General questions and folder not showing up.
g12345567
Post Fri Jul 29, 2011 3:59 am
I am running serviio to stream media via wired DLNA to my Sony BDP-S370 (Australian Version with latest firmware).
1) Is the S370 able to display subtitles and access chapter points embedded in x264 MKV video files? I see it can access multiple audio streams no problem. When playing media over DLNA?
2) Serviio is not displaying all the shared folders containing videos. I have a couple of folders containing MKV videos that are not showing up. All the new files and filders I have added since, show up.
Post Fri Jul 29, 2011 10:33 am
Re: General questions and folder not showing up.
g12345567 wrote:I am running serviio to stream media via wired DLNA to my Sony BDP-S370 (Australian Version with latest firmware).
Chapter selection is not support over DLNA, and external subtitles are limited to only certain file types (embedded subtitles will not work).
please provide " FFmpeg -i " details on the files that wont play ( see signiture for howto )
g12345567
Post Fri Jul 29, 2011 12:35 pm
Re: General questions and folder not showing up [SOLVED]
There is 1 folder containing 2 MKV file that does not show up when I access the shared folders on the Sony blu-ray player.
The original mkv file is 10gb. with 1 audio track and 19 subtitles.
I worked out the file was not loading/showing up because it contained too many subtitles. I used MKVTOOLS to strip out all the unwanted subtitles and just leave english. Now the MKV file shows up on the S370, but is recognised as DIVX with a * (star symbol) next to it. So I used another utility called "MKV WD Fix" to fix the corrupt header in the MKV. File now recognised as MT2S and plays fine.
The reason for the file to loading: Too many Subtitles
Reason for file not being recognised correctly: Corrupt Header
Post Fri Jul 29, 2011 12:37 pm
I worked out the file was not loading/showing up because it contained too many subtitles. I used MKVTOOLS to strip out all the unwanted subtitles and just leave english. Now the MKV file shows up on the S370, but is recognised as DIVX with a * (star symbol) next to it. And will not play.
All my other MKV files show up as M2TS in serviio on the S370.
ok that was not what i asked for, please follow teh below quote.
Post Fri Jul 29, 2011 2:27 pm
g12345567 wrote:I used MKVTOOLS to strip out all the unwanted subtitles and just leave english. Now the MKV file shows up on the S370, but is recognised as DIVX with a * (star symbol) next to it. So I used another utility called "MKV WD Fix" to fix the corrupt header in the MKV. File now recognised as MT2S and plays fine.
Very interesting fix.
I'll have a look at these "MKV WD Fix" Tool.
g12345567
Post Fri Jul 29, 2011 11:45 pm
MKV header removal compression
http://www.bunkus.org/videotools/mkvtoolnix/faq.html#header_removal_compression
The MKV WD FIX tool v0.1.2 can be used to fix header compression in MKV files.
http://www.chumpusrex.com/junk/MKVFix.exe (requires MKVtoolnix 4.3.0)
http://www.bunkus.org/videotools/mkvtoolnix/win32/ (all windows versions)
or MKVtoolnix utility
http://wdtvforum.com/main/index.php?topic=6897.30
hasenfuss
Post Wed Aug 24, 2016 3:06 pm
Hello all,
I have a similar problem.
Since a long time, I had no problem with files with the type "mkv".
Suddenly it does not work any more.
Not all mkv-files but a lot.
It is a file recordet at TV.
I got the error-message:
2016-08-21 17:25:24,442 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (C:\linkdir\Serien\Satire\Extra 3\2016 08-17 22-40-01 NDR FS HH HD (AC3,deu) extra 3 extra 3 Satiresendung.mkv). Message: Unknown video file type.
The output of the ffmpeg - command is:
C:\linkdir\Serien\Satire\Extra 3>
C:\linkdir\Serien\Satire\Extra 3>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i "2016 08-17 22-40-01 NDR FS HH HD (AC3,deu) extra 3 extra 3 Satiresendung.mkv"
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
libavutil 54. 14.100 / 54. 14.100
libavcodec 56. 12.101 / 56. 12.101
libavformat 56. 14.100 / 56. 14.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
Input #0, matroska,webm, from '2016 08-17 22-40-01 NDR FS HH HD (AC3,deu) extra 3 extra 3 Satiresendung.mkv':
encoder : Haali DirectShow Matroska Muxer 1.13.138.14
creation_time : 2016-08-21 10:20:22
Duration: 00:28:55.46, start: 0.000000, bitrate: 7955 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 1k tbn, 100 tbc
title : PID 5221 Video
Stream #0:1(deu): Audio: ac3, 48000 Hz, stereo, fltp, 448 kb/s (default)
title : AC3
Could you help?
Regards
Hasenfuss
Serviio on Windows 8.1 pro
Intel Dualcore-Processor
Users browsing this forum: Google [Bot] and 7 guests
