Impossible to transcode E-AC-3 audio
pierrep
Post Tue Nov 08, 2011 12:41 pm
Hello
I'm trying to add a value in my SHARP AQUOS profile to transcode audio E-AC-3 to AC3. I have TV HD recording that come with EAC3 audio
When playing such a file on the SHARP TV: I have no sound
ffmpeg -i
Input #0, mpegts, from 'xxxxxx.m2ts':
  Duration: 02:30:00.35, start: 81445.521389, bitrate: 9803 kb/s
  Program 1282
    Stream #0.0[0xdc]: Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 26.30 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0.1[0xe7](qaa): Audio: eac3, 48000 Hz, 5.1, s16, 256 kb/s
    Stream #0.2[0xe6](fra): Audio: eac3, 48000 Hz, stereo, s16, 128 kb/s
    Stream #0.3[0xf0](fra): Subtitle: dvbsub (hearing impaired)
    Stream #0.4[0x10e]: Data: [5][0][0][0] / 0x0005
    Stream #0.5[0x10f]: Data: [11][0][0][0] / 0x000B
So I tried to add a line in the profile
     <Matches container="mpegts" aCodec="eac3" />
When launching SERVIIO this line is invalid!
ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-enumeration-valid:
Value 'eac3' is not facet-valid with respect to enumeration '[mp3, mp2, ac3, aac, dca, wmav2, wmapro, lpcm, flac, vorbis, truehd, amrnb]'.
It must be a value from the enumeration.
How to solve this limitation?
Post Tue Nov 08, 2011 12:46 pm
Re: Impossible to transcode E-AC-3 audio
Serviio doesn't distinguish between ac3 and eac3. I'd suggest you transcode it to ac3 manually for now.
pierrep
Post Tue Nov 08, 2011 1:25 pm
Thanks for your reply
Serviio doesn't just use what it is returned by ffmpeg?
In this case perhaps it's just possible to change the XSD profiles file (with a local copy of this file) to add "eac3" in "audioContainerEnumType"?
Post Tue Nov 08, 2011 1:40 pm
nope, it's baked into the code, ie eac3 and ac3 tracks are stored as ac3 in Serviio DB, therefore you cannot distinguish and create a transcoding rule for it (without transcoding all ac3 into something else)
pierrep
Post Tue Nov 08, 2011 3:17 pm
So perhaps it's possible to transcode ac3 to ac3 even it's a stupid operation in most of the cases!
     <Matches container="mpegts" aCodec="ac3" />
Post Tue Nov 08, 2011 4:23 pm
It'll work out it's the same codec and use "-acodec copy", so it won't help. There is forceVTranscoding attribute which would not use 'copy' if this was a video codec example, but there is not such a thing for audio.
pierrep
Post Tue Nov 08, 2011 5:43 pm
So, let's wait for next patch of Serviio with eac3 support (or forceATranscoding option)? :P
guitarboy
Post Mon Oct 17, 2016 7:56 am
I know this is an older thread, but has this problem been solved? Neither my WD TV nor my Panasonic BluRay will play EAC3 audio tracks. Is there any way to force Serviio to transcode these files to AC3 or another audio format?
Muxing the files to another format isn't really an option. I'd rather go out and buy a Roku or other set top box.
If you have any tips for editing the WD TV profile to fix this problem, please let me know.
guitarboy
Post Tue Oct 18, 2016 8:40 pm
I've just figured out that it's my receiver that can't do DD+/E-AC-3. The WD TV is just doing HDMI pass through, so what I really need is for Serviio to do the transcoding for me from DD+/E-AC-3 to basic DD/AC-3 (or something equivalent).
For those interested, my (hopefully temporary) workaround is to do the following:
  1. Extract the E-AC-3 track to an MKA file using MKVToolNix.
  2. Convert the MKA file to AC-3 using Any Audio Converter (free converter [ad supported], easy and attractive UI, works well).
  3. Use MKVToolNix Merge Tool to mux the original MKV with the new AC3 track.
Apparently some streaming platforms (e.g. Amazon) are now using Dolby Digital Plus exclusively, so this is going to be a growing problem for those of us with older audio hardware.
Post Wed Oct 19, 2016 7:46 am
can you create a bitbucket ticket with some ffmpeg -i examples of eac3 files?
guitarboy
Post Wed Oct 19, 2016 8:45 am
I created the issue https://bitbucket.org/xnejp03/serviio/i ... c3-example
Hopefully that's what you're looking for (I don't have much experience with ffmpeg).
Please PM me if you're looking for more.
Post Wed Oct 19, 2016 1:05 pm
guitarboy
Post Mon Oct 31, 2016 6:34 am
Issue link has been updated to https://bitbucket.org/xnejp03/serviio/i ... eac3-audio.
If you would like to see this enhancement, please vote for it on Bitbucket.
Tarrasque
Post Fri Dec 16, 2016 11:02 am
Seems like the panasonic 2012 profile has not been updated. When plyaing videos with eac3 it (tv) says audio not supported.
Will create ffmpeg info on file i am using.
Post Fri Dec 16, 2016 6:09 pm
No profiles have been updated. Let me know the needed changes and I will include it in the next version
Tarrasque
Post Fri Dec 16, 2016 8:42 pm
Here is the ffmpeg -i of the file in question
    encoder         : no_variable_data
    creation_time   : 1970-01-01 00:00:00
  Duration: 01:01:44.00, start: 0.000000, bitrate: 6028 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p(tv, bt709/unknown/unknown), 12
80x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1: Audio: eac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
Profile I am using the Panasonic 2011/2012 UT.
I added these lines under the profile, and fixed the issue (not sure if it is the most efficient line of code)
            <Matches container="*" aCodec="eac3" />
Regards
Brianwuz
Post Mon Jan 09, 2017 9:33 am
Regards
Thanks Tarrasque,
I followed your lead and made my Sony BDP-S580 profile like this and sound from a mkv with eac3 audio from amazon works:
<Profile id="bdp2011" name="Sony BDP-Sx80/SMP-N200 (2011)" extendsProfileId="bdp2010">
      <!-- Same as profile bdp2010, except AVIs with DivX FourCC must be transcoded, no XSub subtitle support -->
         <!-- unsupported codecs will be transcoded to mpegts with mpeg2video and ac3 audio -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384">
            <!-- DivX -->
            <Matches container="avi" vCodec="mpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
            <Matches container="avi" vCodec="msmpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
Also a BIG note. If you are having trouble getting the serviio service to start after changing the profile, then you have xml errors. I was pulling my hair out and reinstalling serviio till I figured this out. I had forgotten the closing tag.
Brian
Henderson
Post Thu Mar 16, 2017 2:18 am
I've recently run into this problem with E-AC-3 audio on a few files and can't seem to get Serviio to transcode the mkv files. I've tried both additions above to my profile (and several variations of them) and my player either eventually says corrupt file, or the player locks up with the wait animation going forever where I have to unplug it, it's completely unresponsive.
My player is Sony BDP-S6500 and I'm using the 2013 profile. I tried other profiles too hoping to force Serviio into transcoding the mkv file to force the downmix to stereo, but no luck with any of them. If anyone has tried other profile additions that work, I'd love to know how to do it.
dazzknowles
Post Sat Oct 21, 2017 5:22 pm
Does anybody know how, or indeed if it's even possible, to get E-AC3 to play on a PlayStation 4? I've tried adding lines like...
to the transcoding directives in the profile but it just says "Cannot play audio. The audio format is unsupported"
Cheers.
bembe
Post Sat Nov 18, 2017 4:24 pm
Hi.
I have a question regarding E-AC and transcoding.
As far as I have seen - E-AC is enabled in Serviio from version 1.8
However, I have 1.9 version and it doesn't transcode. My Sony Bravia (2013/2104) gives me message "Audio format not supported".
Any tips how to use it?
Audio file info:
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Codec ID : A_EAC3
Duration : 58 min 7 s
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 266 MiB (8%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
