Panasonic TX-L37E5B which profile
callen
Post Mon Jun 13, 2016 6:34 am
Please can anyone advise the correct profile to use with a Panasonic TX-L37E5B. I have not been able to find out the model year, although I believe the TX range is also known as TH in some countries.
Post Tue Jun 14, 2016 1:30 am
Re: Panasonic TX-L37E5B which profile
I believe it was a 2012 TV.
Use this post as a guide: viewtopic.php?f=13&t=12367&start=80#p86472 - so:
  1. Start with the Panasonic Viera (2013) profile and test a mainstream MP4 file (see that post for what I mean by "mainstream"). Also test AVI files if you have them.
  2. If the MP4 file doesn't play change to the 2011/12 profile and test an AVI file.
  3. If the AVI file doesn't play, change to the 2011 profile.
I think it will be 1 or 2.
Users browsing this forum: Baidu [Spider] and 20 guests
