Can't add file: error never seen before
Post Mon Sep 05, 2016 2:10 am
OK, I've never seen this error in the log before. The movie was added with no issue originally, then I used Handbrake to convert the file from MKV to MP4 and burn the subs into the video. The file plays without issue in VLC or the Windows 10 video player. However, Serviio now reports the following error:
WARN [MediaFileIndexer] Cannot add file The Martian.mp4 because of an unexpected error. Message: For input string: "max. 200"
There's no metadata contained within the file itself, so I have no idea where the max. 200 error is coming from. I've tried a couple of different ways to name the file with no change. Here's the MediaInfo readout from the file:
Complete name                            : F:\Video_4\The Martian.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (isom/iso2/avc1/mp41)
File size                                : 9.30 GiB
Duration                                 : 2 h 21 min
Overall bit rate                         : 9 401 kb/s
Movie name                               : The Martian
Encoded date                             : UTC 2016-09-04 20:48:58
Tagged date                              : UTC 2016-09-04 20:48:58
Writing application                      : HandBrake 0.10.5 2016021100
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 4 390 kb/s
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Variable
Frame rate                               : 23.976 (24000/1001) FPS
Minimum frame rate                       : 23.810 FPS
Maximum frame rate                       : 24.390 FPS
Bits/(Pixel*Frame)                       : 0.119
Stream size                              : 4.34 GiB (47%)
Writing library                          : x264 core 142 r2479 dd79a61
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color range                              : Limited
Menus                                    : 3
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Mode                                     : 16
Codec ID                                 : A9
Bit rate mode                            : Variable / Constant
Bit rate                                 : Unknown / 1 509 kb/s
Channel(s)_Original                      : 8 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 spf)
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Stream size                              : 4.94 GiB (53%)
Title                                    : Surround / Surround
Alternate group                          : 1
Menus                                    : 3
Menu
Codec ID                                 : text
Menu For                                 : 1,2
00:00:00.000                             : Chapter 1
00:03:22.410                             : Chapter 2
00:10:08.691                             : Chapter 3
00:15:24.757                             : Chapter 4
00:18:25.354                             : Chapter 5
00:21:34.585                             : Chapter 6
00:24:28.175                             : Chapter 7
00:28:52.856                             : Chapter 8
00:31:36.728                             : Chapter 9
00:34:21.184                             : Chapter 10
00:39:13.601                             : Chapter 11
00:41:21.854                             : Chapter 12
00:46:23.614                             : Chapter 13
00:49:25.212                             : Chapter 14
00:56:15.914                             : Chapter 15
00:59:40.577                             : Chapter 16
01:02:23.990                             : Chapter 17
01:06:53.301                             : Chapter 18
01:09:53.147                             : Chapter 19
01:13:51.385                             : Chapter 20
01:18:38.380                             : Chapter 21
01:22:52.551                             : Chapter 22
01:30:41.436                             : Chapter 23
01:37:30.261                             : Chapter 24
01:43:32.164                             : Chapter 25
01:46:16.370                             : Chapter 26
01:50:18.945                             : Chapter 27
01:54:08.133                             : Chapter 28
01:57:49.520                             : Chapter 29
02:04:41.766                             : Chapter 30
02:11:05.816                             : Chapter 31
02:13:28.959                             : Chapter 32
Bit rate mode                            : VBR
Post Mon Sep 05, 2016 8:54 am
Re: Can't add file: error never seen before
Can you post ffmpeg -i for the file pls?
Post Mon Sep 05, 2016 5:57 pm
Here ya go...
F:\Video_4>ffmpeg -i "the martian (2015).mp4
ffmpeg version N-81516-gbe07c25 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 5.4.0 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-libebur128 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib
  libavutil      55. 29.100 / 55. 29.100
  libavcodec     57. 54.101 / 57. 54.101
  libavformat    57. 48.101 / 57. 48.101
  libavdevice    57.  0.102 / 57.  0.102
  libavfilter     6. 58.100 /  6. 58.100
  libswscale      4.  1.100 /  4.  1.100
  libswresample   2.  1.100 /  2.  1.100
  libpostproc    54.  0.100 / 54.  0.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'the martian (2015).mp4':
    major_brand     : mp42
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    creation_time   : 2016-09-04T20:48:58.000000Z
    title           : The Martian
    encoder         : HandBrake 0.10.5 2016021100
  Duration: 02:21:37.58, start: 0.000000, bitrate: 9401 kb/s
    Chapter #0:0: start 0.000000, end 202.410000
      title           : Chapter 1
    Chapter #0:1: start 202.410000, end 608.691000
      title           : Chapter 2
    Chapter #0:2: start 608.691000, end 924.757000
      title           : Chapter 3
    Chapter #0:3: start 924.757000, end 1105.354000
      title           : Chapter 4
    Chapter #0:4: start 1105.354000, end 1294.585000
      title           : Chapter 5
    Chapter #0:5: start 1294.585000, end 1468.175000
      title           : Chapter 6
    Chapter #0:6: start 1468.175000, end 1732.856000
      title           : Chapter 7
    Chapter #0:7: start 1732.856000, end 1896.728000
      title           : Chapter 8
    Chapter #0:8: start 1896.728000, end 2061.184000
      title           : Chapter 9
    Chapter #0:9: start 2061.184000, end 2353.601000
      title           : Chapter 10
    Chapter #0:10: start 2353.601000, end 2481.854000
      title           : Chapter 11
    Chapter #0:11: start 2481.854000, end 2783.614000
      title           : Chapter 12
    Chapter #0:12: start 2783.614000, end 2965.212000
      title           : Chapter 13
    Chapter #0:13: start 2965.212000, end 3375.914000
      title           : Chapter 14
    Chapter #0:14: start 3375.914000, end 3580.577000
      title           : Chapter 15
    Chapter #0:15: start 3580.577000, end 3743.990000
      title           : Chapter 16
    Chapter #0:16: start 3743.990000, end 4013.301000
      title           : Chapter 17
    Chapter #0:17: start 4013.301000, end 4193.147000
      title           : Chapter 18
    Chapter #0:18: start 4193.147000, end 4431.385000
      title           : Chapter 19
    Chapter #0:19: start 4431.385000, end 4718.380000
      title           : Chapter 20
    Chapter #0:20: start 4718.380000, end 4972.551000
      title           : Chapter 21
    Chapter #0:21: start 4972.551000, end 5441.436000
      title           : Chapter 22
    Chapter #0:22: start 5441.436000, end 5850.261000
      title           : Chapter 23
    Chapter #0:23: start 5850.261000, end 6212.164000
      title           : Chapter 24
    Chapter #0:24: start 6212.164000, end 6376.370000
      title           : Chapter 25
    Chapter #0:25: start 6376.370000, end 6618.945000
      title           : Chapter 26
    Chapter #0:26: start 6618.945000, end 6848.133000
      title           : Chapter 27
    Chapter #0:27: start 6848.133000, end 7069.520000
      title           : Chapter 28
    Chapter #0:28: start 7069.520000, end 7481.766000
      title           : Chapter 29
    Chapter #0:29: start 7481.766000, end 7865.816000
      title           : Chapter 30
    Chapter #0:30: start 7865.816000, end 8008.959000
      title           : Chapter 31
    Chapter #0:31: start 8008.959000, end 8497.447000
      title           : Chapter 32
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x800 [SAR 1:1 DAR 12:5], 4390 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 180k tbc (default)
      handler_name    : VideoHandler
    Stream #0:1(eng): Audio: dts (DTS-HD MA) (mp4a / 0x6134706D), 48000 Hz, 7.1, s32p (24 bit) (default)
      handler_name    : Surround
    Stream #0:2(eng): Subtitle: mov_text (text / 0x74786574)
      handler_name    : SubtitleHandler
Post Mon Sep 05, 2016 7:47 pm
Are you sure ot's the same file? The file name is different to the one in the log.
Post Mon Sep 05, 2016 8:05 pm
zip wrote:Are you sure ot's the same file? The file name is different to the one in the log.
Yep, same file. I tried removing and adding the year to the file name, just to see if that changed anything. It didn't.
Here's the ffmpeg info for the original file, before using Handbrake. This one is added to the database without issue.
ffmpeg -i "the martian (2015).mkv"
[matroska,webm @ 00000000001965e0] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[matroska,webm @ 00000000001965e0] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle): unspecified size
[matroska,webm @ 00000000001965e0] Could not find codec parameters for stream 6 (Subtitle: hdmv_pgs_subtitle): unspecified size
Input #0, matroska,webm, from 'the martian (2015).mkv':
    title           : The Martian
    encoder         : libmakemkv v1.10.1 (1.3.3/1.4.4) win(x64-release)
    creation_time   : 2016-09-01T19:34:31.000000Z
  Duration: 02:21:37.57, start: 0.000000, bitrate: 33801 kb/s
    Chapter #0:0: start 0.000000, end 202.285417
      title           : Chapter 01
    Chapter #0:1: start 202.285417, end 608.608000
      title           : Chapter 02
    Chapter #0:2: start 608.608000, end 924.590333
      title           : Chapter 03
    Chapter #0:3: start 924.590333, end 1105.187417
      title           : Chapter 04
    Chapter #0:4: start 1105.187417, end 1294.376417
      title           : Chapter 05
    Chapter #0:5: start 1294.376417, end 1468.091625
      title           : Chapter 06
    Chapter #0:6: start 1468.091625, end 1732.689292
      title           : Chapter 07
    Chapter #0:7: start 1732.689292, end 1896.644750
      title           : Chapter 08
    Chapter #0:8: start 1896.644750, end 2061.100708
      title           : Chapter 09
    Chapter #0:9: start 2061.100708, end 2353.434417
      title           : Chapter 10
    Chapter #0:10: start 2353.434417, end 2481.770958
      title           : Chapter 11
    Chapter #0:11: start 2481.770958, end 2783.530750
      title           : Chapter 12
    Chapter #0:12: start 2783.530750, end 2965.087125
      title           : Chapter 13
    Chapter #0:13: start 2965.087125, end 3375.747375
      title           : Chapter 14
    Chapter #0:14: start 3375.747375, end 3580.493583
      title           : Chapter 15
    Chapter #0:15: start 3580.493583, end 3743.823417
      title           : Chapter 16
    Chapter #0:16: start 3743.823417, end 4013.134125
      title           : Chapter 17
    Chapter #0:17: start 4013.134125, end 4192.980458
      title           : Chapter 18
    Chapter #0:18: start 4192.980458, end 4431.301875
      title           : Chapter 19
    Chapter #0:19: start 4431.301875, end 4718.255208
      title           : Chapter 20
    Chapter #0:20: start 4718.255208, end 4972.467500
      title           : Chapter 21
    Chapter #0:21: start 4972.467500, end 5441.269167
      title           : Chapter 22
    Chapter #0:22: start 5441.269167, end 5850.094250
      title           : Chapter 23
    Chapter #0:23: start 5850.094250, end 6211.997458
      title           : Chapter 24
    Chapter #0:24: start 6211.997458, end 6376.286583
      title           : Chapter 25
    Chapter #0:25: start 6376.286583, end 6618.737125
      title           : Chapter 26
    Chapter #0:26: start 6618.737125, end 6847.966125
      title           : Chapter 27
    Chapter #0:27: start 6847.966125, end 7069.312250
      title           : Chapter 28
    Chapter #0:28: start 7069.312250, end 7481.682542
      title           : Chapter 29
    Chapter #0:29: start 7481.682542, end 7865.732875
      title           : Chapter 30
    Chapter #0:30: start 7865.732875, end 8008.792458
      title           : Chapter 31
    Chapter #0:31: start 8008.792458, end 8497.572417
      title           : Chapter 32
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
      BPS-eng         : 26800140
      DURATION-eng    : 02:21:37.572416666
      NUMBER_OF_FRAMES-eng: 203738
      NUMBER_OF_BYTES-eng: 28467014912
      SOURCE_ID-eng   : 001011
      _STATISTICS_WRITING_APP-eng: MakeMKV v1.10.1 win(x64-release)
      _STATISTICS_WRITING_DATE_UTC-eng: 2016-09-01 19:34:31
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
    Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s32p (24 bit) (default)
      title           : Surround 7.1
      BPS-eng         : 4997359
      DURATION-eng    : 02:21:37.578666666
      NUMBER_OF_FRAMES-eng: 796648
      NUMBER_OF_BYTES-eng: 5308181300
      SOURCE_ID-eng   : 001100
    Stream #0:2(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s
      title           : Surround 5.1
      BPS-eng         : 1509000
      NUMBER_OF_BYTES-eng: 1602855776
    Stream #0:3(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s
      BPS-eng         : 448000
      DURATION-eng    : 02:21:37.600000000
      NUMBER_OF_FRAMES-eng: 265550
      NUMBER_OF_BYTES-eng: 475865600
      SOURCE_ID-eng   : 001101
    Stream #0:4(eng): Subtitle: hdmv_pgs_subtitle
      BPS-eng         : 43483
      DURATION-eng    : 02:15:59.296979166
      NUMBER_OF_FRAMES-eng: 4290
      NUMBER_OF_BYTES-eng: 44349734
      SOURCE_ID-eng   : 001200
    Stream #0:5(eng): Subtitle: hdmv_pgs_subtitle
      BPS-eng         : 24098
      DURATION-eng    : 00:00:47.735187500
      NUMBER_OF_FRAMES-eng: 24
      NUMBER_OF_BYTES-eng: 143795
      SOURCE_ID-eng   : 001205
    Stream #0:6(eng): Subtitle: hdmv_pgs_subtitle
      BPS-eng         : 24098
Post Mon Sep 05, 2016 8:34 pm
Did you try with the 1.7 beta? The same result?
Post Mon Sep 05, 2016 10:06 pm
zip wrote:Did you try with the 1.7 beta? The same result?
No, but I'll copy it to my test server and see. I'll let ya know!
Nope, same error message...
Post Wed Sep 07, 2016 10:00 pm
which metadata source are you using? online, xbmc, ?
Post Thu Sep 08, 2016 12:21 am
Using online metadata.
I'm out of town until Friday, so any further testing has to wait until I get home.
