x265 still not working
• Page 1 of 1
I was hoping that x265 situation would be fixed with the new update.. No work on that?
Re: x265 still not working
Whats broken? What TV do you have. What profile is assigned to that TV?
I have LG 49UB850V-ZD
Mac OSX 10.10.5
I've tried every possible combination. And even manually changed profile with one of your guys help. But it didnt work.
I took SS and put here. They said everything looks fine but it's not working.
My TV supports x265 if I connect through usb or HDD but not through serviio. Without transcoding option, I'm recieving "network connection" error. if I activate transcoding with "burned subtitles" videos starts to play at the begining but in a minute or two it acts like its buffering. And some of the video files working fine without transcoding are stops working after I activate it.
With the new update I was hoping that it could resolve but now I've lost the subtitles
I guess I'll rollback to 1.6.1
Mac OSX 10.10.5
I also have an LG TV (Model 40UB800T-TB) and I can confirm that H265 are unwatchable in the latest, licenced versions of Serviio no matter what I do.
I have Serviio set to use the LG TV / Player Profile but the generic DLNA profile does not work either.
I have reverted back to the last version where it did work reliably with my TV, Serviio version 1.5.2 using the LG TV / Player profile and all is well.
(And I must admit, I like the older style interface of Serviio 1.5.2 better than the newer versions)
Jeff C.
aka
MaXiLeeCH
Jeff C.
aka
MaXiLeeCH
Can you post ffmpeg -i of the file?
Petr
Help translate Serviio
MaXiLeeCH wrote:I also have an LG TV (Model 40UB800T-TB) and I can confirm that H265 are unwatchable in the latest, licenced versions of Serviio no matter what I do.
Jeff C.
aka
MaXiLeeCH
Really? x265 works on 1.5.2 ? did you change anything manually while you use 1.5.2
I will try too
zip wrote:Can you post ffmpeg -i of the file?
You have to be more specific, please..
ffmpeg -i "filename"
I.e. ffmpeg -i "Undateable S03E01.mp4"
This will show some output which zip can use to decode the errors.
Hello.
I have LG 42LN575S (2013).
I can't play file with HEVC.
File info from MediaInfo
log from serviio.log (during trying to play file)
File info from ffmpeg.exe
I use Serviio 1.5.1 and I have set LG TV / player Profile, because I can't set this profile in newest version.
ffmpeg is up-to-date! Download from http://ffmpeg.zeranoe.com/builds/
This file can't be play in 1.8.1 with Generic DLNA profile too.
I decide about purchasing Pro version, but this is the problem.
- Code:
Unique ID : 192386701210754839118229287163396550194 (0x90BC54B450487FB4AB4E23215E46EE32)
Complete name : C:\John Wick 2.mkv
Format : Matroska
File size : 2.67 GiB
Duration : 2 h 2 min
Overall bit rate : 3 125 kb/s
Encoded date : UTC 2017-05-31 16:11:57
Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 2 483 kb/s
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.067
Stream size : 2.12 GiB (79%)
Writing library : x265 2.1:[Windows][GCC 5.4.0][64 bit] 8bit
Encoding settings : wpp / ctu=32 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=1 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=10 / lookahead-slices=5 / bframes=3 / bframe-bias=0 / b-adapt=0 / ref=1 / limit-refs=0 / no-limit-modes / no-weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=0.00 / cbqpoffs=0 / crqpoffs=0 / rd=2 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / log2-max-poc-lsb=8 / no-rd-refine / signhide / deblock=0:0 / no-sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=abr / bitrate=2500 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 560 MiB (20%)
Title : Surround
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
- Code:
2017-06-11 13:49:07,007 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,007 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,007 DEBUG [ResourceDeliveryProcessor] Request for resource 1 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,007 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2017-06-11 13:49:07,007 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 1
2017-06-11 13:49:07,007 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 1
2017-06-11 13:49:07,007 DEBUG [GETMethodProcessor] Stream entity has length: 6525
2017-06-11 13:49:07,007 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 6525,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,023 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55683: GET /resource/2/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,023 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,023 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,023 DEBUG [ResourceDeliveryProcessor] Request for resource 2 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,023 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 2)
2017-06-11 13:49:07,023 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 2
2017-06-11 13:49:07,023 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 2
2017-06-11 13:49:07,023 DEBUG [GETMethodProcessor] Stream entity has length: 6993
2017-06-11 13:49:07,023 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 6993,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,108 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55684: GET /resource/3/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,108 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,108 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,108 DEBUG [ResourceDeliveryProcessor] Request for resource 3 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,108 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3)
2017-06-11 13:49:07,108 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 3
2017-06-11 13:49:07,108 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 3
2017-06-11 13:49:07,108 DEBUG [GETMethodProcessor] Stream entity has length: 3631
2017-06-11 13:49:07,108 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 3631,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,224 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55685: GET /resource/4/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,224 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,224 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,224 DEBUG [ResourceDeliveryProcessor] Request for resource 4 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,224 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 4)
2017-06-11 13:49:07,224 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 4
2017-06-11 13:49:07,224 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 4
2017-06-11 13:49:07,224 DEBUG [GETMethodProcessor] Stream entity has length: 4640
2017-06-11 13:49:07,224 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 4640,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,324 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55686: GET /resource/6/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,324 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,324 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,324 DEBUG [ResourceDeliveryProcessor] Request for resource 6 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,324 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 6)
2017-06-11 13:49:07,324 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 6
2017-06-11 13:49:07,324 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 6
2017-06-11 13:49:07,324 DEBUG [GETMethodProcessor] Stream entity has length: 4711
2017-06-11 13:49:07,324 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 4711,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,408 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55687: GET /resource/7/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,408 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,408 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,408 DEBUG [ResourceDeliveryProcessor] Request for resource 7 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,408 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 7)
2017-06-11 13:49:07,408 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 7
2017-06-11 13:49:07,408 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 7
2017-06-11 13:49:07,408 DEBUG [GETMethodProcessor] Stream entity has length: 6391
2017-06-11 13:49:07,408 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 6391,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,493 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55689: GET /resource/8/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,493 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,494 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,494 DEBUG [ResourceDeliveryProcessor] Request for resource 8 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,494 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 8)
2017-06-11 13:49:07,494 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 8
2017-06-11 13:49:07,494 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 8
2017-06-11 13:49:07,494 DEBUG [GETMethodProcessor] Stream entity has length: 3367
2017-06-11 13:49:07,494 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 3367,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,571 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55692: GET /resource/9/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,571 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,572 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,572 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,572 DEBUG [ResourceDeliveryProcessor] Request for resource 9 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,572 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9)
2017-06-11 13:49:07,573 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 9
2017-06-11 13:49:07,573 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 9)
2017-06-11 13:49:07,573 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 9
2017-06-11 13:49:07,573 DEBUG [GETMethodProcessor] Stream entity has length: 5431
2017-06-11 13:49:07,573 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 5431,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,667 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55693: GET /resource/10/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,667 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,668 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,668 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,668 DEBUG [ResourceDeliveryProcessor] Request for resource 10 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,668 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 10)
2017-06-11 13:49:07,668 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 10
2017-06-11 13:49:07,669 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 10
2017-06-11 13:49:07,669 DEBUG [GETMethodProcessor] Stream entity has length: 4188
2017-06-11 13:49:07,669 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 4188,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,773 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55694: GET /resource/11/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,773 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,773 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,774 DEBUG [ResourceDeliveryProcessor] Request for resource 11 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,774 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 11)
2017-06-11 13:49:07,774 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 11
2017-06-11 13:49:07,774 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 11
2017-06-11 13:49:07,774 DEBUG [GETMethodProcessor] Stream entity has length: 6603
2017-06-11 13:49:07,774 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 6603,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,860 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55695: GET /resource/12/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,860 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,861 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,861 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,861 DEBUG [ResourceDeliveryProcessor] Request for resource 12 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,861 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 12)
2017-06-11 13:49:07,861 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 12
2017-06-11 13:49:07,862 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 12)
2017-06-11 13:49:07,862 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 12
2017-06-11 13:49:07,862 DEBUG [GETMethodProcessor] Stream entity has length: 5523
2017-06-11 13:49:07,862 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 5523,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:07,923 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55696: GET /resource/14/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:07,923 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:07,923 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:07,923 DEBUG [ResourceDeliveryProcessor] Request for resource 14 and type 'COVER_IMAGE' received
2017-06-11 13:49:07,923 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 14)
2017-06-11 13:49:07,923 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 14
2017-06-11 13:49:07,923 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 14
2017-06-11 13:49:07,923 DEBUG [GETMethodProcessor] Stream entity has length: 5337
2017-06-11 13:49:07,923 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 5337,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:07 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:08,039 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55697: GET /resource/15/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:08,039 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,039 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:08,039 DEBUG [ResourceDeliveryProcessor] Request for resource 15 and type 'COVER_IMAGE' received
2017-06-11 13:49:08,039 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15)
2017-06-11 13:49:08,039 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 15
2017-06-11 13:49:08,039 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 15
2017-06-11 13:49:08,039 DEBUG [GETMethodProcessor] Stream entity has length: 4901
2017-06-11 13:49:08,039 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 4901,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:08,140 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55698: GET /resource/16/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:08,140 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,140 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:08,140 DEBUG [ResourceDeliveryProcessor] Request for resource 16 and type 'COVER_IMAGE' received
2017-06-11 13:49:08,140 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 16)
2017-06-11 13:49:08,140 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 16
2017-06-11 13:49:08,140 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 16
2017-06-11 13:49:08,140 DEBUG [GETMethodProcessor] Stream entity has length: 3166
2017-06-11 13:49:08,140 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 3166,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:08,224 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55699: GET /resource/17/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:08,224 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,224 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:08,224 DEBUG [ResourceDeliveryProcessor] Request for resource 17 and type 'COVER_IMAGE' received
2017-06-11 13:49:08,224 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 17)
2017-06-11 13:49:08,224 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 17
2017-06-11 13:49:08,224 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 17
2017-06-11 13:49:08,224 DEBUG [GETMethodProcessor] Stream entity has length: 6631
2017-06-11 13:49:08,224 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 6631,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:08,300 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55700: GET /resource/18/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:08,300 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,301 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,301 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:08,301 DEBUG [ResourceDeliveryProcessor] Request for resource 18 and type 'COVER_IMAGE' received
2017-06-11 13:49:08,301 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 18)
2017-06-11 13:49:08,301 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 18
2017-06-11 13:49:08,302 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 18
2017-06-11 13:49:08,302 DEBUG [GETMethodProcessor] Stream entity has length: 4857
2017-06-11 13:49:08,302 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 4857,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:08,408 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55701: GET /resource/19/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:08,408 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,408 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:08,408 DEBUG [ResourceDeliveryProcessor] Request for resource 19 and type 'COVER_IMAGE' received
2017-06-11 13:49:08,408 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 19)
2017-06-11 13:49:08,408 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 19
2017-06-11 13:49:08,408 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 19
2017-06-11 13:49:08,408 DEBUG [GETMethodProcessor] Stream entity has length: 3661
2017-06-11 13:49:08,408 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 3661,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:08,496 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55702: GET /resource/20/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.0.2:8895,Accept: */*]]
2017-06-11 13:49:08,496 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,497 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:08,497 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:08,497 DEBUG [ResourceDeliveryProcessor] Request for resource 20 and type 'COVER_IMAGE' received
2017-06-11 13:49:08,497 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 20)
2017-06-11 13:49:08,497 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 20
2017-06-11 13:49:08,498 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image (SD) with id 20
2017-06-11 13:49:08,498 DEBUG [GETMethodProcessor] Stream entity has length: 4873
2017-06-11 13:49:08,498 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 4873,Content-Type: image/jpeg,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:08 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:10,659 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.0.1:4579s
2017-06-11 13:49:10,660 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.0.0.1:4579
2017-06-11 13:49:10,663 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.0.1:4579s
2017-06-11 13:49:10,663 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /10.0.0.1:4579
2017-06-11 13:49:13,485 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55706: GET /resource/9/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.1, headers = [Host: 10.0.0.2:8895,Connection: close,icy-metadata: 1,User-Agent: GStreamer souphttpsrc (compatible; LG NetCast.TV-2013) libsoup/2.34.2]]
2017-06-11 13:49:13,485 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:13,485 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:13,486 DEBUG [ResourceDeliveryProcessor] Request for resource 9 and type 'MEDIA_ITEM' received
2017-06-11 13:49:13,486 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 9 (local)
2017-06-11 13:49:13,486 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 9)
2017-06-11 13:49:13,487 DEBUG [VideoDAOImpl] Reading a Video (id = 9)
2017-06-11 13:49:13,487 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 9, format MATROSKA and profile LG TV / player
2017-06-11 13:49:13,487 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 9 (local)
2017-06-11 13:49:13,487 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 9)
2017-06-11 13:49:13,488 DEBUG [VideoDeliveryEngine] Delivering item '9' for client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:13,488 DEBUG [VideoDeliveryEngine] Delivering file 'John Wick 2.mkv' in native format
2017-06-11 13:49:13,488 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2017-06-11 13:49:13,488 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 9) as read
2017-06-11 13:49:13,490 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2017-06-11 13:49:13,490 DEBUG [GETMethodProcessor] Stream entity has length: 2867947416
2017-06-11 13:49:13,490 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 2867947416,Content-Type: video/x-matroska,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:13 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Streaming]]
2017-06-11 13:49:13,602 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55707: GET /resource/9/SUBTITLE.srt HTTP/1.1, headers = [Host: 10.0.0.2:8895,Range: bytes=4001-4500,User-Agent: GStreamer souphttpsrc (compatible; LG NetCast.TV-2013) libsoup/2.34.2]]
2017-06-11 13:49:13,602 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:13,602 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:13,602 DEBUG [ResourceDeliveryProcessor] Request for resource 9 and type 'SUBTITLE' received
2017-06-11 13:49:13,602 DEBUG [VideoDAOImpl] Reading a Video (id = 9)
2017-06-11 13:49:13,603 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2017-06-11 13:49:13,603 DEBUG [SubtitlesService] Found external subtitle file: D:\Downloads\_premiery\nevideno\John Wick 2.srt
2017-06-11 13:49:13,603 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 9
2017-06-11 13:49:13,604 DEBUG [VideoDAOImpl] Reading a Video (id = 9)
2017-06-11 13:49:13,604 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2017-06-11 13:49:13,604 DEBUG [SubtitlesService] Found external subtitle file: D:\Downloads\_premiery\nevideno\John Wick 2.srt
2017-06-11 13:49:13,604 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 9
2017-06-11 13:49:13,605 DEBUG [GETMethodProcessor] Stream entity has length: 500
2017-06-11 13:49:13,605 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 500,Content-Type: text/srt,Cache-control: no-cache,Connection: close,Content-Range: bytes 4001-4500/41361,Date: Sun, 11 Jun 2017 11:49:13 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:13,643 DEBUG [ServiioHttpService] Incoming request from /10.0.0.1:55708: GET /resource/9/SUBTITLE.srt HTTP/1.1, headers = [Host: 10.0.0.2:8895,Connection: close,User-Agent: GStreamer souphttpsrc (compatible; LG NetCast.TV-2013) libsoup/2.34.2]]
2017-06-11 13:49:13,643 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:13,644 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.0.0.1
2017-06-11 13:49:13,644 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.0.0.1, Profile=LG TV / player'
2017-06-11 13:49:13,644 DEBUG [ResourceDeliveryProcessor] Request for resource 9 and type 'SUBTITLE' received
2017-06-11 13:49:13,644 DEBUG [VideoDAOImpl] Reading a Video (id = 9)
2017-06-11 13:49:13,644 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2017-06-11 13:49:13,645 DEBUG [SubtitlesService] Found external subtitle file: D:\Downloads\_premiery\nevideno\John Wick 2.srt
2017-06-11 13:49:13,645 DEBUG [SubtitlesRetrievalStrategy] Retrieving info of Subtitles for media item with id 9
2017-06-11 13:49:13,645 DEBUG [VideoDAOImpl] Reading a Video (id = 9)
2017-06-11 13:49:13,645 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2017-06-11 13:49:13,645 DEBUG [SubtitlesRetrievalStrategy] Retrieving Subtitles for media item with id 9
2017-06-11 13:49:13,646 DEBUG [GETMethodProcessor] Stream entity has length: 41361
2017-06-11 13:49:13,646 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 41361,Content-Type: text/srt,Cache-control: no-cache,Connection: close,Date: Sun, 11 Jun 2017 11:49:13 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.1,transferMode.dlna.org: Interactive]]
2017-06-11 13:49:14,384 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2017-06-11 13:49:21,739 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 5a14656e-f0e9-2246-bd31-c1c1bfdb0e95 from address 10.0.0.1
2017-06-11 13:49:21,739 DEBUG [RendererManager] Removing renderer 5a14656e-f0e9-2246-bd31-c1c1bfdb0e95 from list of active renderers
2017-06-11 13:49:21,797 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:byebye) message from Renderer 5a14656e-f0e9-2246-bd31-c1c1bfdb0e95 from address 10.0.0.1
2017-06-11 13:49:21,907 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:5a14656e-f0e9-2246-bd31-c1c1bfdb0e95 from address /10.0.0.1:7898s
2017-06-11 13:49:31,754 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2017-06-11 13:49:31,754 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
• Page 1 of 1
Users browsing this forum: Baidu [Spider] and 3 guests
