ReMux .MKV to .TS to preserve multi audio
PeterB
Post Tue Mar 15, 2011 10:13 pm
Hi All,
I have had some succes in remuxing a .MKV into a .TS with tSMuxer. The end resulting .TS file played through Serviio and contained both Dolby Digital Audio Streams the original MKV had.
The streams were also selectable in the Panasonic Option Button Menu during playback of the movie.
As DTS seems not to be supported, perhaps it is possible to create a profile which will convert all possible streams ina MKV into Dolby Digital before packing it all into a .TS
I am now testing the same file with adding subtitles to it to see if the Panasonic will also allow me to select multiple subtitle streams.
If it works then we can pack MKV into .TS and preserve all DD audio streams and subttitles ;)
Cheers,
Peter
Post Tue Mar 15, 2011 11:14 pm
Re: ReMux .MKV to .TS to preserve multi audio
Serviio will currently only use the first audio stream (as defined by FFmpeg)
AlD
Post Fri Mar 18, 2011 9:32 pm
Hi Peter,
could you provide some details on the steps you took to convert the .mkv to a file playable on a Panasonic Viera device?
I tried this script and tinkered with it, but had no success so far.
Thanks in advance!
Cheers, Daniel
Post Sat Mar 19, 2011 8:16 am
AlD wrote:Hi Peter,
Thanks in advance!
Cheers, Daniel
ZIP please correct me if im wrong but MKV file will play on the panasonic if they use the correct profile wont they or have we still not got enough information to make a decent working panasonic profile ???
AlD
Post Sat Mar 19, 2011 6:31 pm
Well, I have the device profile set to "Panasonic Viera" in serviio 0.5.1, but I just get a "file type not supported" when trying to play an mkv on the TV.
Post Sat Mar 19, 2011 6:44 pm
I'm not sure to be honest ;-) post ffmpeg -i for the mkv you cannot play
AlD
Post Sat Mar 19, 2011 6:51 pm
OK, I don't want to "hijack" the thread ;-) but here goes:
FFmpeg version SVN-r25767, Copyright (c) 2000-2010 the FFmpeg developers
built on Jan 29 2011 19:47:43 with gcc 4.5.2
configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --enable-static --enable-shared --cc=x86_64-pc-linux-gnu-gcc --enable-gpl --enable-version3 --enable-postproc --enable-avfilter --disable-stripping --disable-debug --disable-doc --disable-network --disable-vaapi --disable-static --disable-vdpau --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --disable-indev=oss --disable-indev=jack --enable-x11grab --disable-outdev=oss --enable-pthreads --enable-librtmp --enable-libschroedinger --disable-altivec --cpu=host --enable-hardcoded-tables
libavutil 50.33. 0 / 50.33. 0
libavcore 0.13. 0 / 0.13. 0
libavcodec 52.96. 0 / 52.96. 0
libavformat 52.84. 0 / 52.84. 0
libavdevice 52. 2. 2 / 52. 2. 2
libavfilter 1.62. 0 / 1.62. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0x158c510] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 24.00 (24/1)
Input #0, matroska,webm, from 'Bored.To.Death.S02E06.720p.HDTV.x264.mkv':
Duration: 00:26:43.55, start: 0.000000, bitrate: 384 kb/s
Stream #0.0: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s
Stream #0.1(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 24 tbr, 1k tbn, 47.95 tbc
Post Sun Mar 20, 2011 11:16 am
The profile specifies remuxing MKV with H264 to mpegts with ac3. Your file should be compatible, unless it's profile/level is too high (you could find that in Media Info). Do all your mkv files fail to play or is this the only one?
AlD
Post Sun Mar 20, 2011 11:41 am
The behaviour is consistent with all of my MKVs, i.e. none of them play.
Post Sun Mar 20, 2011 12:02 pm
can you post detailed log of when you try to play the file?
AlD
Post Sun Mar 20, 2011 7:50 pm
Sure thing.
serviio.log.txt
(5.06 KiB) Downloaded 1069 times
Post Sun Mar 20, 2011 7:55 pm
Please, could you post MediaInfo result of your file too?
AlD
Post Sun Mar 20, 2011 8:17 pm
Sure, here you go.
For what it's worth, I'm also attaching a log excerpt of a working mpeg file.
serviio-working-mpeg.log.txt
(3.84 KiB) Downloaded 984 times
mediainfo.txt
(2.66 KiB) Downloaded 1054 times
Post Mon Mar 21, 2011 10:09 am
Panasonic renderers only supports
- AVC/H264 with x264 core >61 revision. --> x264 core 85 r1442tw : OK
- H264 High@Level < 4.1 --> High@L3.1 : OK
Seems good, could you provide mkvinfo of you mkv file? I'll looking at header compression issue.
AlD
Post Mon Mar 21, 2011 7:04 pm
Ok, mkvinfo, here it is:
mkvinfo.txt
(1.47 KiB) Downloaded 967 times
Post Mon Mar 21, 2011 7:25 pm
AlD wrote:Ok, mkvinfo, here it is:
Thanks, there were no header compression.
Sorry but, no more ideas...
PeterB
Post Sat Mar 26, 2011 3:02 pm
AlD wrote:Hi Peter,
Thanks in advance!
Cheers, Daniel
Daniel,
I first remuxed the MKV into a .TS ( so Servioo ) did not have to do it.
When the MKV has multiple Dolby Digital tracks in it and you convert it into a .TS then the file should allow you to play either stream.
No luck thusfar with subtitles as the subtitles used in normal .TS streams by Tv stations are ofthen way different from what we are using.
klaus
Post Tue Jan 10, 2012 9:48 pm
If anybody is interested, I made this minimalistic ffmpeg wrapper, to support multiple audio tracks while transcoding or just remuxing:
#!/bin/bash
argv=("$@")
argc=${#argv[@]}
j=0
map[0]="0:v:0"      # 1st map: 1st video track
map[1]="0:a"      # 2nd map: all audio tracks
for (( i=0 ; i<argc ; i++ )); do
    case "${argv[i]}" in
   "-map" ) argv[i+1]=${map[j++]} ;;
    esac
done
/opt/ffmpeg/bin/ffmpeg "${argv[@]}"
Works fine with serviio 0.6.1 & ffmpeg 0.9.1.
Return to Panasonic
