No srt external subtitles on Samsung 55JU6700
Post Fri Jul 22, 2016 1:02 pm
Re: No srt external subtitles on Samsung 55JU6700
I did try a video I have with an SRT file, and no I did not see any captions. So I confirm the problem with version 1.6.1. I know it worked in the past, but can't say when it changed. I only have one video with a captions file, and don't watch it that often.
Although I just checked my console and I see I do not have burned in subs enabled. I'll change that and try it again.
EDIT: nope, still nothing. Although, Zip, it appears to work on the current beta.
Firoj
Post Wed Nov 17, 2021 9:52 pm
The log shows the subtiutle has been found, the TV requested it and Serviio served it successfully.
https://19216801.onl/ https://routerlogin.uno/
If it doesn't show, it's either a bug in the TV's firmware (try to update) or the subtitle file is corrupted.
Previous
