Serviio doesn't work in MacOS Sierra
GoldFran
Post Sun Oct 02, 2016 6:37 pm
Hello guys.
I have an iMac late 2013 and today I install this program to check if this program it's great to me.
When I install Serviio server not running and say this:
I'm try to reinstall java but the server continue same
What's the problem?
Is it possible that this app does't work in Sierra OS?
Enviado desde mi iPhone utilizando Tapatalk
Post Sun Oct 02, 2016 11:09 pm
Re: Serviio doesn't work in MacOS Sierra
I'm not Mac-savvy, but I do recall a message about older versions of the Mac OS not supporting the newest versions of Serviio. I can't recall where the cutoff was, and of course I have no idea what version of OSX Sierra is.
GoldFran
Post Mon Oct 03, 2016 12:29 am
atc98092 wrote:I'm not Mac-savvy, but I do recall a message about older versions of the Mac OS not supporting the newest versions of Serviio. I can't recall where the cutoff was, and of course I have no idea what version of OSX Sierra is.
Sierra is new Apple OS 10.12...
In last version 10.11, Serviio 1.7 work perfectly, but not in this
Post Mon Oct 03, 2016 12:43 pm
Can you post your serviio log file? http://wiki.serviio.org/doku.php?id=detail_logging
GoldFran
Post Mon Oct 03, 2016 9:31 pm
zip wrote:Can you post your serviio log file? http://wiki.serviio.org/doku.php?id=detail_logging
OK, this's a log:
Mon Oct 03 23:29:30 CEST 2016:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.12.1.1 - (1704137): instance a816c00e-0157-8c73-a107-fffff4a463b2
on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@23fc625e
Loaded from file:/Library/Application%20Support/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.8.0_91-b14
user.dir=/
os.name=Mac OS X
os.arch=x86_64
os.version=10.12.1
derby.system.home=/Library/Application Support/Serviio/library
derby.stream.error.file=../log/derby.log
------------ Begin Shutdown Error Stack -------------
ERROR XSLA7: Cannot redo operation null in the log.
at org.apache.derby.impl.store.raw.log.FileLogger.redo(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.startModule(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager$5.run(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase$5.run(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootServiceModule(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection$4.run(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.startPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.jdbc.InternalDriver$1.run(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:270)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:79)
at org.serviio.MediaServer.main(MediaServer.java:122)
Caused by: ERROR XSDB4: Page Page(1,Container(0, 2544)) is at version 139.754, the log file contains change version 155.313, either there are log records of this page missing, or this page did not get written out to disk properly.
at org.apache.derby.impl.store.raw.data.PageBasicOperation.needsRedo(Unknown Source)
... 52 more
============= begin nested exception, level (1) ===========
============= end nested exception, level (1) ===========
------------ End Shutdown Error Stack -------------
Shutting down instance a816c00e-0157-8c73-a107-fffff4a463b2 on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@23fc625e
Mon Oct 03 23:29:30 CEST 2016 Thread[main,5,main] Cleanup action starting
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@23fc625e, see the next exception for details.
Caused by: ERROR XJ040: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@23fc625e, see the next exception for details.
at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
... 22 more
... 19 more
java.sql.SQLException: Page Page(1,Container(0, 2544)) is at version 139.754, the log file contains change version 155.313, either there are log records of this page missing, or this page did not get written out to disk properly.
... 19 more
============= begin nested exception, level (2) ===========
============= end nested exception, level (2) ===========
Cleanup action completed
Post Mon Oct 03, 2016 10:05 pm
GoldFran
Post Mon Oct 03, 2016 10:27 pm
zip wrote:Similar to this: viewtopic.php?f=5&t=22486#p110601
Yes I saw this post and unistall Serviio completely you see:
Install again but the problem is here...
I can't find any solution :(
GoldFran
Post Mon Oct 03, 2016 10:35 pm
OK, that's right.
I'm solve the problem. The problem was that I had have remove Serviio folder in Application support because Appcleaner doesn't erase it
Serviio work find!
Post Tue Oct 04, 2016 8:44 am
woohoo :)
Potche
Post Sun Oct 16, 2016 7:47 am
HI everybody I m new on this forum and I hop my English will be good enough
I m using Serviio on Mac OS sierra and I he just upgraded serviio i confirm that serviio console work fine even if I had the error message several times I had to switch mac off and restart
However I never have been able to launch serviio.app it always ask me to install java pack 6 and when I try mac tells me that it s impossible to install because an recent version of java is already in the mac. It was the same problem before I upgrade serviio and before I upgrade Serra . So I use serviio but never serviio app and I don't know what can I do to use it
Could you please help to solve this problem : open serviio app on the mac
My second request is how can I change in serviio the titles of the music file for exemple I have an album from an artist Jean Louis Murat and one album from the same artist but labeled jean-Louis murat and they don't appear at the same location because of the caracters I though that i could do that in the serviio app but....i can t open it please help me
I use Mac mini OS X sierra
Serviio 1.7
Yamaha advantage 3030 as the receiver in wifi
Thanks to all
Mark-UK
Post Sun Oct 16, 2016 9:47 am
To change the titles from jean-Louis to Jean Louis, this has to be done to each files tags, something like mp3tag will make this a simple process http://www.mp3tag.de/en/
Users browsing this forum: Google [Bot] and 39 guests
