Wrong Duration shown
paul33
Post Fri Nov 11, 2016 2:57 pm
I am in the process of moving over from Plex, a lot of the content i use is recorded from tv via a tuner attached to the PC
PC is Windows 10 with all updates and my samsung is a Blu Ray BD-H6500
Some of my recordings when viewing on the Samung have a wrong length (usually about 5mins instead of 30), playing these files directly or on my PC show correct info
Here are the details from ffmpeg -i and also from Mediainfo
Hope someone can help
C:\Program Files\Serviio\lib>ffmpeg.exe -i "e:\tv temp\eastenders - s32e178.ts"
ffmpeg version 3.0.2 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.9.3 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config --bindir='/jenkins/workspace/FFmpeg - Win32/target'
  libavutil      55. 17.103 / 55. 17.103
  libavcodec     57. 24.102 / 57. 24.102
  libavformat    57. 25.100 / 57. 25.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 31.100 /  6. 31.100
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
  libpostproc    54.  0.100 / 54.  0.100
[mpeg2video @ 0313c480] Invalid frame dimensions 0x0.
    Last message repeated 2 times
[mpegts @ 032628e0] PES packet size mismatch
[NULL @ 0313d6c0] start time for stream 2 is not set in estimate_timings_from_pts
    Last message repeated 1 times
[mpegts @ 032628e0] Could not find codec parameters for stream 2 (Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels, s16p): unspecified frame size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mpegts @ 032628e0] Could not find codec parameters for stream 5 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec
[mpegts @ 032628e0] Could not find codec parameters for stream 6 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 032628e0] Could not find codec parameters for stream 7 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 032628e0] Could not find codec parameters for stream 8 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 032628e0] Could not find codec parameters for stream 9 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 032628e0] Could not find codec parameters for stream 10 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec
Input #0, mpegts, from 'e:\tv temp\eastenders - s32e178.ts':
  Duration: 00:29:59.25, start: 47750.371533, bitrate: 2929 kb/s
  Program 4169
    Stream #0:0[0x65]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv), 704x576 [SAR 16:11 DAR 16:9], max. 15000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x66](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 256 kb/s
    Stream #0:2[0x6a](eng): Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels, s16p (visual impaired)
    Stream #0:3[0x69](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006)
    Stream #0:4[0x98]: Audio: mp2 ([6][0][0][0] / 0x0006), 48000 Hz, stereo, s16p, 128 kb/s
    Stream #0:5[0x96]: Unknown: none ([5][0][0][0] / 0x0005)
    Stream #0:6[0x1c21]: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:7[0x1c24]: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:8[0x1c33]: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:9[0x1ce9]: Unknown: none ([11][0][0][0] / 0x000B)
    Stream #0:10[0x1c66]: Unknown: none ([5][0][0][0] / 0x0005)
Complete name                            : E:\TV Temp\EastEnders - S32E178.ts
Format                                   : MPEG-TS
File size                                : 628 MiB
Duration                                 : 29 min 58 s
Overall bit rate                         : 2 930 kb/s
Menu ID                                  : 4169 (0x1049)
Format                                   : MPEG Video
Format profile                           : Main@Main
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : M=3, N=24
Format settings, picture structure       : Frame
Codec ID                                 : 2
Bit rate                                 : 2 333 kb/s
Maximum bit rate                         : 15.0 Mb/s
Width                                    : 704 pixels
Height                                   : 576 pixels
Active Format Description                : Letterbox 16:9 image, with alternative 14:9 center
Frame rate                               : 25.000 FPS
Standard                                 : PAL
Scan type                                : Interlaced
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.230
Stream size                              : 500 MiB (80%)
Audio #1
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 2
Codec ID                                 : 3
Bit rate                                 : 256 kb/s
Sampling rate                            : 48.0 kHz
Delay relative to video                  : -576 ms
Stream size                              : 54.9 MiB (9%)
descriptor_tag_extension                 : 6
Audio #2
Format                                   : MPEG Audio
Codec ID                                 : 3
Duration                                 : 12 s 912 ms
Bit rate                                 : 64.0 kb/s
Channel(s)                               : 1 channel
Stream size                              : 101 KiB (0%)
Language, more info                      : Visual impaired commentary
Audio #3
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Codec ID                                 : 6
Bit rate                                 : 128 kb/s
Delay relative to video                  : -652 ms
Stream size                              : 27.4 MiB (4%)
Text
Format                                   : DVB Subtitle
Codec ID                                 : 6
Post Fri Nov 11, 2016 4:56 pm
Re: Wrong Duration shown
does it take a long time to copy a file to the destination or were all the files already present in the folder that you later shared in Serviio?
Sometimes Serviio gets the duration from the file as it's being written to the folder (incomplete) and then leaves it like that. FFmpeg shows 29 mins so Serviio should use that.
paul33
Post Fri Nov 11, 2016 6:25 pm
Thanks for the reply
These files are created in the folder
I have Serviio scanning E:\Recorded TV and my recording software writes direct to this, so its possible it picked up the wrong time as it was being recorded (before recording complete)
However, I have seen this on recordings made prior to using Serviio, so they would have been complete when imported
For the above file, this would have been recorded as Eastenders_20161107.ts, when the recording finished I manually renamed it with the Season/Episode, so not sure if this gets seen as a new file after the rename
I cant find a pattern to failings like this, but it happens from other UK channels i record, some work, some have the wrong length
I use NFO's for my metadata, so nothing downloded, not sure if this is relevant or not
Post Sat Nov 12, 2016 1:21 am
I had that Samsung BD player before, and it never displayed the correct release date. Run time might be a similar issue. I believe it's a Samsung issue, not Serviio. Since I no longer have that player, I can't confirm if the firmware was ever updated to fix it.
paul33
Post Sat Nov 12, 2016 1:55 pm
Cheers for the info
Been checking it out on recordings for the last few days, and all of them work fine, with correct duration
If i play on my Roku then everything is perfect, ideally would like to avoid this at it transcodes to much
looks like you are right about the Samsung, for some reason it occasionally cannot get the correct length, would be nice to know why and what is in the file it objects to
paul33
Post Sat Nov 12, 2016 2:07 pm
Not sure if this shows anything
This is last nights file which worked perfetly
C:\Program Files\Serviio\lib>ffmpeg.exe -i "e:\tv temp\eastenders - s32e181.ts"
[mpeg2video @ 04bdc480] Invalid frame dimensions 0x0.
    Last message repeated 8 times
[mpegts @ 036f2920] PES packet size mismatch
    Last message repeated 9 times
[mpegts @ 036f2920] Could not find codec parameters for stream 5 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec
[mpegts @ 036f2920] Could not find codec parameters for stream 6 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 036f2920] Could not find codec parameters for stream 7 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 036f2920] Could not find codec parameters for stream 8 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 036f2920] Could not find codec parameters for stream 9 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec
[mpegts @ 036f2920] Could not find codec parameters for stream 10 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec
Input #0, mpegts, from 'e:\tv temp\eastenders - s32e181.ts':
  Duration: 00:29:59.63, start: 11569.840033, bitrate: 3269 kb/s
  Program 4169
    Stream #0:2[0x6a](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, mono, s16p, 64 kb/s (visual impaired)
Complete name                            : E:\TV Temp\EastEnders - S32E181.ts
Format                                   : MPEG-TS
File size                                : 702 MiB
Duration                                 : 29 min 59 s
Overall bit rate                         : 3 271 kb/s
Format                                   : MPEG Video
Format settings, GOP                     : Variable
Codec ID                                 : 2
Duration                                 : 29 min 47 s
Bit rate                                 : 2 657 kb/s
Width                                    : 704 pixels
Height                                   : 576 pixels
Standard                                 : PAL
Bits/(Pixel*Frame)                       : 0.262
Stream size                              : 566 MiB (81%)
Audio #1
Format                                   : MPEG Audio
Codec ID                                 : 3
Bit rate                                 : 256 kb/s
Delay relative to video                  : -138 ms
Stream size                              : 54.9 MiB (8%)
Audio #2
Format                                   : MPEG Audio
Codec ID                                 : 3
Delay relative to video                  : -234 ms
Stream size                              : 13.7 MiB (2%)
Audio #3
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Codec ID                                 : 6
Bit rate                                 : 128 kb/s
Delay relative to video                  : -189 ms
Stream size                              : 27.5 MiB (4%)
Text
Codec ID                                 : 6
Duration                                 : 29 min 42 s
Delay relative to video                  : 15 s 982 ms
