Re: Web UI in PHP
MoonPie2000 wrote:I second that - a guide would be nice for the uneducated. I am running serviio in a windows environment.
Thanks...
zip wrote:why not? you can run PHP anywhere
phn2 wrote:Serviio is the best supported medieserver sw I've found, and I've tried at least 25 diff. distros. Only thing it needs imho is a way to configure it as headless in an easy way, possible via browser. I've read somewhere, that somebodys working on a livecd with serviio, maybe thats the answer...It would make it easier for us linux noobs, who can only repeat what others are doing, not really understanding it...
Cerberus wrote:UPDATE.. project no longer supported from this forum ..UPDATE
The new location for this project is http://labs.softjourn.com/projects/serviioweb please feel free to submit issues to their site as this topic is no longer monitored by their developer..
phn2 wrote:Hello.
Found guide for php/apache on windoze xp here (i've made it work on my pc):
http://wamp.corephp.co.uk/index.php
But how to make the web ui work? I've not found a readme who tells me how to install it?
regards, Per.
phn2 wrote:Hello.
regards, Per.
zip wrote:phn2 wrote:Hello.
regards, Per.
http://www.clearfoundation.com/componen ... /id,25951/
cburbs wrote:
I am trying to get the web portion installed on my vortexbox(fedora 14). I followed the instructions on the clearfoundation link.
If I point my browser to http://IP address of vortexbox/serviioweb/
I get the following - it does load part of the info -
getApplication(); if ($version!=$version_req) { $tab = "error"; $serviio->error = "Required Serviio ${version_req}, but found '${version}'"; } include("code/${tab}.php"); if ($serviio->error && $tab!="about") { $tab = "error"; } ?>
