Flv files not playable
pizzaguy541
Post Mon Jan 31, 2011 8:38 am
Re: Flv files not playable
I know that there's no option currently to specify the sampling rate value, but are you considering hard-coding a value? Both iSedora and Mezzmo use 48k for their sampling rate value and produce video files that play audio perfectly.
I'll try different values for targetACodec and see what happens.
Post Wed Feb 02, 2011 9:21 pm
Looking at this now, can you confirm that the FLV file transcoded with 44100 was playing ok? So only files with freq < 44100 need to use 48000 ?
pizzaguy541
Post Sat Feb 05, 2011 9:57 am
I've tried different values for targetACodec and the results varied depending on the file. With flv files, aac & mp2 worked but mp3 produced no audio. With avi files, aac & mp3 produced unsupported file but mp2 produced no audio.
Yes, the flv file with 44100 rate plays ok with the default sampling rate of 44100. The avi file with the 22050 rate seems to need to be sampled at 48k in order to play audio when transcoded.
As I've mentioned, at least on the Sony, every file seems to play fine when transcoded at a sampling rate of 48k regardless of the files native sampling rate.
Post Sat Feb 05, 2011 11:05 am
cool, I've made the code changes. keep in mind to test it in the next beta pls
pizzaguy541
Post Sun Feb 06, 2011 8:04 am
No problem. I'll look forward to testing it using my av files.
pahuley
Post Wed Mar 16, 2011 7:22 am
Whats the best free flv player for playing videos from the same file folder? I recently lost everything on my pc due to a virus. I cant find the old flv player i had. What free flv players will allow yoo to stream files from a file folder automatically without having to choose a video everytime one stops playing?
______________________________
keyword research ~ keyword tool ~ keyword tracking ~ affiliate elite
pizzaguy541
Post Wed Mar 16, 2011 9:08 am
Have you tried installing and using Serviio?
It will do exactly what you're looking for.
AppleTom
Post Wed Mar 16, 2011 10:10 am
Hi everyone!
Serviio is great.
After testing a couple of different media servers for Mac, Serviio was the only one, playing all my files.
I'm a absolute beginner with this topic, and Serviio was running (almost) out of the box for me.
I startet using the software with 0.5.0 a couple of weeks ago and updated to 0.5.1 two days ago.
So far everything works still fine, except .flv playback.
It worked fine with 0.5.0, but not at all with 0.5.1.
Serviio is running on an iMac, my BDP-S370 (EU) is connected via WLAN.
I would love to use 0.5.1, but until I can't playback flv-files, I went back to 0.5.0, which still works fine.
Would it help, to reinstall the EU Profile, instead of the new "all in one"-profile?
Thank you for your help!
Thomas
Post Wed Mar 16, 2011 6:28 pm
AppleTom wrote:Hi everyone!
Serviio is great.
Thomas
no please dont use a 0.5.0 profile with later version of serviio as that will cause you more troubles than it will fix. From what i understand ZIP has fixed this error for the next release that will hopefully be out later this week
Post Wed Mar 16, 2011 8:39 pm
post ffmpeg -i for the flv file and check if there are any errors in the log
AppleTom
Post Sat Mar 19, 2011 7:00 pm
I'm not sure how to do it, HOW TO is not helping, cannot type anything into Terminal window
Post Sat Mar 19, 2011 7:09 pm
AppleTom wrote:I'm not sure how to do it, HOW TO is not helping, cannot type anything into Terminal window
linux or windows???
AppleTom
Post Sun Mar 20, 2011 10:05 am
Mac OSX 10.6
Post Sun Mar 20, 2011 12:40 pm
AppleTom wrote:Mac OSX 10.6
Mac OS X is built on a version of Unix called Darwin. To access the Unix command prompt in Mac OS X, open the Terminal application. It is located by default inside the Utilities folder, which in turn is inside the Applications folder.
For information about Unix commands.
http://kb.iu.edu/data/afsk.html
hm82
Post Thu Jun 16, 2011 4:18 am
Hi Zip, I have a Samsung C-Series TV and I am trying to play the FLV files. I used to be able to do this with an earlier version but now I am not able to play all the files. The strange thing is that Serviio show thumbnails for all the FLV files which are in the directory however its able to play only a few of them. I believe its a configurations issues, but even after several changes I am not able to figure this out
following is the ffmpeg log of a file I was NOT able to play
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[flv @ 0028be00] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 25.00 (25/1)
Input #0, flv, from 'test-file.flv':
hasKeyframes : true
audiodatarate : 64
hasVideo : true
stereo : true
canSeekToEnd : false
framerate : 25
audiosamplerate : 22000
videocodecid : 4
datasize : 176956140
lasttimestamp : 2994
audiosamplesize : 16
audiosize : 25330448
hasAudio : true
audiodelay : 0
videosize : 151612780
metadatacreator : inlet media FLVTool2 v1.0.6 - http://www.inlet-media.de/fl
vtool2
lastkeyframetimestamp: 2992
height : 298
filesize : 177714113
hasMetadata : true
audiocodecid : 2
videodatarate : 403
duration : 2994
hasCuePoints : false
width : 528
Duration: 00:49:54.44, start: 0.000000, bitrate: 478 kb/s
Stream #0.0: Video: vp6f, yuv420p, 528x304, 412 kb/s, 25 tbr, 1k tbn, 1k tbc
Stream #0.1: Audio: mp3, 22050 Hz, 2 channels, s16, 65 kb/s
Please help me out with this.
thanks,
hm
Post Thu Jun 16, 2011 7:41 am
hm82 wrote:Hi Zip, I have a Samsung C-Series TV ...
You are in a Sony topic, please create one in Samsung section, thanks.
aleenaxy
Post Tue Dec 13, 2011 7:16 am
How can i burn an flv file to a dvd so i can watch it on? What do i need to do/ how do i burn an flv file to a dvd so i can play it on my dvd player without getting lip sync probs.
_________________________________
yahoo keyword tool ~ overture ~ traffic estimator ~ adwords traffic estimator
Previous
