Samsung TV/Serviio Sound problem
blanaboo
Post Mon Aug 08, 2016 12:39 pm
HeyHo
I have a problem with my DLNA Streaming System.
I have a Serviio Server that streams all the movies via Gigabyte Ethernet to my Samsung Smart TV (UE48H). The Samsung Smart TV is connected with a Yamaha rx v 475 via an optical Audio cable. The Serviio Audio Settings are set to keep the original Sound of the Movie. And the audio output of the Samsung TV ist configured to Stream PCM to the Yamaha avr. Furthermore i selected the Samsung H Series as the transcoding Profile for Serviio.
The problem that I have is that every Audio Signal that reaches the avr is only Stereo although most of the movies have a proper 5.1 Audio stream. I guess that it might be the Samsung TV which is downmixing the audio signal. I've googled the Problem and noticed that this problem is known by a few other People. But they can't figure out a proper Solution.
Do you have any idea how to solve this problem?
Greetings
Blanaboo
PS: Sorry for my english... Its late and I'm from Germany so English is not my Mother tongue :)
Gesendet von meinem ONE A2003 mit Tapatalk
Post Mon Aug 08, 2016 3:36 pm
Re: Samsung TV/Serviio Sound problem
Many TVs will not send 5.1 sound out the optical cable from a non-TV source. This means that a Smart TV with its own apps (such as Netflix) will send 5.1 out the audio. But other apps, and external devices plugged into the TV will only send PCM stereo.
Now, my JU will send 5.1 audio out from the DLNA, but I've seen other models and brands that won't. Check your TV audio settings again and see if there's a bitstream out option, rather than PCM. If mine is set to PCM, I also only get stereo.
blanaboo
Post Mon Aug 08, 2016 6:15 pm
HeyHo
Thank you for your quick answer... I have this options in my Audio settings: PCM, DTS, DTS 2:5 and DD. The thing is that depending on the incoming Stream not all of them are available available. Only PCM is available in with every Stream.
Which one is the best to select and which one is created by the Samsung TV in an "artificial" way?!
Greetings
Blanaboo
Post Mon Aug 08, 2016 6:58 pm
Samsung handles audio very poorly. I too have issues with it not switching correctly between DD and DTS, and it often defaults back to PCM. As I mentioned, PCM only comes out in 2 channel stereo. They need a true bitstream option that completely ignores what the incoming audio stream is and just send it through as a raw bitstream to the AVR. Other brands seem to be able to do it, but not Samsung.
I don't want my TV doing anything to the audio. Just pass it through!
blanaboo
Post Mon Aug 08, 2016 7:21 pm
I think we have a small misunderstanding ;)
DD and DTS works as a path through as well or does the TV Change the audio Signal if I select one of those.
blanaboo
Post Mon Aug 08, 2016 8:01 pm
blanaboo wrote:I think we have a small misunderstanding ;)
The Definition of true Bitstream is not clear for me :)
Post Mon Aug 08, 2016 8:57 pm
The TV is supposed to recognize DD or DTS and automatically send it out via bitstream, without altering the stream. If you select PCM or DTS 2:5, the TV modifies the audio stream. What I mean by true bitstream is that it completely ignores what the audio stream is and just send it back out via ARC or the optical connection. But the Samsung doesn't have that option.
On my TV, the audio menu has two separate submenus to choose the audio processing. One has the choices you list (PCM, DD, etc.), while the other shows bitstream and other options (not at home so can't remember exactly what it has). However, both submenus should have the option to select bitstream, which would tell the TV to ignore whatever is contained in the audio stream and send it out. When the TV detects there is an AVR connected, this should be the default. If the sound is going to the TV speakers, then the internal processing is necessary, since the TV does not contain 5.1 speakers (only stereo).
And yes, the TV will alter the audio signal based on the selection you make in that particular submenu. When bitstream is selected in the other menu, it should send them through without altering. However, I have seen many times that the TV changes itself to PCM, which decodes everything to 2 channel stereo.
blanaboo
Post Tue Aug 09, 2016 3:27 am
Okay thank you! I will try to figure out the best solution later basing on the information that you gave to me.. :D
blanaboo
Post Tue Aug 09, 2016 2:02 pm
HeyHo,
so my Samsung TV doesn't has a bitstream option for the audio out signal. But i think i can avoid the issue if i use my Playstation 4 as the dlna client. I've already tested it. I set DTS (bitstream) as the audio output format. Well it works! ;) But now i have another problem. A lot of my movies were recorded with a TechniSat Receiver and afterwards saved in a *.TS file. But the Playstation 4 with the Playstation 4 Profile which is selected in the Serviio Server Console is not able to play the file/movie. I've read about different issues with the ps4 profile and a lot of testing and profile information but i haven't found anything about the described problem. I'll post a detailed serviio log later so you maybe can help me to figure out the problem.
Thanks for all the help!
Greetings
blanaboo
PS: Should i post this in the Sony section? :oops:
EDIT:
2016-08-09 17:07:50,055 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,055 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,088 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,098 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,099 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,099 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:50,105 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:50,109 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:53459: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:50,109 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,110 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,112 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,112 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:50,112 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,112 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,113 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,116 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:50,116 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,116 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,118 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,119 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,119 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,120 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,124 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,131 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,132 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,132 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:50,134 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:50,141 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:53301: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:50,141 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,158 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,160 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,160 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:50,160 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,160 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,163 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,164 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:50,165 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,165 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,166 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,168 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,169 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,169 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,169 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,185 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,185 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,186 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:50,188 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:50,193 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:53184: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:50,194 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,195 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,195 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,195 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:50,196 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,196 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,196 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,197 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:50,198 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,198 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,199 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,200 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,200 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,200 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,203 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,206 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,206 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,207 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:51,546 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:51,625 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:52637: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Connection: Keep-Alive,transferMode.dlna.org: Streaming,Range: bytes=0-,Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4)]]
2016-08-09 17:07:51,626 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,627 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,628 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,629 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:51,629 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,629 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,630 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,631 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:51,632 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,632 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,633 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,635 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,635 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:51,635 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:51,636 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:51,649 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:51,649 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:51,650 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Content-Range: bytes 0-2525855669/2525855670,Date: Tue, 09 Aug 2016 15:07:51 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:51,665 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:51,674 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:51964: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=2523758518-,Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:51,674 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,677 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,677 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:51,678 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,678 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,679 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,680 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:51,683 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,684 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,685 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,686 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,686 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:51,687 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:51,688 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:51,699 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:51,699 DEBUG [GETMethodProcessor] Stream entity has length: 2097152
2016-08-09 17:07:51,700 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2097152,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Content-Range: bytes 2523758518-2525855669/2525855670,Date: Tue, 09 Aug 2016 15:07:51 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:51,740 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:65097: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=0-,Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:51,742 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,757 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,759 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,759 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:51,760 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,760 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,761 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,764 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:51,765 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,765 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,767 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,768 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,768 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:51,768 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:51,769 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:51,782 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:51,782 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:51,783 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Content-Range: bytes 0-2525855669/2525855670,Date: Tue, 09 Aug 2016 15:07:51 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:54,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:07:54,427 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.37:50261s
2016-08-09 17:07:58,885 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2016-08-09 17:07:58,885 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2016-08-09 17:08:06,720 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:08:08,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:13,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:18,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:23,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:26,939 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 1312d000-0040-1000-8e48-5056bf5c368b from address 192.168.178.4
2016-08-09 17:08:26,940 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 1312d000-0040-1000-8e48-5056bf5c368b from address 192.168.178.4
2016-08-09 17:08:26,940 DEBUG [RendererManager] Removing renderer 1312d000-0040-1000-8e48-5056bf5c368b from list of active renderers
2016-08-09 17:08:28,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:32,273 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.94:57454s
2016-08-09 17:08:34,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:39,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:44,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:49,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:51,331 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.66:63346s
2016-08-09 17:08:54,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:58,908 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2016-08-09 17:08:58,913 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2016-08-09 17:09:08,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:08,043 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:13,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:13,041 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:18,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:18,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:23,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:23,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:25,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.178.75:47134s
2016-08-09 17:09:25,043 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.178.75:47134s
2016-08-09 17:09:25,043 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.178.75:35354s
2016-08-09 17:09:25,044 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.178.75:35354s
2016-08-09 17:09:28,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:28,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:34,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:37,533 DEBUG [PlaylistDAOImpl] Reading all Playlists
2016-08-09 17:09:39,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:44,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:49,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:54,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:54,424 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.37:50261s
2016-08-09 17:09:58,952 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2016-08-09 17:09:58,952 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
blanaboo
Post Tue Aug 09, 2016 3:24 pm
I#ve edited the other post and added a part of the log text. I hope it is the right one. :oops:
Just a guess: Maybe the error occurs because the files end with *.TS . I have other ones which are ending with *.ts and they are working/playing fine?!
Post Tue Aug 09, 2016 4:01 pm
That is also my solution, to use my Sony BD player instead of the Samsung client. :D
I'm not familiar at all with the PS4, so can't offer any suggestions there.
blanaboo
Post Tue Aug 09, 2016 4:35 pm
Okay :D
Do you know someone who is familiar with the ps4? Otherwise i would just post this issue in the Sony section again. Or can someone move it?!
Furthermore i tried to do the ffmpeg.exe -i command but i got this massage back:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\Leon Filme\SD\Ghetto Gangz - Die
Hölle vor Paris"
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
E:\Leon Filme\SD\Ghetto Gangz - Die H├Âlle vor Paris: No such file or directory
I changed the name of the file because it obviously has a problem with the "ö" :D The next result was:
Hoelle vor Paris"
E:\Leon Filme\SD\Ghetto Gangz - Die Hoelle vor Paris: Permission denied
Is this the way this command is supposed to work or is there another Error that occurs(permission?!)?
Greetings
boo
Post Tue Aug 09, 2016 5:21 pm
Is your E: drive mapped to another computer, or is it a local drive? In theory a mapped drive could have a permissions issue, but since you're running it from your user account that shouldn't be an issue.
I notice that you aren't showing the full file name, so that could be an issue. Remember that by default Windows hides the file extension of known types (which I can't stand), so there should be a file extension on the file name when you use ffmpeg. I don't know if it's MPG or TS or MKV or whatever, but I'm pretty sure that ffmpeg needs the complete name.
blanaboo
Post Tue Aug 09, 2016 6:29 pm
Okay I've added the filename with extension ;)
Hoelle vor Paris\27.01.2012 22_53 Ghetto Gangz - Die Hoelle vor Paris.TS"
[mpeg2video @ 01BBC3E0] Invalid frame dimensions 0x0.
    Last message repeated 9 times
[mpegts @ 01BB5E60] PES packet size mismatch
    Last message repeated 1 times
Input #0, mpegts, from 'E:\Leon Filme\SD\Ghetto Gangz - Die Hoelle vor Paris\27.
01.2012 22_53 Ghetto Gangz - Die Hoelle vor Paris.TS':
  Duration: 01:32:35.47, start: 64200.948211, bitrate: 3637 kb/s
  Program 12003
  Program 12004
  Program 12005
  Program 12006
  Program 12020
    Stream #0:0[0xa6]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
(tv), 720x576 [SAR 64:45 DAR 16:9], max. 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50
 tbc
    Stream #0:1[0x80](ger): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo
, s16p, 192 kb/s (clean effects)
    Stream #0:2[0x44](ger): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
  Program 12030
  Program 12040
  Program 12041
  Program 12060
  Program 12061
  Program 12080
  Program 12090
  Program 12095
is this better than the previous one?
Greetings
blanaboo
Edit: And yes it is a local hard drive. The problem was that I only listed the folder but not the specific file with its extension ;)
Users browsing this forum: No registered users and 57 guests
