JU7000 and 1.6.1 issues - external SRT and other problems
Morgh
Post Tue Jun 21, 2016 8:09 am
So I saw in console that a new version is available so I updated. Well this resulted in a few issues:
1) Subtitles present in the form of external files (SRT) were not being played
2) Movies were taking a LONG time to load up - after selecting content a "Loading" message would appear and it would last for ~3-5 minutes until a movie started playing - after the initial wait I could FF/RW the file without such long loadings, however should I close the file, selecting it again would mean another long load
3) After some time the TV would stop seeing the shared content - the "Serviio" source was available in the TV to choose, however "no content" was displayed. This could be remedied by unplugging the TV from wall socket and replugging - a bit tedious.
I've tried uninstalling together with registry cleaning - no success. Java reinstallation did not help either. All the issues seem to have subsided once I found a 1.6 installation package online.
Post Tue Jun 21, 2016 12:37 pm
Re: JU7000 and 1.6.1 issues - external SRT and other problem
Make sure the update didn't change the profile you have selected for your set. It usually doesn't, but I have seen it on rare occasions.
I haven't played much with my JU7100 since the version update. My wife usually uses the Sony BD player because the Samsung DLNA functionality isn't the greatest lately. It usually throws a connection error after the movie ends and the next one attempts to load. I know it's the Samsung's problem, as no other device does it. I'll try to remember to check it this week. I believe I have a couple of videos with SRT files so I'll check that as well.
Morgh
Post Wed Jun 22, 2016 4:01 pm
I did check this and even deleted the device and waited for it to be detected again. It was J-series in both cases and did not help a bit.
(everything still running smoothly with 1.6)
EDIT: Spoke too soon - the "no content" just happened again - this is so peculiar... it was working just a few hours ago - no changes were made, I can still select the Serviio media server in TV - it just appears to be completely empty (even the initial categories Image/Video/Audio is not displayed)
Simply unplugging TV from socket and replugging it resolved this issue...
I uploaded the LOG file (with detailed logging enabled - without the replugging part though).
serviio.zip
(28.77 KiB) Downloaded 679 times
Morgh
Post Wed Jun 22, 2016 5:31 pm
Uploaded Log file in the previous post. Can try to be of more help - just need to be told what to do ;)
mey-zing
Post Sat Jun 25, 2016 11:42 am
I also have the same 3 problems with a ju7500, so basically I stopped using serviio with this tv :(
Users browsing this forum: Baidu [Spider] and 15 guests
