Show only first VOB file in multiple VOB file set
MoonPie2000
Post Mon Mar 14, 2011 11:00 pm
It would be nice to allow a switch that would allow for only first VOB file to be shown / used to idenify a VOB file set. For instance I have a folder with a movie that has VTS_01_1.vob, VTS_01_2.vob, VTS_01_3.vob, etc. and they are all part of one movie. I only want the first VOB file to be shown but all vob files in the folder to play. Current situation is that either all files are shown creating multiple selections for same movie or If i hide all vob files except first everyting looks o.k. BUT only the first vob file plays - hidden files do not play. I do not want to combine vob files into one big vob file for compatablity reasons. Like for instance you could specifiy a top level folder that would filter only the first vob file found in any sub-folder for selection / metadata.
PeterB
Post Mon Mar 14, 2011 11:06 pm
Re: Show only first VOB file in multiple VOB file set
Moonpie,
You and I seem to share the same problem, too many vob's.
I think it would be easier to support the IFO file, that contains the info on all vob files and tells the player in what sequence they should be played. If the server would read and parse these IFO files, then the rest should follow automatically....at least I think it will...
Post Mon Mar 14, 2011 11:25 pm
create a ticket on bitbucket, will see when I get some time to implement it
Post Tue Mar 15, 2011 10:03 pm
jckonieczny
Post Mon Apr 04, 2011 4:23 pm
I found these instructions that were posted but I am unclear on how to only allow the first VOB for display / be used for metadat idnetification. How do I set this up?
Joe
Allow only first VOB file in a folder to display / be used for metadat idnetification. If you have a VOB file set i.e. VTS_01_1.vob, VTS_01_02.vob, VTS_01_3.vob, etc. that are all related to one movie only use the first .vob file for display / identificaiton purposes.
Post Mon Apr 04, 2011 4:31 pm
You can't do it presently, it's a feature request. Your only chance now is to join the VOBs to 1 (mpeg) file.
luna
Post Thu Apr 14, 2011 11:49 am
interesting for me, thanks
slingshot
Post Fri Apr 15, 2011 2:23 pm
I really would like this feature seen implemented
Post Mon May 16, 2011 9:56 am
See some link about DVD File structure,
By reading/parse IFO file, serviio could build the stream structure (chapters,etc.)
http://dvd.sourceforge.net/dvdinfo/
http://en.wikipedia.org/wiki/DVD-Video# ... _structure
Return to Feature requests
