40EX650 (profile sony2012) with parameters: objectID = V_F^FOL_R4$F31235, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2016-06-09 17:50:30,033 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2016-06-09 17:50:30,035 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 31235 [No_Restriction]
2016-06-09 17:50:30,069 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 31235 (from=0, count=10) [No_Restriction]
2016-06-09 17:50:30,234 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:30,237 DEBUG [GenreDAOImpl] Reading a Genre (id = 24)
2016-06-09 17:50:30,258 DEBUG [VideoDAOImpl] Reading a Video (id = 182607)
2016-06-09 17:50:30,297 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 182607 and profile Sony Bravia TV (2012)
2016-06-09 17:50:30,307 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:30,310 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:30,316 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Annie.2014.720p.BluRay.x264.YIFY.mp4": AVC_TS_MP_HD_AC3_ISO
2016-06-09 17:50:30,318 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 35325)
2016-06-09 17:50:30,322 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:30,324 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 31235 (filter: ALL) [No_Restriction]
2016-06-09 17:50:30,328 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2016-06-09 17:50:30,349 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:30,479 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46463: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 702,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2016-06-09 17:50:30,480 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,486 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.100
2016-06-09 17:50:30,486 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,515 DEBUG [ContentDirectory] Browse() called for renderer KDL-40EX650 (profile sony2012) with parameters: objectID = V_F^FOL_R4$F31235, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2016-06-09 17:50:30,515 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2016-06-09 17:50:30,518 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2016-06-09 17:50:30,534 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:30,535 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46464: GET /resource/35325/COVER_IMAGE HTTP/1.1, headers = [transferMode.dlna.org: Interactive,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895]]
2016-06-09 17:50:30,535 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,545 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,591 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.100, Profile=Sony Bravia TV (2012)'
2016-06-09 17:50:30,595 DEBUG [ResourceDeliveryProcessor] Request for resource 35325 and type 'COVER_IMAGE' received
2016-06-09 17:50:30,600 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 35325)
2016-06-09 17:50:30,604 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 35325
2016-06-09 17:50:30,611 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 35325)
2016-06-09 17:50:30,613 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 35325
2016-06-09 17:50:30,614 DEBUG [GETMethodProcessor] Stream entity has length: 4528
2016-06-09 17:50:30,619 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 4528,Content-Type: image/jpeg,Cache-control: no-cache,Connection: keep-alive,Date: Thu, 09 Jun 2016 16:50:30 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Interactive]]
2016-06-09 17:50:30,665 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46465: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 702,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2016-06-09 17:50:30,665 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,670 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.100
2016-06-09 17:50:30,670 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:30,713 DEBUG [ContentDirectory] Browse() called for renderer KDL-40EX650 (profile sony2012) with parameters: objectID = V_F^FOL_R4$F31235, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2016-06-09 17:50:30,713 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2016-06-09 17:50:30,715 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2016-06-09 17:50:30,735 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:31,274 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46466: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 702,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2016-06-09 17:50:31,275 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:31,301 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.0.100
2016-06-09 17:50:31,301 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:31,317 DEBUG [ContentDirectory] Browse() called for renderer KDL-40EX650 (profile sony2012) with parameters: objectID = V_F^FOL_R4$F31235, browseFlag = BrowseDirectChildren, filter = dc:title,av:mediaClass,dc:date,@childCount,res,upnp:rating,upnp:rating@type,upnp:class,res@resolution,res@av:mpfEntries,upnp:album,upnp:genre,upnp:albumArtURI,upnp:albumArtURI@dlna:profileID,dc:creator,res@size,res@duration,res@bitrate,res@protocolInfo, startIndex = 0, count = 10, sortCriteria =
2016-06-09 17:50:31,317 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2016-06-09 17:50:31,320 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2016-06-09 17:50:31,341 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:32,189 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:50:33,828 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46467: HEAD /resource/182607/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895]]
2016-06-09 17:50:33,828 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:33,832 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:33,835 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.100, Profile=Sony Bravia TV (2012)'
2016-06-09 17:50:33,836 DEBUG [ResourceDeliveryProcessor] Request for resource 182607 and type 'MEDIA_ITEM' received
2016-06-09 17:50:33,837 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 182607 (local)
2016-06-09 17:50:33,837 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 182607)
2016-06-09 17:50:33,865 DEBUG [VideoDAOImpl] Reading a Video (id = 182607)
2016-06-09 17:50:33,871 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 182607, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2016-06-09 17:50:33,873 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,875 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,876 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file Annie.2014.720p.BluRay.x264.YIFY.mp4
2016-06-09 17:50:33,878 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,879 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Annie.2014.720p.BluRay.x264.YIFY.mp4": AVC_TS_MP_HD_AC3_ISO
2016-06-09 17:50:33,884 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Thu, 09 Jun 2016 16:50:33 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-06-09 17:50:33,899 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46468: GET /resource/182607/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [TimeSeekRange.dlna.org: npt=0.000-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895]]
2016-06-09 17:50:33,899 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:33,903 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:33,910 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.100, Profile=Sony Bravia TV (2012)'
2016-06-09 17:50:33,910 DEBUG [ResourceDeliveryProcessor] Request for resource 182607 and type 'MEDIA_ITEM' received
2016-06-09 17:50:33,910 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 182607 (local)
2016-06-09 17:50:33,910 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 182607)
2016-06-09 17:50:33,913 DEBUG [VideoDAOImpl] Reading a Video (id = 182607)
2016-06-09 17:50:33,917 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 182607, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2012)
2016-06-09 17:50:33,918 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,920 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,920 DEBUG [AbstractAVTranscodingDeliveryEngine] Getting media info for transcoded version of file Annie.2014.720p.BluRay.x264.YIFY.mp4
2016-06-09 17:50:33,922 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,923 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Annie.2014.720p.BluRay.x264.YIFY.mp4": AVC_TS_MP_HD_AC3_ISO
2016-06-09 17:50:33,924 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 182607 (local)
2016-06-09 17:50:33,924 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 182607)
2016-06-09 17:50:33,927 DEBUG [VideoDAOImpl] Reading a Video (id = 182607)
2016-06-09 17:50:33,931 DEBUG [VideoDeliveryEngine] Delivering item '182607' for client 'Identifier=192.168.0.100, Profile=Sony Bravia TV (2012)'
2016-06-09 17:50:33,932 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,934 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,935 DEBUG [VideoDeliveryEngine] Delivering file 'Annie.2014.720p.BluRay.x264.YIFY.mp4' using transcoding
2016-06-09 17:50:33,936 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,938 DEBUG [SubtitlesService] Found external subtitle file: /volume1/video/Nieobejrzane/Annie (2014)/Annie.2014.720p.BluRay.x264.YIFY.srt
2016-06-09 17:50:33,969 DEBUG [AbstractAVTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.100, Profile=Sony Bravia TV (2012)'
2016-06-09 17:50:34,893 DEBUG [SearchManager] Committing search index
2016-06-09 17:50:37,179 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:50:41,546 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.0.152, timeout = 0
2016-06-09 17:50:41,548 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 790739cb-33c1-376f-a3f7-9af39d613175
2016-06-09 17:50:42,206 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:50:42,313 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46469: GET /deviceDescription/790739cb-33c1-376f-a3f7-9af39d613175 HTTP/1.1, headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:42 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]]
2016-06-09 17:50:42,314 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,318 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 790739cb-33c1-376f-a3f7-9af39d613175 from 192.168.0.100 (headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:42 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";])
2016-06-09 17:50:42,319 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,321 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:42 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]
2016-06-09 17:50:42,324 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,348 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV (2012)'
2016-06-09 17:50:42,437 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46470: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:42 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]]
2016-06-09 17:50:42,438 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,441 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2016-06-09 17:50:42,464 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2016-06-09 17:50:42,485 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46471: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:42 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]]
2016-06-09 17:50:42,486 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,489 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2016-06-09 17:50:42,547 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2016-06-09 17:50:42,575 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46472: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2016-06-09 17:50:42,576 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,582 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.0.100
2016-06-09 17:50:42,582 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,598 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:42,619 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46473: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2016-06-09 17:50:42,620 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,624 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.0.100
2016-06-09 17:50:42,624 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,641 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2012)'
2016-06-09 17:50:42,683 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:42,774 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46474: GET /deviceDescription/790739cb-33c1-376f-a3f7-9af39d613175 HTTP/1.1, headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:43 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]]
2016-06-09 17:50:42,775 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,779 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 790739cb-33c1-376f-a3f7-9af39d613175 from 192.168.0.100 (headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:43 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";])
2016-06-09 17:50:42,779 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,781 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:43 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]
2016-06-09 17:50:42,783 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,788 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony Bravia TV (2012)'
2016-06-09 17:50:42,825 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46475: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:43 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]]
2016-06-09 17:50:42,826 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,830 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2016-06-09 17:50:42,830 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2016-06-09 17:50:42,850 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46476: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [Host: 192.168.0.152:8895,Date: Thu, 09 Jun 2016 16:50:43 GMT,User-Agent: UPnP/1.0,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";]]
2016-06-09 17:50:42,850 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,853 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2016-06-09 17:50:42,854 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2016-06-09 17:50:42,885 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46477: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 280,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"]]
2016-06-09 17:50:42,886 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,889 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.0.100
2016-06-09 17:50:42,889 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,914 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:42,962 DEBUG [ServiioHttpService] Incoming request from /192.168.0.100:46478: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40EX650";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40EX650"; mv="1.7";,Host: 192.168.0.152:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 273,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"]]
2016-06-09 17:50:42,962 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,965 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from 192.168.0.100
2016-06-09 17:50:42,966 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2016-06-09 17:50:42,979 DEBUG [ConnectionManager] Sending protocol info using profile 'Sony Bravia TV (2012)'
2016-06-09 17:50:43,017 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2016-06-09 17:50:43,452 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:34 (advertisement duration is 1800 sec.)
2016-06-09 17:50:47,172 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:50:52,170 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:50:57,171 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:50:59,218 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2016-06-09 17:50:59,218 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2016-06-09 17:51:02,174 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:04,901 DEBUG [SearchManager] Committing search index
2016-06-09 17:51:06,485 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096d58db7 from address 192.168.0.100
2016-06-09 17:51:07,160 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096d58db7 from address 192.168.0.100
2016-06-09 17:51:07,180 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:07,291 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096d58db7 from address 192.168.0.100
2016-06-09 17:51:07,524 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 00000000-0000-1010-8000-00a096d58db7 from address 192.168.0.100
2016-06-09 17:51:12,186 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:17,170 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:22,195 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:27,169 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:32,173 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:32,696 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.130:59975s
2016-06-09 17:51:34,562 DEBUG [TranscodingJobListener] Deleted temp file '/volume1/@tmp/Serviio/transcoding-temp-182607-sony2012-ORIGINAL-58958b3746b530a2bd2273fc792b8037.stf': false
2016-06-09 17:51:34,564 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding job 'transcoding-temp-182607-sony2012-ORIGINAL-58958b3746b530a2bd2273fc792b8037.stf' of client 'Identifier=192.168.0.100, Profile=Sony Bravia TV (2012)'
2016-06-09 17:51:34,564 DEBUG [AbstractAVTranscodingDeliveryEngine] Removing transcoding listener with id transcoding-temp-182607-sony2012-ORIGINAL-58958b3746b530a2bd2273fc792b8037.stf
2016-06-09 17:51:34,588 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/volume1/@tmp/Serviio/transcoding-temp-182607-sony2012-ORIGINAL-58958b3746b530a2bd2273fc792b8037.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/volume1/@tmp/Serviio/transcoding-temp-182607-sony2012-ORIGINAL-58958b3746b530a2bd2273fc792b8037.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractAVTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractAVTranscodingDeliveryEngine.java:143)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:93)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:158)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
at org.apache.http.protocol.HttpService.doService(HttpService.java:423)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:78)
at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:341)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:204)
2016-06-09 17:51:34,905 DEBUG [SearchManager] Committing search index
2016-06-09 17:51:35,697 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.130:59975s
2016-06-09 17:51:37,167 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:38,697 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.0.130:59975s
2016-06-09 17:51:42,207 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2016-06-09 17:51:42,604 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2016-06-09 17:51:42,604 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2016-06-09 17:51:42,612 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2016-06-09 17:51:42,704 DEBUG [PipeManager] Stopped PipeProcessingConsumer
2016-06-09 17:51:42,808 DEBUG [PipeManager] Stopped PipeProcessingConsumer
2016-06-09 17:51:42,808 INFO [LibraryOneTimeScanner] Interrupting library scan
2016-06-09 17:51:42,808 DEBUG [LibraryOneTimeScanner] Library scan has been interrupted
2016-06-09 17:51:42,809 INFO [LibraryDeltaScanner] Stopping the library delta scan
2016-06-09 17:51:42,809 DEBUG [FileDeltaPoller] Stopping FileDeltaPoller
2016-06-09 17:51:42,816 DEBUG [FileDeltaWatcher] Stopping FileDeltaWatcher
2016-06-09 17:51:42,818 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2016-06-09 17:51:42,921 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2016-06-09 17:51:42,921 INFO [FeedUpdaterWorker] Finished looking for online resources information
2016-06-09 17:51:43,025 INFO [PluginCompilerThread] Finished looking for plugins
2016-06-09 17:51:43,144 INFO [SearchIndexer] Closing search index writer
2016-06-09 17:51:43,152 INFO [SearchIndexer] Closing search index writer
2016-06-09 17:51:43,158 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-06-09 17:51:43,159 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: /volume1/@tmp/Serviio
2016-06-09 17:51:43,161 DEBUG [DiscoveryManager] UPNP device 790739cb-33c1-376f-a3f7-9af39d613175 (192.168.0.152) is unavailable
2016-06-09 17:51:43,161 DEBUG [WebServer] Socket closed
2016-06-09 17:51:43,161 DEBUG [WebServer] Marking the web server for exit
2016-06-09 17:51:43,161 INFO [WebServer] WebServer shutting down
2016-06-09 17:51:43,162 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2016-06-09 17:51:43,163 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2016-06-09 17:51:43,164 DEBUG [DiscoverySSDPMessageListener] Socket closed: Socket closed
2016-06-09 17:51:43,164 INFO [EventDispatcher] Leaving EventDispatcher
2016-06-09 17:51:43,164 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2016-06-09 17:51:43,165 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth0 (eth0) and address 192.168.0.152, timeout = 0
2016-06-09 17:51:43,170 INFO [DatabaseManager] Shutting down database
2016-06-09 17:51:43,172 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2016-06-09 17:51:43,173 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2016-06-09 17:51:43,428 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2016-06-09 17:51:44,125 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2016-06-09 17:51:44,125 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-06-09 17:51:44,126 DEBUG [AbstractAVTranscodingDeliveryEngine] Deleting temporary transcoded files from: /volume1/@tmp/Serviio
efekt
Post Thu Jun 09, 2016 8:49 pm
Re: syntax error near unexpected token
I have removed the (2014) from the folder name and the error disappeared. The movie still didn't play, however I have reinstalled serviio and used ffmpeg 2.7.1 instead of the lower version during the installation and the movie started working.
efekt
Post Sun Jun 12, 2016 5:30 am
dead forum? dead product?
Post Wed Jun 15, 2016 6:44 pm
So you have a bug in your wrapper, and you found a workaround. What support are you looking for. Who provided the wrapper?
Users browsing this forum: Baidu [Spider] and 23 guests
