PS4 Profile problem
blanaboo
Post Wed Aug 17, 2016 8:38 am
PS4 Profile problem
HeyHo
I have a problem with my Sony Playstation 4 Profile of my Serviio Server. I have some *.TS Files which are not playable with the PS4. Please write me what Information you need to figure out a solution. Furthermore i am not sure about the right Audio Out Settings at the ps4 which is linked with an Yamaha AVR. At this Moment i use the DTS (Bitstream) Output option.
Greetings Blanaboo
PS: Sorry for my english. I am from Germany :)
blanaboo
Post Thu Aug 18, 2016 7:14 am
Re: PS4 Profile problem
Hello again,
does this help you?
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\Leon Filme\SD\Ghetto Gangz - Die
Hoelle vor Paris\27.01.2012 22_53 Ghetto Gangz - Die Hoelle vor Paris.TS"
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
[mpeg2video @ 01BBC3E0] Invalid frame dimensions 0x0.
    Last message repeated 9 times
[mpegts @ 01BB5E60] PES packet size mismatch
    Last message repeated 1 times
Input #0, mpegts, from 'E:\Leon Filme\SD\Ghetto Gangz - Die Hoelle vor Paris\27.
01.2012 22_53 Ghetto Gangz - Die Hoelle vor Paris.TS':
  Duration: 01:32:35.47, start: 64200.948211, bitrate: 3637 kb/s
  Program 12003
  Program 12004
  Program 12005
  Program 12006
  Program 12020
    Stream #0:0[0xa6]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
(tv), 720x576 [SAR 64:45 DAR 16:9], max. 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50
 tbc
    Stream #0:1[0x80](ger): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo
, s16p, 192 kb/s (clean effects)
    Stream #0:2[0x44](ger): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
  Program 12030
  Program 12040
  Program 12041
  Program 12060
  Program 12061
  Program 12080
  Program 12090
  Program 12095
2016-08-09 17:07:50,055 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,055 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,088 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,098 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,099 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,099 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:50,105 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:50,109 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:53459: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:50,109 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,110 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,112 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,112 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:50,112 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,112 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,113 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,116 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:50,116 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,116 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,118 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,119 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,119 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,120 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,124 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,131 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,132 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,132 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:50,134 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:50,141 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:53301: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:50,141 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,158 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,160 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,160 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:50,160 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,160 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,163 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,164 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:50,165 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,165 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,166 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,168 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,169 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,169 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,169 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,185 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,185 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,186 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:50,188 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:50,193 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:53184: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:50,194 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,195 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:50,195 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,195 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:50,196 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,196 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,196 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,197 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:50,198 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:50,198 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:50,199 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:50,200 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:50,200 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:50,200 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:50,203 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:50,206 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:50,206 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:50,207 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Date: Tue, 09 Aug 2016 15:07:50 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:51,546 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:51,625 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:52637: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Connection: Keep-Alive,transferMode.dlna.org: Streaming,Range: bytes=0-,Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4)]]
2016-08-09 17:07:51,626 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,627 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,628 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,629 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:51,629 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,629 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,630 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,631 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:51,632 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,632 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,633 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,635 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,635 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:51,635 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:51,636 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:51,649 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:51,649 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:51,650 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Content-Range: bytes 0-2525855669/2525855670,Date: Tue, 09 Aug 2016 15:07:51 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:51,665 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:07:51,674 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:51964: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=2523758518-,Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:51,674 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,676 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,677 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,677 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:51,678 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,678 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,679 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,680 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:51,683 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,684 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,685 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,686 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,686 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:51,687 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:51,688 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:51,699 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:51,699 DEBUG [GETMethodProcessor] Stream entity has length: 2097152
2016-08-09 17:07:51,700 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2097152,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Content-Range: bytes 2523758518-2525855669/2525855670,Date: Tue, 09 Aug 2016 15:07:51 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:51,740 DEBUG [ServiioHttpService] Incoming request from /192.168.178.130:65097: GET /resource/1056/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=0-,Host: 192.168.178.100:8895,User-Agent: MediaPlayer/2.00 libhttp/3.55 (PlayStation 4),Connection: Keep-Alive]]
2016-08-09 17:07:51,742 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,757 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.178.130
2016-08-09 17:07:51,759 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,759 DEBUG [ResourceDeliveryProcessor] Request for resource 1056 and type 'MEDIA_ITEM' received
2016-08-09 17:07:51,760 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,760 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,761 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,764 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1056, format MPEG_TS_SD_EU_ISO and profile Playstation 4
2016-08-09 17:07:51,765 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1056 (local)
2016-08-09 17:07:51,765 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1056)
2016-08-09 17:07:51,767 DEBUG [VideoDAOImpl] Reading a Video (id = 1056)
2016-08-09 17:07:51,768 DEBUG [VideoDeliveryEngine] Delivering item '1056' for client 'Identifier=192.168.178.130, Profile=Playstation 4'
2016-08-09 17:07:51,768 DEBUG [VideoDeliveryEngine] Delivering file '27.01.2012 22_53 Ghetto Gangz - Die Hölle vor Paris.TS' in native format
2016-08-09 17:07:51,768 DEBUG [MediaItemDAOImpl] Getting file of media item 1056
2016-08-09 17:07:51,769 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1056) as read
2016-08-09 17:07:51,782 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2016-08-09 17:07:51,782 DEBUG [GETMethodProcessor] Stream entity has length: 2525855670
2016-08-09 17:07:51,783 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 2525855670,Content-Type: video/mpeg,Cache-control: no-cache,Connection: keep-alive,Content-Range: bytes 0-2525855669/2525855670,Date: Tue, 09 Aug 2016 15:07:51 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.6.1,transferMode.dlna.org: Streaming]]
2016-08-09 17:07:54,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:07:54,427 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.37:50261s
2016-08-09 17:07:58,885 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2016-08-09 17:07:58,885 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2016-08-09 17:08:06,720 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2016-08-09 17:08:08,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:13,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:18,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:23,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:26,939 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 1312d000-0040-1000-8e48-5056bf5c368b from address 192.168.178.4
2016-08-09 17:08:26,940 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 1312d000-0040-1000-8e48-5056bf5c368b from address 192.168.178.4
2016-08-09 17:08:26,940 DEBUG [RendererManager] Removing renderer 1312d000-0040-1000-8e48-5056bf5c368b from list of active renderers
2016-08-09 17:08:28,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:32,273 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.94:57454s
2016-08-09 17:08:34,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:39,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:44,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:49,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:51,331 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.66:63346s
2016-08-09 17:08:54,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:08:58,908 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2016-08-09 17:08:58,913 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2016-08-09 17:09:08,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:08,043 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:13,034 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:13,041 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:18,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:18,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:23,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:23,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:25,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.178.75:47134s
2016-08-09 17:09:25,043 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.178.75:47134s
2016-08-09 17:09:25,043 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.178.75:35354s
2016-08-09 17:09:25,044 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.178.75:35354s
2016-08-09 17:09:28,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:28,042 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:avm-aha:1 from address /192.168.178.1:60855s
2016-08-09 17:09:34,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:37,533 DEBUG [PlaylistDAOImpl] Reading all Playlists
2016-08-09 17:09:39,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:44,035 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:49,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:54,036 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:l2tpv3:1 from address /192.168.178.121:52430s
2016-08-09 17:09:54,424 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:dial-multiscreen-org:service:dial:1 from address /192.168.178.37:50261s
2016-08-09 17:09:58,952 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2016-08-09 17:09:58,952 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Greetings Blanaboo
Post Thu Aug 18, 2016 7:51 am
Looks like a problem in the file itself.
Try remuxing the file. This is a non-destructive process than may fix the issue. To do so, from the command window in the folder where your file is located, type:
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "oldfilename.ts" -c copy -map 0 -f mpegts "newfilename.ts"
or use my WinHelper program (see signature).
If remuxing doesn't fix it, then you will likely need to re-encode the video. Serviio could transcode these files if needed, however you will end up transcoding all mpegts files (including any good ones).
blanaboo
Post Thu Aug 18, 2016 9:10 am
HeyHo Thank you for your quick response.
C:\>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "E:\Leon Filme\SD\Ghetto Gangz
- Die Hoelle vor Paris\27.01.2012 22_53 Ghetto Gangz - Die Hoelle vor Paris.ts"
-c copy -map 0 -f mpegts "Ghetto Gangz.ts"
[mpeg2video @ 0003C860] Invalid frame dimensions 0x0.
[mpegts @ 01BBC2A0] PES packet size mismatch
01.2012 22_53 Ghetto Gangz - Die Hoelle vor Paris.ts':
  Program 12003
  Program 12004
  Program 12005
  Program 12006
  Program 12020
 tbc
  Program 12030
  Program 12040
  Program 12041
  Program 12060
  Program 12061
  Program 12080
  Program 12090
  Program 12095
Output #0, mpegts, to 'Ghetto Gangz.ts':
    encoder         : Lavf56.14.100
    Stream #0:0: Video: mpeg2video ([2][0][0][0] / 0x0002), yuv420p, 720x576 [SA
R 64:45 DAR 16:9], q=2-31, max. 15000 kb/s, 25 fps, 90k tbn, 25 tbc
    Stream #0:1(ger): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, 192
    Stream #0:2(ger): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
  Stream #0:2 -> #0:2 (copy)
frame= 1211 fps=0.0 q=-1.0 size=   25583kB time=00:00:49.07 bitrate=4270.7kbits/
frame= 1710 fps=1671 q=-1.0 size=   39952kB time=00:01:09.03 bitrate=4741.0kbits
frame= 2346 fps=216 q=-1.0 size=   57689kB time=00:01:34.47 bitrate=5002.4kbits/
frame= 3117 fps=275 q=-1.0 size=   80666kB time=00:02:05.31 bitrate=5273.4kbits/
frame= 4492 fps=379 q=-1.0 size=  114025kB time=00:03:00.31 bitrate=5180.4kbits/
frame= 5910 fps=478 q=-1.0 size=  148313kB time=00:03:57.03 bitrate=5125.8kbits/
frame= 6918 fps=533 q=-1.0 size=  171282kB time=00:04:37.35 bitrate=5059.1kbits/
frame= 8247 fps=612 q=-1.0 size=  201742kB time=00:05:30.51 bitrate=5000.3kbits/
frame= 9746 fps=698 q=-1.0 size=  234435kB time=00:06:30.47 bitrate=4918.4kbits/
frame=10569 fps=731 q=-1.0 size=  254548kB time=00:07:03.39 bitrate=4925.1kbits/
frame=11845 fps=791 q=-1.0 size=  284306kB time=00:07:54.43 bitrate=4909.1kbits/
frame=13099 fps=846 q=-1.0 size=  317767kB time=00:08:44.59 bitrate=4962.2kbits/
frame=14511 fps=907 q=-1.0 size=  354332kB time=00:09:41.07 bitrate=4995.4kbits/
frame=16149 fps=979 q=-1.0 size=  396414kB time=00:10:46.59 bitrate=5022.4kbits/
frame=17361 fps=1022 q=-1.0 size=  420259kB time=00:11:35.07 bitrate=4953.1kbits
frame=18841 fps=1077 q=-1.0 size=  456440kB time=00:12:34.27 bitrate=4957.3kbits
frame=20333 fps=1130 q=-1.0 size=  494457kB time=00:13:33.95 bitrate=4976.5kbits
frame=21337 fps=1154 q=-1.0 size=  521613kB time=00:14:14.11 bitrate=5002.9kbits
frame=23087 fps=1216 q=-1.0 size=  560432kB time=00:15:24.11 bitrate=4968.1kbits
frame=25037 fps=1278 q=-1.0 size=  600759kB time=00:16:42.11 bitrate=4911.0kbits
frame=26415 fps=1314 q=-1.0 size=  633985kB time=00:17:37.23 bitrate=4912.5kbits
frame=27816 fps=1351 q=-1.0 size=  673834kB time=00:18:33.27 bitrate=4958.4kbits
[mpegts @ 01BBC2A0] DTS 5912605819 < 5912609419 out of order
[mpegts @ 03711E40] Non-monotonous DTS in output stream 0:0; previous: 101522880
, current: 101519280; changing to 101522881. This may result in incorrect timest
amps in the output file.
[mpegts @ 03711E40] Application provided invalid, non monotonically increasing d
ts to muxer in stream 2: 101491200 >= 101491200
av_interleaved_write_frame(): Invalid argument
frame=28187 fps=1359 q=-1.0 Lsize=  682604kB time=00:18:48.07 bitrate=4957.0kbit
s/s
video:559405kB audio:26415kB subtitle:39270kB other streams:0kB global headers:0
kB muxing overhead: 9.200942%
Conversion failed!
C:\>
this is the Result of the Command Line. I tested the WinHelper program as well but i doesn't work either :(
Any ideas/suggestions?
Greetings Blanaboo
EDIT: Transcoding is enabled in Serviio anyway: Delivery -> Transcoding -> |X| Enable transcoding <- should i change this?
Post Thu Aug 18, 2016 1:16 pm
The source file has out-of-order time stamps. Not sure how to fix that but perhaps someone on the forum could help. Perhaps try this:
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "oldfilename.ts" -c:v copy -c:a copy -f mpegts "newfilename.ts"
That will strip the subtitles out (I don't think they are the issue but test anyway, you never know). If that doesn't work try re-encoding the video (this should be the correct command line, I can't test):
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "oldfilename.ts" -c copy -c:v mpeg2video -qscale:v 2 -f mpegts "newfilename.ts"
If still no go, I'm going to have to defer to others.
No, don't change your Serviio settings. They are correct.
Users browsing this forum: No registered users and 69 guests
