Working VLC audio streams not works in Serviio
http://shoutcast.radio24.it:8000/listen.pls
http://radiodeejay-lh.akamaihd.net/i/Ra ... aster.m3u8
http://icy.unitedradio.it/105Hits.mp3.m3u
Thanks for the support.
minimega
#EXTM3U
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=48000,CODECS="mp4a.40.2"
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/index_48_a-p.m3u8?sd=10&rebase=on
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/index_48_a-b.m3u8?sd=10&rebase=on
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=64000,CODECS="mp4a.40.2"
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/index_64_a-p.m3u8?sd=10&rebase=on
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/index_64_a-b.m3u8?sd=10&rebase=on
#EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=96000,CODECS="mp4a.40.2"
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/index_96_a-p.m3u8?sd=10&rebase=on
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/index_96_a-b.m3u8?sd=10&rebase=on
#EXTM3U
#EXT-X-TARGETDURATION:10
#EXT-X-ALLOW-CACHE:YES
#EXT-X-VERSION:3
#EXT-X-MEDIA-SEQUENCE:7794645
#EXTINF:10.000,
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/segment7794645_48_a-p.ts?sd=10
#EXTINF:10.000,
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/segment7794646_48_a-p.ts?sd=10
#EXTINF:10.000,
http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/segment7794647_48_a-p.ts?sd=10
zip wrote:Oh, they are HLS streams. They are not supported yet, but there is a ticket: https://bitbucket.org/xnejp03/serviio/i ... -hls-files
Format : MPEG Audio
File size : 780 KiB
Writing library : Lavf57.25.100
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Compression mode : Lossy
Stream size : 780 KiB (100%)
