Console lock remote access
o2co0l
Post Mon Sep 19, 2016 1:53 pm
I encounter a serious security problem.
The Remote Access console (on the web) has no restriction !!!!!!
we can put you an access code? (.htacces and more ?)
Or apply the identic restriction as mediabrowser ????
Thanks,
Post Mon Sep 19, 2016 2:56 pm
Re: Console lock remote access
Unless you've created a port forwarding rule in your firewall, it not accessible from outside your network. Yes, any computer connected to your internal network can access it. I don't know if the developer is considering adding password control to the console at this time.
Post Mon Sep 19, 2016 3:58 pm
if you want to disable access from local network as well you can set up your Windows Firewall for port 23423
o2co0l
Post Tue Sep 20, 2016 8:24 am
Hello !
Thank you for the answer.
It's better than nothing but I hope it will be possible on a future release, to do otherwise because I do not want to block access either.
the console out of the network is still useful because I am traveling a lot.
Thank you
Users browsing this forum: No registered users and 72 guests
