Mon Sep 19, 2016 9:41 am by Neven
Hello Petr,
see logfile from 18.9., I dont know how to interprete. Among others I found this:
2016-09-18 18:14:03,390 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2016-09-18 18:14:03,390 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2016-09-18 18:14:03,390 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
One more: appearance of thumbnails is somehow deliberate. When testing different options and then setting them back, the result is NOT the same like initially. Results also dffer for different shared folders. Confusing. Whatever advice you give me, now I can only test on the TV and come back to you as my test version expired and I have to upgrade.
Beside this some videos on TV appear with wrong creation date and length (300 hours.) But they play well. WMP works.
Neven
- Attachments
- (94.81 KiB) Downloaded 503 times
