Install Serviio at QNAP TS-439 Pro II Turbo NAS
albertoto
Post Sun Mar 07, 2010 10:02 am
Hello everyone.
I have read the topic about the installing a Serviio at WD My Book World and I am in similar situation.
I'm also amazed by this media server. It's great, simple, good, easy ,.... and works great (installed on my Windows XP based laptop) with my Oppo BDP-83.
My NAS - QNAP TS-439 Pro (Intel CPU) has preinstalled Twonky Media Server. But during a playback of mkv movie files from Twonky, my Oppo BDP-83 after few minutes stops the playback and skips to the folloowing media file. :( Streaming from Serviio (at laptop) is absolutely correct and reliable.
That is reason why I would like to install Serviio to my Linux based QNAP TS-439. I tried it following your instructions but I was unsuccesful. (Sorry, I am an analphabet in Linux ...). I do not know which Linux distribution is installed on NAS.
QNAP TS-439 is able to install a "qpkg" packages through a web-based administration of NAS.
Is it possible to find somewhere the "qpkg" release of linux install package?
Can somebody help me, please?
Peter
Post Sun Mar 07, 2010 10:52 am
Re: Install Serviio at QNAP TS-439 Pro II Turbo NAS
I did a quick search and found this: http://forum.qnap.com/viewtopic.php?p=1 ... 7d0f75dd27
You will need to:
1. install Java 6 on it via the link above
2. open ssh connection to the NAS (do a search for how to do it, you can probably use Putty terminal)
3. see if there is ffmpeg intalled, if not install it (not sure how, try google)
4. upload Seviio.tar.gz, unzip it in the terminal and follow Linux instructions on how to run it
Hope this helps
albertoto
Post Thu Apr 01, 2010 2:17 pm
I asked my friends for help.
Result:
1.Java is running.
2. OK
3.FFmpeg is installed
4.Serviio is installed and running on my Linux NAS server
My Oppo BDP-83 can see the Serviio on NAS :-) ... but without the shared files.
Question is: How can I add a folders for sharing in linux release (Windows release is user friendly and easy)?
I did not find the possibitily in profile.xml and log4j.xml files.
Other people have the same problem on Linux, as I saw in other topics on this forum.
OR: How can I run Serviio console on WinXP laptop and connect it to Serviio on linux NAS server?
Peter
Post Fri Apr 02, 2010 7:24 am
well done.
You have to conect to your Linux Serviio server from a remote console. So you have to install Serviio on another (e.g. Windows) machine, disable the Windows service there (as you will only need the console from that installation) and follow this:
http://www.serviio.org/component/content/article/21#q2
and if you have problems here:
viewtopic.php?f=5&t=142&start=10#p873
There is an outstanding bug still that will not enable you to actually add any folder that doesn't exist on the local (Windows) machine. This is fixed in 0.4. PM me to participate in the beta testing and I'll send you the beta when it's available.
albertoto
Post Sat Apr 03, 2010 10:03 am
Thanks for information.
I tried to connect the Serviio console running on Windows machine to the Seviio server running on Linux NAS according to yor advice...I was unsuccessful (sorry I am the linux analphabet :-) ).
I added the IP adress of NAS to the hosts file, but I did not understand where I have to change the right paths in Serviio.Console.exe vmoptions and Seviio.Console.bat on windows machine and in serviio-console.sh file on linux server.
If I was successful it does not solve the problem of adding any folder on server...
My result is that I must wait for 0.4 release.
Send me the 0.4 beta please. I'll try test it.
Peter
Post Sun Apr 04, 2010 8:11 am
You have to add
-Dserviio.corbaHost=<ip_address_of_your_NAS>
to Serviio.Console.exe.vmoptions and retart the Console. That should be enough. If it doesn't start post logs from both machines (debug on).
albertoto
Post Sun Apr 04, 2010 10:26 am
Yesss, it is running. Thanks. I can add paths in Serviio Console running on the Windows machine and I can see these paths on Oppo BDP-83 from Serviio service runnig on linux NAS.
But I am not able to see any multimedia files on linux server in added paths. I tried to add various ways of absolute and relative paths in Serviio console.
I think, it is the issue you wrote on Friday.
albertoto
Post Fri May 21, 2010 4:04 pm
zip wrote:You have to add
I have installed Serviio release 0.4 on linux server and also on WinXP laptop.
I added the line -Dserviio.corbaHost=<real_ip_address_of_my_NAS> into Serviio.Console.exe.vmoptions file.
But, after restart, Console is writing the Error message: "Cannot connest to Serviio server, it does not seem to be running. Exiting...". But the Serviio is running on my linux NAS (I can see it on my home network).
Have you any ideas for me, please?
I do not understand it, the release 0.3.1 was running correctly.
In serviio.log file are following lines:
2010-05-22 11:11:31,140 INFO [ServiioConsole] Starting Serviio Console
2010-05-22 11:11:34,250 ERROR [ServiioConsole] Cannot connect to the server because of remote exception: CORBA COMM_FAILURE 1398079689 No; nested exception is: org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 201 completed: No
2010-05-22 11:11:39,640 INFO [ServiioConsole] Leaving Serviio Console
2010-05-22 11:14:20,187 INFO [ServiioConsole] Starting Serviio Console
2010-05-22 11:14:22,468 ERROR [ServiioConsole] Cannot connect to the server because of remote exception: CORBA COMM_FAILURE 1398079689 No; nested exception is: org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 201 completed: No
2010-05-22 11:14:28,906 INFO [ServiioConsole] Leaving Serviio Console
Peter
Post Sun May 23, 2010 9:55 am
NOt sure what it might be. Is it the same behaviour when you do Windows - Windows?
albertoto
Post Sun May 23, 2010 11:10 am
zip wrote:NOt sure what it might be. Is it the same behaviour when you do Windows - Windows?
Windows (Console)<->Windows(Service) is OK.
Windows (Console)<->Linux (Service) is NOT ok. I started the ServiioService on Linux first. When I want to start the Console on Windows, the reported error message occures.
The line "-Dserviio.corbaHost=192.168.2.9" in Serviio.Console.exe.vmoptions file (on Windows machine) is OK?
I saw the line: "-Xmx384m" in "Serviio.Service.exe.vmoptions" file. It is something new in comparison with 0.3.1 release. Is it OK?
Is there necessary to change similar parameters on linux machine?
Post Sun May 23, 2010 9:49 pm
Ok, I found a bug in 0.4. Will be fixed in 0.4.1. You might try to get around it by adding these to your server .sh amont other "-D" parameters:
-Dorg.omg.CORBA.ORBInitialPort=23423 -Dorg.omg.CORBA.ORBInitialHost=<your_server_ip>
albertoto
Post Tue May 25, 2010 5:25 pm
zip wrote:Ok, I found a bug in 0.4. Will be fixed in 0.4.1. You might try to get around it by adding these to your server .sh amont other "-D" parameters:
I added the line into serviio.sh file.
My linux NAS responses:
-Dorg.omg.CORBA.ORBInitialPort=23423: command not found
In techspecs I found that the QNAP TS-439 Pro II has the operating system - Embedded Linux
Post Tue May 25, 2010 8:58 pm
post your serviio.sh
albertoto
Post Thu May 27, 2010 1:44 pm
I have added the parameters into serviio.sh file on linux server.
# Setup Serviio specific properties
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dorg.omg.CORBA.ORBInitialPort=23423 -Dorg.omg.CORBA.ORBInitialHost=192.168.2.9"
Serviio service is running on linux server again. The line "-Dserviio.corbaHost=192.168.2.9" also exists in Serviio.Console.exe.vmoptions file on Windows machine.
But .. the Console on Windows machine is still unable to connect the Serviio server, the error message is the same: "Cannot connest to Serviio server, it does not seem to be running. Exiting..."
Post Thu May 27, 2010 1:58 pm
Hmm, you'll have to wait for 0.4.1 I'm affraid. Send me a PM and I'll send you a beta to try it out.
albertoto
Post Sun Jun 20, 2010 7:52 am
I had small problems with starting of 0.4.1 release on linux server but it is OK now. It is working with console on winXP machine well.
Great job, Petr. Thanks.
albertoto
Post Sat Jun 26, 2010 9:45 pm
Hi, I have bought new Mac with OS10.6. The OSX release was downloaded and unpacked.
I opened the Servio-Console.app and changed the Info.plist file, with
<key>-Dserviio.corbaHost</key>
<string>192.168.2.9</string>
as follows:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<plist version="1.0">
  <dict>
    <key>CFBundleName</key>
    <string>Serviio-Console</string>
    <key>CFBundleShortVersionString</key>
    <string>0.4.1</string>
    <key>CFBundleGetInfoString</key>
    <string>0.4.1 (c) 2009 - 2010 Petr Nejedly</string>
    <key>CFBundleAllowMixedLocalizations</key>
    <string>false</string>
    <key>CFBundleInfoDictionaryVersion</key>
    <string>6.0</string>
    <key>CFBundleExecutable</key>
    <string>JavaApplicationStub</string>
    <key>CFBundleDevelopmentRegion</key>
    <string>English</string>
    <key>CFBundlePackageType</key>
    <string>APPL</string>
    <key>CFBundleSignature</key>
    <string>????</string>
    <key>CFBundleIconFile</key>
    <string>serviio.icns</string>
    <key>Java</key>
    <dict>
      <key>MainClass</key>
      <string>org.serviio.console.ServiioConsole</string>
      <key>JVMVersion</key>
      <string>1.6+</string>
      <key>ClassPath</key>
      <array>
        <string>$JAVAROOT/jul-to-slf4j.jar</string>
        <string>$JAVAROOT/log4j.jar</string>
        <string>$JAVAROOT/serviio-client.jar</string>
        <string>$JAVAROOT/serviio.jar</string>
        <string>$JAVAROOT/slf4j-api.jar</string>
        <string>$JAVAROOT/slf4j-log4j12.jar</string>
        <string>$JAVAROOT/config</string>
      </array>
      <key>Properties</key>
      <dict>
        <key>serviio.home</key>
        <string>$JAVAROOT</string>
        <key>java.net.preferIPv4Stack</key>
        <string>true</string>
      </dict>
    </dict>
  </dict>
</plist>
But I am unable to connect the console running on OSX with Serviio service running on Linux machine. The error message occures: "Cannot connect to Serviio server, it does not seem to be running . Exiting..." (i.e. it is similar like my previous problem with console on winXP and service on linux machine).
Was my change of Info.plist correct or I made something wrong?
Thanks for response in advance.
P.
Post Sat Jun 26, 2010 10:07 pm
Remove the -D like this:
<key>serviio.corbaHost</key>
albertoto
Post Mon Jun 28, 2010 9:38 pm
Yess, It is running. Thanks a lot.
albertoto
Post Sat Sep 18, 2010 8:14 pm
I have upgraded the 0.4.2 release.
In my remote console on Mac OSX machine I changed in Info.plist file as follows:
<key>serviio.remoteHost</key>
<string>XXX.XXX.X.X</string>
but the Console is still unable to connect the Serviio server, the error message is the same: "Cannot connest to Serviio server, it does not seem to be running. Exiting..."
I changed also the serviio.sh file on my Linux server for Serviio service, as follows:
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dserviio.remoteHost=XXX.XXX.X.X"
But the result is the same.
Have you any advice for me, please?
Users browsing this forum: Baidu [Spider] and 19 guests
