Serviio does not see the PC as online video source
Neven
Post Thu Sep 22, 2016 3:11 pm
Configuration
- Streaming a video by VLC over http:// port 8080
- Playing this stream via 2. nd VLC instance on PC with http://127.0.0.1:8080 works fine
- Serviio Online sources set to Video, Life Stream, http://127.0.0.1:8080 (localhost)
- Checking stream URL: source available and working
On the Smart TV message "No video content on this device"
This works:
- VLC Audio online streaming on TV works
- Library Shared folders streaming on TV works fine
Any help to this?
Neven
Post Thu Sep 22, 2016 10:57 pm
Re: Serviio does not see the PC as online video source
Post result of ffmpeg -i http://127.0.0.1:8080
Neven
Post Fri Sep 23, 2016 10:17 am
Hi, thank you.
There is one ffmpeg.exe in serviio/lib.
Result when streaming not running
Streaming a mp4 file running
ffmpeg running.png (11.92 KiB) Viewed 12814 times
Streaming running, with address of PC 192.168.178.20 instead of 127.0.0.1
ffmpeg running 1 .png (12.53 KiB) Viewed 12813 times
Post Fri Sep 23, 2016 3:10 pm
Ok, so you will have to use the computer IP. Does that work?
Neven
Post Fri Sep 23, 2016 10:29 pm
Same.
But how it can work when missing a parameter?
The red ffmpeg message saying "at least one output file must be specified"
Or something should be set in VLC, although it works on the host.
Post Mon Sep 26, 2016 6:50 pm
Ignore the red ffmpeg message.
Post your detailed log of Serviio startup and browsing to the online folder.
Neven
Post Mon Sep 26, 2016 7:40 pm
What means browsing to the online (?) folder? You man online source.
Addendum
As to start debugging I first wanted to delete the content of the log file, but cannot save it. Saying
"cannot create file serviio.log, make sure that the path and filename are correct"
Trying to delete logfile itself results in "cannot delete serviio, it is being used by another program"
What program? Server is NOT running, Console NOT active.
So I attach the debug logfile as it is, see the last part.
Server stopped
log4j changed INFO to DEBUG, started server
VLC streaming a video
Tryed to get it on TV - same like usually, "no content"
(16.65 KiB) Downloaded 496 times
Post Tue Sep 27, 2016 12:15 pm
You didn't restart the service. Try to restart the whole PC. There should be a lot of DEBUG statements in the log file.
Neven
Post Wed Sep 28, 2016 8:54 am
Yes, a lot of DEBUG's.
1. INFO set to DEBUG
2. restarted PC
3. started a local stream
4. On TV went to Serviio video / online
5. no Serviio icon, right away saying "no content on this device" (in German)
As I said, the same procedure with an audio file works.
(254.36 KiB) Downloaded 517 times
Post Wed Sep 28, 2016 6:14 pm
What if you swap to something like DirectTv profile?
Neven
Post Wed Sep 28, 2016 6:58 pm
zip wrote:What if you swap to something like DirectTv profile?
My TV is Samsung Series F
So what to do now (swap what to where and how)
Transcoding issue? ****Note that playing shared folders works perfectly.
Pls advise
Post Fri Sep 30, 2016 12:58 pm
Click on the Edit button next to your TV and then you can select a different profile for it.
Neven
Post Sun Oct 02, 2016 9:58 am
Same - doesnt work. If it is profile issue, it would not work playing a shared folder either.
Maybe it is a VLC video streaming issue.
Can you give me some kind of video streaming link for test? Just like I can stream internet radio links online with serviio.
Post Mon Oct 03, 2016 12:39 pm
Try some from here: viewforum.php?f=41
