Serviigo and VLC android app Galaxy S5 not working
Troutking
Post Mon Jul 11, 2016 8:46 pm
On my galaxy s5, I can no longer choose VLC as the default player. When I choose to play a file it goes online and starts my browser. What the F!? In settings I can choose to force internal player, but that one will only play in landscape mode. What the hell has happened? Is it because of the android 6.0.1 upgrade/ver.?
TV: Samsung UE40C8705
FW: T-VALDEUC-3007.1
Troutking
Post Wed Jul 13, 2016 11:54 am
Re: Serviigo and VLC android app Galaxy S5 not working
No one got a clue as at what is happening here? Why is it starting my browser and asking if I want to download a file. Why can't I choose VLC as a default player. Everything is working perfectly on my galaxy note 2014 edition, that isn't running 6xx android, so that's a difference.
Troutking
Post Thu Jul 21, 2016 8:43 pm
Is it supposed to be like this with this version of Android? If so, to me, a borderline useless app...
Troutking
Post Fri Aug 12, 2016 10:55 am
Is this going to be fixed or not?
Post Tue Aug 16, 2016 12:46 pm
Best ask in the ServiiGo thread. viewtopic.php?f=17&t=6803
fmustang76
Post Tue Aug 30, 2016 2:10 pm
This may or may not help, but it sounds like at some point you may have accidentally set your "browser" as the default app for the file type that you are trying to open through ServiiGo. I've used the same setup with Android 6.0.1 on my family's S5's and the ServiiGo app without the problem you are describing. But I have seen that problem with other file types and other programs on Android and had to clear the defaults to correct it.
I would suggest clearing the defaults for the browser that opens when you try to play a file. You could also clear the defaults for the VLC app as well as the ServiiGo app if that doesn't resolve the problem. Afterward, setting ServiioGo to "force external player" should give you the option to pick a player app such as VLC and set that app as the default app when you next try to play a file.
https://www.google.com/search?q=S5+clear+default+apps
Another thing to try if the above doesn't work is either clearing the ServiiGo app data or uninstalling the ServiiGo app to clear it. Then reinstall and trying again.
https://www.google.com/search?q=S5+clear+app+data
Let us know if that helps.
Troutking
Post Mon Sep 05, 2016 9:33 pm
fmustang76 wrote:This may or may not help, but it sounds like at some point you may have accidentally set your "browser" as the default app for the file type that you are trying to open through ServiiGo.
That was the problem and solution. Thank you very much.
