Serviio Can't See/Be Seen Wired Setup
NuttBoxer
Post Sun Jun 12, 2016 11:22 pm
After I updated Serviio to 1.6 I was no longer able to see or be seen by my Blu-ray player. I have tried downgrading to 1.5.1, but the problem persists. I have opened ports, added multicasting support to Ubuntu, and bound the IP to the server's wired etho.
Hardware Setup:
Sony Blu-ray BDP-S3200 wired
Ubuntu Headless 14.04 Wired
ATT Pace 5031nv
Log Output:
2016-06-12 15:55:39,222 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2016-06-12 15:55:39,208 INFO [LibraryDeltaScanner] Starting the library delta scan
2016-06-12 15:55:39,208 INFO [LibraryDeltaScanner] Added repository '/media/storage/media' to delta scanner (NATIVE)
2016-06-12 15:55:37,582 INFO [LibraryDeltaScanner] Added repository '/media/storage/downloads' to delta scanner (NATIVE)
2016-06-12 15:55:37,397 INFO [LocalLibraryManager] Starting automatic library scan
2016-06-12 15:55:37,218 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2016-06-12 15:55:37,203 INFO [FeedUpdaterWorker] Started looking for information about online resources
2016-06-12 15:55:11,078 INFO [RendererSearchSender] Searching for Renderer devices
2016-06-12 15:55:11,074 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2016-06-12 15:55:11,073 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2016-06-12 15:55:11,066 INFO [EventDispatcher] Starting EventDispatcher
2016-06-12 15:55:11,066 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address (server ethernet IP), timeout = 0
2016-06-12 15:55:11,061 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2016-06-12 15:55:11,035 INFO [WebServer] WebServer starting on port 8895
2016-06-12 15:55:11,026 INFO [Device] Updated bound IP address of Device with UUID: 09a48b58-776e-306a-9e7c-0908fc46be05, bound address: (server ethernet IP)
2016-06-12 15:55:10,754 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-06-12 15:55:10,720 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
... 1 more
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.UNIXProcess.(UNIXProcess.java:248)
at java.lang.UNIXProcess.forkAndExec(Native Method)
Caused by: java.io.IOException: error=2, No such file or directory
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
java.io.IOException: Cannot run program "dcraw": error=2, No such file or directory
2016-06-12 15:55:10,703 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
2016-06-12 15:55:10,664 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
2016-06-12 15:55:10,558 INFO [UpdateChecker] Checking if a new version is available
2016-06-12 15:55:10,542 INFO [PluginCompilerThread] Started looking for plugins
2016-06-12 15:55:10,539 INFO [PluginCompilerThread] Looking for plugins at /etc/serviio/serviio-1.5.1/plugins
2016-06-12 15:55:10,424 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2016-06-12 15:55:10,423 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-06-12 15:55:10,422 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-06-12 15:55:10,421 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-06-12 15:55:10,415 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-06-12 15:55:10,414 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-06-12 15:55:10,413 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-06-12 15:55:10,409 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-06-12 15:55:10,408 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-06-12 15:55:10,407 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-06-12 15:55:10,401 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-06-12 15:55:10,291 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-06-12 15:55:10,290 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-06-12 15:55:10,289 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-06-12 15:55:10,285 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-06-12 15:55:10,284 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-06-12 15:55:10,283 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-06-12 15:55:10,282 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-06-12 15:55:10,281 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-06-12 15:55:10,280 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2016-06-12 15:55:10,272 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-06-12 15:55:10,269 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-06-12 15:55:10,267 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-06-12 15:55:10,266 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-06-12 15:55:10,265 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-06-12 15:55:10,262 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-06-12 15:55:10,258 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-06-12 15:55:10,257 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-06-12 15:55:10,256 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-06-12 15:55:10,255 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-06-12 15:55:10,254 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-06-12 15:55:10,253 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-06-12 15:55:10,252 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-06-12 15:55:10,251 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-06-12 15:55:10,250 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-06-12 15:55:10,250 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-06-12 15:55:10,247 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-06-12 15:55:10,245 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-06-12 15:55:10,244 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-06-12 15:55:10,244 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-06-12 15:55:10,236 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-06-12 15:55:10,233 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-06-12 15:55:10,228 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-06-12 15:55:10,226 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-06-12 15:55:10,225 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-06-12 15:55:10,223 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-06-12 15:55:10,222 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-06-12 15:55:10,221 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-06-12 15:55:10,219 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-06-12 15:55:10,207 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-06-12 15:55:10,203 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-06-12 15:55:10,202 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-06-12 15:55:10,198 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-06-12 15:55:10,193 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-06-12 15:55:10,189 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-06-12 15:55:10,187 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-06-12 15:55:10,185 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-06-12 15:55:10,178 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-06-12 15:55:10,155 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-06-12 15:55:09,981 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-06-12 15:55:09,195 INFO [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2016-06-12 15:55:08,634 INFO [Device] Created UPnP Device with UUID: 09a48b58-776e-306a-9e7c-0908fc46be05, bound address: (server ethernet IP)
2016-06-12 15:55:08,399 INFO [MediaServer] ------------------------------------------------------------------------
2016-06-12 15:55:08,399 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2016-06-12 15:55:08,398 INFO [MediaServer] ------------------------------------------------------------------------
2016-06-12 15:55:04,040 INFO [DatabaseManager] Using DERBY database language
2016-06-12 15:55:03,975 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-06-12 15:55:03,917 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2016-06-12 15:55:03,916 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2016-06-12 15:55:03,494 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2016-06-12 15:55:03,488 INFO [WebServer] Socket buffer set to 65535 bytes
2016-06-12 15:55:02,792 INFO [MediaServer] ------------------------------------------------------------------------
2016-06-12 15:55:02,792 INFO [MediaServer] Temp dir: /tmp
2016-06-12 15:55:02,792 INFO [MediaServer] User home dir: /root
2016-06-12 15:55:02,792 INFO [MediaServer] User: root
2016-06-12 15:55:02,792 INFO [MediaServer] Headless mode enabled: true
2016-06-12 15:55:02,542 INFO [MediaServer] File encoding: US-ASCII
2016-06-12 15:55:02,542 INFO [MediaServer] OS Linux 3.13.0-87-generic
2016-06-12 15:55:02,542 INFO [MediaServer] Java 1.8.0_91-Oracle Corporation amd64
2016-06-12 15:55:02,541 INFO [MediaServer] http://www.serviio.org
2016-06-12 15:55:02,541 INFO [MediaServer] Petr Nejedly 2009-2015
2016-06-12 15:55:02,541 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.1 (rev. 9d3f18af690f)
NuttBoxer
Post Mon Jun 13, 2016 9:21 pm
Re: Serviio Can't See/Be Seen Wired Setup
Doesn't answer the why, but thinking of adding a router and setting my modem as a bridge. The 5031nv doesn't have the Multicast options displayed, and I've seen several places that IGMP tends to be enabled by default by ATT. Disabling the 5031 and setting up a router with PFSense sounds like a better option. Especially since I've never really been happy with the options for ATT modem/routers. The password is exposed in plaintext on the homepage for anyone who can figure out your gateway, WTF!?
