WebUI versions
Swoop
Post Sun Aug 25, 2013 4:19 pm
WebUI versions
Hi all,
to have a better overview on which WebUI version works for which Serviio version, please have a look at the below:
Works with Serviio v1.5 (https://github.com/SwoopX/Web-UI-for-Serviio/archive/Serviio-1.5.zip)
1.6.4- 04/17/2015
- Fixed add/remove bug for libraries
1.6.3- 02/09/2015
- Fixed burned-in subtilte select box
- Added path selection dialog
- Added row style for render and library tab
1.6.2- 01/29/2015
- FINALLY fixed license upload bug
- Removed obsolete ServiiDB related code
- Changed start/stop server button behavior
- Fixed access display in library tab
- Fixed rating filter selection
- Removed obsolete code
1.6.1 - 01/21/2015
- Fixed setting of video rating
- Corrected removal of scanForUpdates from SharedFolder object
1.6 - 12/22/2014
- Updated to work with Serviio 1.5
Works with Serviio v1.3, 1.3.1 and 1.4 (https://github.com/SwoopX/Web-UI-for-Serviio/archive/Serviio-1.4.zip)
1.5.5 - 10/31/2014
- Fixed license upload
- NIC is now automatically selected if not chosen specifically
- Number of cores now automatically determined if not chosen specifically
- Multilanguage updates
- Preparations for Serviio API update
1.5.4 - 01/20/2014
- Corrected function name
- Changed dialog size for Serviidb
- Fixed resource type for OS
- Serviidb OS item are now enabled by default
- Fixed a bug where scrollbar is not clickable in certain tables in Chrome
- Selectable event is now canceled on iPhone switch on status tab
- Deleted obsolete code which interfered with iPhone switch
1.5.3 - 01/06/2014
- Video now again preselected while adding new online sources
- Removed redundant code
- Rewritten major parts of code
- Added button to check stream URL while adding or editing online sources
- Fixed bug for not providing parameters for REST API call postAction
- Updated page icon
- Improved error handling and error information output
- Fixed metadata rescan and library refresh
- Fixed refresh button in status tab
- Names of online sources can now contain characters like ' < > &
- Updated to jQuery 1.9.1
- Updated datatables and ColVis to latest nightly builds
- Fix a bug where ocasionally a selected local folder cannot be added or a wrong selection dialog might appear
- Updated Serviio version check
- Added page reload after OS import and license upload
- Revised style of renderers, local and online sources table to implement scrollbar
- Changed license upload method
- Changed filename for exported online sources
- Minor other bug fixes
Works with Serviio v1.3 and 1.3.1 (https://github.com/SwoopX/Web-UI-for-Serviio/archive/Serviio-1.3.zip)
1.5b1 - 07/31/2013
- Updated to work with Serviio 1.3 (Import/Export of online sources not yet implemented)
- Log file can now be browsed
- Retrieve metadata now clickable when adding new sources
- Switched metadata and delivery tab
- Updated display string for access levels
- ServiiDroid icons are now used
- Updated layout of online sources table (ServiiLink not yet working)
1.5 - 08/25/2013
- Implemented and activated functionality to import/export online resources
- Minor corrections and updates
- Updated language files
- Fixed parser errors in presentation and logs tab
- Fixed variable naming in presentation tab which lead to parser error during save
- ServiiLink icon click now displays ServiiLink
- Updated logfile cookie lifetime
1.5.1 - 09/02/2013
- Changed style of online sources table to implement scrollbar
- Changed file extension from .soe to .sob for online sources backup
- Corrected icon size in library tab
1.5.2 - 11/17/2013
- Status tab: Renderers are now selected by corresponding line instead of checkbox
- Status tab: Fixed renderer removal in free version of Serviio
- Delivery tab: Fixed display of number of used CPU cores
- Logs tab: Fixed refresh button (applies for free version of Serviio)
- Library tab: Fixed erroneous access restriction behaviour
- Library tab: Fixed visibility of feed expiry interval
Works with Serviio v1.2 and 1.2.1 (https://github.com/SwoopX/Web-UI-for-Serviio/archive/master.zip)
1.4b1 - 04/05/2013
- Various code enhancements
- Language selection in console tab now working (fixed wrong cookie path)
- Improved multilanguage support, added new language tags
- Updated German translation
- Page is reloaded to discard changes on reset button press
- Media browser link now accessess the bound interface IP
- Status tab lets you now chose the bound network interface (Serviio API 1.2)
- Transcoding settings now working again (Serviio API 1.2)
- Added new subtitle options (Serviio API 1.2)
- Added new remote options (Serviio API 1.2)
- Tested to work with Serviio 1.21
1.4b2 - 05/06/2013
- Fixed library changes not savable in free version
- Resources added from ServiiDB now have the correct feed type
- Remote tab not visible in free version of Serviio
- Installed plugins are now shown as separate tab under Library
- Added tab to display Serviio log information via variable defined in config.php
1.4b3 - 06/10/2013
- Selected language is now taken from Serviio instead of cookie usage
- Code cleanup
- Re-activated check for compatible Serviio version
- Unified button behavior
- Minor bugfixes
1.4b4 - 07/28/2013
- For log files, latest events are now shown on top, warnings are highlighted in yellow, errors in red
Swoop
Post Mon Jan 06, 2014 4:41 pm
Re: WebUI versions
Released version 1.5.3
Swoop
Post Sun Mar 09, 2014 11:40 pm
Re: WebUI versions
Small bug fixes for version 1.5.4.
Swoop
Post Sun Nov 02, 2014 12:13 pm
Re: WebUI versions
Version 1.5.5 released
TeHashX
Post Mon Jan 25, 2016 5:04 pm
Re: WebUI versions
Working fine with Serviio v1.6 too :)
praeTorian
Post Fri Sep 09, 2016 5:52 am
Re: WebUI versions
I have a problem with version 1.6.1 of servo and WebGUI, because I can't change Audio Transcoding settings.
For example: the switch from "Downmix to stereo" to "keep original"
Workaround: I changed the settings in the original console. http://<IP>:23423/console/
Users browsing this forum: No registered users and 66 guests
