Cannot start Serviio on my mac
snowguard
Post Fri Sep 30, 2016 9:49 pm
Hi everybody,
I'm John a happy user :) , using Serviio for some years, it never let me down, helped me with my needs of data streaming.
I have a mac osx 10.10.5
I had to restore my mac for a broken ssd, recover all my data from time machine but my Serviio won't start
it said, in a blank sad windows named Electron: Cannot connect to the server, it doesn't seem to be running
tried to delete and reinstall the software (i think i had 1.6.1, download the 1.7) but same error occur
any ideas?
Thank you for the great Job
PS I run a search but didn't find any solution for my problem, found some similar on windows, but cannot help me.
Snow.
Post Mon Oct 03, 2016 6:56 pm
Re: Cannot start Serviio on my mac
snowguard
Post Mon Oct 03, 2016 7:55 pm
I look at it, but didn't understand the problem, so I've attached it.
Thank you for the support!
Snow
looking sharply, i think I post the wrong file, try to delete the old logs, but no log appeared... so I post the one that seems newer to me, but time is not matching...
The Log
(60.01 KiB) Downloaded 545 times
derby.log
Log file
(24.11 KiB) Downloaded 496 times
Post Mon Oct 03, 2016 8:41 pm
Looks like the database got corrupted.
Your best bet is to uninstall Serviio and install it again. http://serviio.org/component/content/article?id=21#q4
snowguard
Post Mon Oct 03, 2016 11:48 pm
I did it, but put the application on the trash, then reinstall, didn't solve the problem, so I trash the application and the folder on library, now it's ok, i've lost my library, but there is no problem. :) Again, thank you for your support!!
Snow
