HP Mediasmart TV
Puhac
Post Tue Jul 19, 2016 9:54 pm
HP Mediasmart TV
Hi there,
I have had good experiences in the past with Serviio, but unfortunately now some of my movies are grayed out on my TV. Not sure if it's the DLNA profile or not. I had it working, but my server crashed and upon installing the latest version it no longer worked.
Unfortunately I bought this HP TV which stopped being produced shortly after.
Any ideas?
http://www.newegg.com/Product/Product.a ... 6889241009
Post Tue Jul 19, 2016 10:09 pm
Re: HP Mediasmart TV
Yes, it's likely the profile. Have you tried others?
What type of movies (post MediaInfo details -see sig) and what profile are you using.
Puhac
Post Tue Jul 19, 2016 11:14 pm
DenyAll wrote:Yes, it's likely the profile. Have you tried others?
Thanks for the quick reply! I tried a couple others but really wasn't sure which direction to go with it. Is there a special restart that's needed from Serviio's side when you change a profile? A forum I read provided a profile for the HP Mediasmart TV, but unfortunately it's for Plex and not Serviio.
I have a range of different types of files, but somehow Serviio worked on all of them in the past.
Here is one that does work:
Format profile                           : Base Media
Codec ID                                 : isom (isom)
File size                                : 951 MiB
Duration                                 : 2 h 0 min
Overall bit rate                         : 1 099 kb/s
Encoded date                             : UTC 2015-10-22 20:51:14
Tagged date                              : UTC 2015-10-22 20:51:14
Xtra                                     : WM/MediaClassPrimaryID
Format settings, ReFrames                : 5 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 999 kb/s
Maximum bit rate                         : 4 826 kb/s
Height                                   : 536 pixels
Display aspect ratio                     : 2.40:1
Frame rate                               : 29.970 (30000/1001) FPS
Bits/(Pixel*Frame)                       : 0.049
Stream size                              : 864 MiB (91%)
Writing library                          : x264 core 146 r2538 121396c
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=999 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2015-10-22 20:50:53
Tagged date                              : UTC 2015-10-22 20:51:21
Color range                              : Limited
Codec ID                                 : 40
Source duration                          : 2 h 0 min
Bit rate                                 : 96.0 kb/s
Maximum bit rate                         : 136 kb/s
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 spf)
Stream size                              : 83.0 MiB (9%)
Source stream size                       : 83.0 MiB (9%)
Alternate group                          : 1
Here is one that does not work:
Format version                           : Version 4 / Version 2
File size                                : 1.45 GiB
Duration                                 : 2 h 7 min
Overall bit rate                         : 1 638 kb/s
Movie name                               :
Encoded date                             : UTC 2016-05-29 17:01:32
Writing application                      : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
Format settings, ReFrames                : 12 frames
Bit rate                                 : 1 480 kb/s
Height                                   : 536 pixels
Frame rate                               : 23.976 (24000/1001) FPS
Bits/(Pixel*Frame)                       : 0.090
Stream size                              : 1.27 GiB (87%)
Title                                    :
Writing library                          : x264 core 148 r2638 7599210
Encoding settings                        : cabac=1 / ref=12 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.07 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=1000 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=12 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1480 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : A_AAC
Bit rate                                 : 192 kb/s
Delay relative to video                  : 9 ms
Stream size                              : 174 MiB (12%)
Title                                    :
Text
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 1 h 55 min
Bit rate                                 : 12.1 kb/s
Count of elements                        : 2452
Stream size                              : 9.97 MiB (1%)
Title                                    :
And here is the profile that I was reading that might work. They say it's based off a Sony Bravia, but switching to that profile didn't change anything for me. Discussion: (Search for the word "HP") https://forums.plex.tv/discussion/73703/working-dlna-profiles/p2
Unfortunately, it's a different structure than that of Serviio.
<?xml version="1.0" encoding="utf-8"?>
<Client name="HP MediaSmart TV">
  <!-- Author: Plex Inc. based on original profile from Yardco -->
  <!-- http://kb.sony-europe.com/SRVS/CGI-BIN/WEBCGI.EXE?St=52,E=0000000000126930010,Key=6939,SXI=14,Case=obj(15280) -->
  <Identification>
    <Header name="X-AV-Client-Info" regex=".*KDL-\d{2}[EHLNPB]X\d[01]\d.*" />
    <DeviceDescription>
      <Manufacturer substring="Hewlett-Packard" />
      <FriendlyName regex="HP MediaSmart TV" />
    </DeviceDescription>
  </Identification>
  <ProtocolInfo>
    <Source>http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000</Source>
  </ProtocolInfo>
  <DeviceDescription>
    <ModelName>Windows Media Player Sharing</ModelName>
    <ModelNumber>3.0</ModelNumber>
    <ModelUrl>http://www.microsoft.com/</ModelUrl>
    <Manufacturer>Microsoft Corporation</Manufacturer>
    <ManufacturerUrl>http://www.microsoft.com/</ManufacturerUrl>
    <X-DlnaCap />
    <Sony-AggregationFlags>10</Sony-AggregationFlags>
  <Settings>
    <Setting name="AlbumArtPN" value="JPEG_TN" />
  </Settings>
  <TranscodeTargets>
    <VideoProfile container="mpegts" codec="h264" audioCodec="ac3">
      <Setting name="MpegtsM2tsMode" value="true" />
    </VideoProfile>
    <MusicProfile container="mp3" codec="mp3" />
    <PhotoProfile container="jpeg">
      <Setting name="ChromaSubsampling" value="4:2:2" />
    </PhotoProfile>
  </TranscodeTargets>
  <DirectPlayProfiles>
    <VideoProfile container="mpegts" codec="h264" audioCodec="ac3,aac,mp3" />
    <VideoProfile container="mpegts" codec="mpeg1video,mpeg2video" audioCodec="mp2,mp3" />
    <VideoProfile container="mpeg" codec="mpeg1video,mpeg2video" audioCodec="mp2,mp3" />
  </DirectPlayProfiles>
  <CodecProfiles>
    <VideoCodec name="*">
      <Limitations>
        <UpperBound name="video.width" value="1920" />
        <UpperBound name="video.height" value="1080" />
      </Limitations>
    </VideoCodec>
    <VideoCodec name="h264">
      <Limitations>
        <UpperBound name="video.frameRate" value="30" />
        <Match name="video.frameRateMode" value="cfr" />
        <UpperBound name="video.bitrate" value="20000" />
        <UpperBound name="video.level" value="41" />
      </Limitations>
    </VideoCodec>
    <VideoCodec name="mpeg2video">
      <Limitations>
      </Limitations>
    </VideoCodec>
    <VideoAudioCodec name="ac3">
      <Limitations>
        <UpperBound name="audio.channels" value="6" />
      </Limitations>
    </VideoAudioCodec>
    <VideoAudioCodec name="aac">
      <Limitations>
        <UpperBound name="audio.channels" value="2" />
        <NotMatch name="audio.profile" substring="he-aac" isRequired="false" /><!-- No he-aac -->
      </Limitations>
    </VideoAudioCodec>
  </CodecProfiles>
  <ContainerProfiles>
    <PhotoContainer name="*">
      <Limitations>
        <UpperBound name="media.width" value="1920" />
        <UpperBound name="media.height" value="1080" />
      </Limitations>
    </PhotoContainer>
  </ContainerProfiles>
  <DlnaMediaProfiles>
    <!-- These are from the Serviio profile. Thanks, Serviio -->
    <DlnaVideoProfile container="mpegts" codec="h264" audioCodec="ac3,aac,mp3" pn="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T" mimeType="video/vnd.dlna.mpeg-tts">
      <Limitations>
        <Match name="video.packetLength" value="192" />
        <Match name="video.timeStamp" value="1" />
      </Limitations>
    </DlnaVideoProfile>
    <DlnaVideoProfile container="mpegts" codec="h264" audioCodec="ac3,aac,mp3" pn="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO" mimeType="video/mpeg">
      <Limitations>
        <Match name="video.packetLength" value="188" />
      </Limitations>
    </DlnaVideoProfile>
    <DlnaVideoProfile container="mpegts" codec="h264" audioCodec="ac3,aac,mp3" pn="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU" mimeType="video/vnd.dlna.mpeg-tts" />
    <DlnaVideoProfile container="mpegts" codec="mpeg2video" pn="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO" mimeType="video/vnd.dlna.mpeg-tts" />
    <!-- These are inferred from the earlier PMS Bravia profile -->
    <DlnaVideoProfile container="mpeg" codec="mpeg1video,mpeg2video" pn="MPEG_PS_NTSC,MPEG_PS_PAL" mimeType="video/mpeg" />
  </DlnaMediaProfiles>
</Client>
Post Thu Jul 21, 2016 1:00 am
If you edit a profile, you need to either restart the Serviio service, or reboot the computer. If you are only selecting a different profile in the console, then you have to hit the save button twice (once when changing the profile, then again at the bottom of the Status page).
Puhac
Post Thu Jul 21, 2016 2:01 am
atc98092 wrote:If you edit a profile, you need to either restart the Serviio service, or reboot the computer. If you are only selecting a different profile in the console, then you have to hit the save button twice (once when changing the profile, then again at the bottom of the Status page).
Great, thanks for the explanation. Good news - I went and started some random testing (would've done that in the first place if I thought it made a difference) and Vizio TV appears to have worked! Now to remember this in the future incase I run into it again :)
Post Thu Jul 21, 2016 12:33 pm
If I remember correctly, the Vizio profile transcodes most videos. Your TV can probably play most of the videos without it, but I'd have to research it more.
I did a quick search and there doesn't seem to be much information available online about exactly what this TV supports. I did find this: http://support.hp.com/us-en/document/c00716154
    Audio Video Interleaved (avi)
    MPEG-1 (mp1, mpeg, mpg)
    MPEG-2 (mp2, mpeg, mpg)
    Microsoft Recorded TV Show (dvr-ms)
    Windows Media Video (wmv, wmv-hd)
    DivX
Music/Audio
    MP3 (mp3)
    PCM (pcm)
    WAV (wav)
    Windows Media Audio (wma, wma-pro)
One major red flag is that it doesn't list AC3 as a supported audio stream. This seems very strange, as AC3 is the audio type used by broadcast TV.
Return to User experiences
Users browsing this forum: No registered users and 144 guests
