Network Disconnection problems on Samsung Series 7
madman10
Post Sun Oct 02, 2016 2:10 am
I have been getting random and frequent network disconnection problems on my Samsung Series 7 HDTV, I never had these problems since you changed Serviio to the console through the Web browser.
I never had any disconnection issues before the console through the web browser, Serviio works fine on all my other devices but only disconnects on the Samsung Series 7 TV.
I have the TV connected through my wired connection, I tried different cables and even through a Power line adapter and still it disconnects. I doubt it's the network because it worked fine before the console was changed.
I would like to know if anyone else is having this issue, my brother has a new LG TV and is also having the same issue.
I tried uninstalling/reinstalling and still no change I will have to try and find a version of Serviio that is before it was changed to the browser access console.
Thank You
The Madman :D
Post Sun Oct 02, 2016 11:02 pm
Re: Network Disconnection problems on Samsung Series 7
Having no issues with disconnects with my Roku players or Sony BDP. I'll give my Samsung a shot this evening to see how it does. I usually don't use the TV itself, as the Sony and Roku have better user interfaces.
Post Mon Oct 03, 2016 12:22 pm
Watched about 20 minutes of a movie last night (all I had time for). No connection issues. I'm on a wired Gigabit network.
madman10
Post Tue Oct 04, 2016 2:13 am
Thanks for your input, but these disconnections are random but frequent. This only happens on my Samsung Series 7 TV and I am wired directly to the TV, I tried different cables and even a Power line adapter and still disconnects. I have other devices connected to it and no problems, I have 2 other Samsung older TVS and they don't disconnect. It just seems to be that series, maybe the solution would be to make a profile on the settings for that Samsung Series. :mrgreen:
Post Tue Oct 04, 2016 12:12 pm
Well, I use the J series profile for my JU7100. Although before that profile was available I was using the H profile with no issues either. The Samsung profiles are based on the letter series, not the number, so I'm not sure how your 7 series may differ from mine. Exactly which model are you using?
madman10
Post Wed Oct 05, 2016 4:19 pm
I do believe I am using UN50JS7000 or UA50HU7000R but I think it's the one that is in bold, anyways I am really disappointed with Serviio now always love it until now.
Need a solution, I might get a NUC and use Kodi instead of Serviio. :(
AndyCr15
Post Wed Oct 12, 2016 5:12 pm
Mine says it's a PS50C550 and I have a similar problem. I seem to get about 25 minutes in and it loses connection, or I turn the TV on a Serviio simply isn't there and appears half way through watching something else. Gigabit wired connection. My 40" Samsung seems fine...
madman10
Post Thu Oct 13, 2016 4:01 am
It is random, sometimes it disconnects after 6mins. Another time it works for like 30mins and then disconnects or another time it doesn't disconnect, I think there's something in the new code that is doing this. My brother has a new LG HD TV and it has the same disconnecting issues. :?:
Post Thu Oct 13, 2016 6:22 am
I'm guessing, but try setting a longer advertisement time: http://www.serviio.org/component/conten ... properties
Look at the serviio.advertisementDuration switch - by default its 1800 seconds (30 minutes), try setting it to 10800 (3 hours)
madman10
Post Thu Oct 13, 2016 9:57 pm
I am not sure how to change what you are suggesting, I looked in the settings in the web interface and can't find anywhere what you are suggesting please clarify. :shock:
madman10
Post Thu Oct 13, 2016 10:24 pm
I think I found out where to go: 1) First turn off Serviio service 2) Edit C:\Program Files\Serviio\bin and then add -D<serviio.advertisementDuration>=<10800> to the ServiioService.exe.vmoption.s file 3) Turn Serviio service back on
Post Fri Oct 14, 2016 12:47 am
madman10 wrote:I think I found out where to go: 1) First turn off Serviio service 2) Edit C:\Program Files\Serviio\bin and then add -D<serviio.advertisementDuration>=<10800> to the ServiioService.exe.vmoption.s file 3) Turn Serviio service back on
Make sure you're actually stopping the service, and not using the DLNA server control on the console. In Windows, that's the Services app. Rebooting will also accomplish the same thing.
Post Fri Oct 14, 2016 10:07 pm
without the "<"'s
It should be -Dserviio.advertisementDuration=10800
madman10
Post Sat Oct 15, 2016 2:04 am
Thank you for your help, I will test to see if my issue is resolved and let you know. I also would like to change the size of the thumbnails to larger or more detailed resolution, in the properties for Serviio server it says that the default is 320. Now can I double it to 640 or is that not possible and would I change it in the same file with the following addition: -Dserviio.hdThumbnailResoulution=640.
I find my thumbnails look low res and blocky and this is why I want them more detailed. :lol:
madman10
Post Sat Oct 15, 2016 2:12 am
Now this resolution tweek only change the thumbnails in the browser not the tv? I don't have the pro version so I don't use the browser. :shock:
Post Sat Oct 15, 2016 8:22 am
madman10 wrote:Now this resolution tweek only change the thumbnails in the browser not the tv?
Yes, it's only for the browser.
madman10
Post Mon Oct 17, 2016 1:29 am
I tried adding the suggestion: I'm guessing, but try setting a longer advertisement time: http://www.serviio.org/component/conten ... properties
It is still losing the network connection, it's not the network it has to be something with the TV, any suggestions. :|
madman10
Post Tue Oct 18, 2016 11:50 pm
I found out my TV is a Samsung UN50HU7000
Post Wed Oct 19, 2016 12:38 am
Did you restart your PC after changing the switch (otherwise nothing changes)
I have read one post where the opposite helped - setting it to a smaller duration (eg. 300 seconds).
Also check/change your router settings for IGMP Snooping or Muliticast. This has helped in the past but depends on the router.
madman10
Post Wed Oct 19, 2016 3:45 am
I did reboot PC and still the same, now the only other thing I could think of is maybe the firmware update on the TV. :shock:
Users browsing this forum: No registered users and 123 guests
