Network Disconnection problems on Samsung Series 7
Post Wed Oct 19, 2016 1:11 pm
Re: Network Disconnection problems on Samsung Series 7
Did you go through some of the solutions offered here? viewtopic.php?f=5&t=10289
madman10
Post Tue Nov 01, 2016 9:03 pm
I tried what you suggested and it still disconnects after 6mins, and then I continue where I left off and 6mins in it disconnects again.
I am stomped, and don't know where to go from here. I think maybe we need a profile for the model series of Samsung TV, it seems like this happens when playing MP4 files.
So anymore suggestions would be good, only this TV has this problem all my other devices work flawlessly the TV is Samsung UN50HU7000.
Frankz
Post Fri Dec 09, 2016 12:17 pm
I'm experiencing the same issue as you described. After about 15-20 minutes it will completely lose connection to Serviio. I have a Samsung UE55KS7000(2016). If I had to take a guess, I think this is an issue caused by the TV itself and not by Serviio, although I can't be 100% sure. Is there any way to pull up a log from the samsung tv itself?
This is what the serviio logs display;
2016-12-06 08:03:32,028 INFO  [PlaybackProgressUpdater] Started playback progress updater
2016-12-06 08:04:01,403 INFO  [PlaybackEventsManager] Playback of media item 267 has started at 0% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 08:33:37,611 INFO  [PlaybackEventsManager] Playback of media item 267 has stopped at 27% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 08:33:49,133 INFO  [PlaybackEventsManager] Playback of media item 267 has started at 0% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 09:03:52,007 INFO  [PlaybackEventsManager] Playback of media item 267 has stopped at 61% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 09:04:01,099 INFO  [PlaybackEventsManager] Playback of media item 267 has started at 0% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 09:37:03,847 INFO  [PlaybackEventsManager] Playback of media item 267 has stopped at 95% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 09:37:12,824 INFO  [PlaybackEventsManager] Playback of media item 267 has started at 0% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 09:46:24,668 INFO  [PlaybackEventsManager] Playback of media item 267 has stopped at 100% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 09:47:42,952 INFO  [PlaybackEventsManager] Playback of media item 267 has started at 99% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
2016-12-06 09:47:45,689 INFO  [PlaybackEventsManager] Playback of media item 267 has stopped at 100% on Identifier=192.168.0.240, Profile=Generic DLNA profile, Name=Unrecognized device
madman10
Post Mon Dec 12, 2016 3:33 am
I also think it has to do with the firmware version mine is at: 1160.4 BT-S :o
zilvanis
Post Mon Jan 16, 2017 2:09 pm
I have the same problem with my SAMSUNG UE-55KS7502 After watching a movie for some time it just disappear from tv. I tried different DLNA application, but TV behavior still the same(movie suddenly dissapears from screen). I changed my router, but that didn't help. I will try to run serviio from different pc. If anyone has some other suggestions iam lisstening
Previous
Users browsing this forum: Google [Bot] and 1 guest
