serviio server keeps stopping
reiga
Post Wed Nov 30, 2016 1:02 pm
Hi, ive got a problem with the server not running.
i kinda had solved the problem with enabling mini dump(after long time of research) and was ok for a while and same problem started happening again and nothing has worked since.. server stats and after a minute or so it just stops with an error log..
my error log is as below;
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_IN_PAGE_ERROR (0xc0000006) at pc=0x033bd70a, pid=6288, tid=9596
# JRE version: Java(TM) SE Runtime Environment (8.0_91-b15) (build 1.8.0_91-b15)
# Java VM: Java HotSpot(TM) Client VM (25.91-b15 mixed mode windows-x86 )
# Problematic frame:
# J 2510 C1 java.nio.DirectLongBufferU.get()J (15 bytes) @ 0x033bd70a [0x033bd6d0+0x3a]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x280dbc00): JavaThread "Thread-86" daemon [_thread_in_Java, id=9596, stack(0x2dd50000,0x2dda0000)]
siginfo: ExceptionCode=0xc0000006, ExceptionInformation=0x00000000 0x00e1b800 0xc000009c
Registers:
EAX=0x00000000, EBX=0x2720f700, ECX=0x00000000, EDX=0x00000000
ESP=0x2dd9f6b0, EBP=0x2dd9f720, ESI=0x00e1b800, EDI=0x033bd6e0
EIP=0x033bd70a, EFLAGS=0x00010246
Top of Stack: (sp=0x2dd9f6b0)
0x2dd9f6b0: 00000000 ffffffff 06d37410 06d37470
0x2dd9f6c0: 06d37470 2dd9f6c4 2d250059 2dd9f6fc
0x2dd9f6d0: 2d250838 00000000 2d250080 00000000
0x2dd9f6e0: 2dd9f6fc 2dd9f720 2dd9f720 02f64580
0x2dd9f6f0: 02f64580 06d37470 00000000 00000000
0x2dd9f700: 2dd9f700 2e02b4ee 2dd9f734 2e02b6a8
0x2dd9f710: 00000000 2e02b528 2dd9f6f4 2dd9f734
0x2dd9f720: 2dd9f758 02f64580 00000000 00000000
Instructions: (pc=0x033bd70a)
0x033bd6ea: 38 8b 41 14 8b 51 18 3b c2 0f 8d 27 00 00 00 8b
0x033bd6fa: d0 42 89 51 14 8b 71 08 8b 51 0c 8b c8 c1 f9 1f
0x033bd70a: 8b 14 c6 8b 4c c6 04 8b c2 8b d1 83 c4 38 5d 85
0x033bd71a: 05 00 01 29 01 c3 89 4c 24 2c 0f 1f 40 00 e9 26
Register to memory mapping:
EAX=0x00000000 is an unknown value
EBX={method} {0x2720f704} 'get' '()J' in 'java/nio/DirectLongBufferU'
ECX=0x00000000 is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x2dd9f6b0 is pointing into the stack for thread: 0x280dbc00
EBP=0x2dd9f720 is pointing into the stack for thread: 0x280dbc00
ESI=0x00e1b800 is an unknown value
EDI=0x033bd6e0 is at entry_point+16 in (nmethod*)0x033bd5c8
Stack: [0x2dd50000,0x2dda0000], sp=0x2dd9f6b0, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j org.serviio.delivery.subtitles.OpenSubtitlesHasher.computeHashForChunk(Ljava/nio/ByteBuffer;)J+22
j org.serviio.delivery.subtitles.OpenSubtitlesHasher.computeHash(Ljava/io/File;)Ljava/lang/String;+63
j org.serviio.delivery.subtitles.OpenSubtitlesService.generateHash(Ljava/io/File;)Ljava/lang/String;+31
j org.serviio.library.local.metadata.extractor.embedded.VideoExtractionStrategy.extractMetadata(Lorg/serviio/library/local/metadata/VideoMetadata;Ljava/io/File;)V+96
j org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveVideoMetadata(Ljava/io/File;Lorg/serviio/library/local/metadata/LocalItemMetadata;)V+14
j org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveMetadata(Lorg/serviio/library/local/metadata/extractor/MetadataFile;Lorg/serviio/library/local/metadata/LocalItemMetadata;)V+43
j org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(Ljava/io/File;Lorg/serviio/library/metadata/MediaFileType;Lorg/serviio/library/entities/Repository;)Lorg/serviio/library/local/metadata/LocalItemMetadata;+38
j org.serviio.library.local.MetadataExtractionCoordinator.extractMetadata(Ljava/io/File;Lorg/serviio/library/metadata/MediaFileType;Lorg/serviio/library/entities/Repository;)Ljava/util/Optional;+70
j org.serviio.library.local.indexing.MediaFileIndexer.addNewMediaFile(Lorg/serviio/library/entities/Repository;Ljava/io/File;Z)V+113
J 2088 C1 org.serviio.library.local.indexing.DefaultLibraryMonitor.fileAdded(Ljava/io/File;Lorg/serviio/library/entities/Repository;Z)V (82 bytes) @ 0x0330be70 [0x0330b5d0+0x8a0]
J 2082 C1 org.serviio.library.local.indexing.pipe.PipeManager$PipeProcessingConsumer.lambda$run$9(Lorg/serviio/library/local/indexing/pipe/FileOperation;)V (137 bytes) @ 0x0330a3e0 [0x0330a260+0x180]
J 2081 C1 org.serviio.library.local.indexing.pipe.PipeManager$PipeProcessingConsumer$$Lambda$19.accept(Ljava/lang/Object;)V (12 bytes) @ 0x03309fd0 [0x03309f90+0x40]
J 2080 C1 java.util.Optional.ifPresent(Ljava/util/function/Consumer;)V (18 bytes) @ 0x03309dc8 [0x03309d90+0x38]
j org.serviio.library.local.indexing.pipe.PipeManager$PipeProcessingConsumer.run()V+48
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
V [jvm.dll+0x159425]
V [jvm.dll+0x21f02e]
V [jvm.dll+0x1594be]
V [jvm.dll+0x159646]
V [jvm.dll+0x1596b7]
V [jvm.dll+0xfdd2f]
V [jvm.dll+0x17c8ec]
V [jvm.dll+0x17c9da]
V [jvm.dll+0x1c0fd6]
C [msvcr100.dll+0x10fac]
C [msvcr100.dll+0x110b1]
C [KERNEL32.DLL+0x162c4]
C [ntdll.dll+0x60719]
C [ntdll.dll+0x606e4]
C 0x00000000
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x28498c00 JavaThread "DestroyJavaVM" [_thread_blocked, id=6492, stack(0x01240000,0x01290000)]
0x280de800 JavaThread "PlaylistMaintainerThread" daemon [_thread_blocked, id=4744, stack(0x2df90000,0x2dfe0000)]
0x280dd800 JavaThread "Thread-89" [_thread_blocked, id=7756, stack(0x2df00000,0x2df50000)]
0x280dc400 JavaThread "Thread-88" daemon [_thread_blocked, id=6240, stack(0x2de70000,0x2dec0000)]
0x280dfc00 JavaThread "Thread-87" daemon [_thread_blocked, id=600, stack(0x2dde0000,0x2de30000)]
=>0x280dbc00 JavaThread "Thread-86" daemon [_thread_in_Java, id=9596, stack(0x2dd50000,0x2dda0000)]
0x280e1c00 JavaThread "RepositoryStatusThread" daemon [_thread_blocked, id=1680, stack(0x2dcc0000,0x2dd10000)]
0x280dd000 JavaThread "FeedUpdaterThread" daemon [_thread_blocked, id=6400, stack(0x2dc30000,0x2dc80000)]
0x280e1000 JavaThread "pool-8-thread-10" [_thread_blocked, id=7908, stack(0x2dba0000,0x2dbf0000)]
0x280ddc00 JavaThread "pool-8-thread-9" [_thread_blocked, id=6440, stack(0x2db10000,0x2db60000)]
0x280db000 JavaThread "pool-8-thread-8" [_thread_blocked, id=5760, stack(0x2da80000,0x2dad0000)]
0x280dac00 JavaThread "pool-8-thread-7" [_thread_blocked, id=9488, stack(0x2d9f0000,0x2da40000)]
0x280de400 JavaThread "Thread-83" daemon [_thread_in_native, id=4824, stack(0x2b920000,0x2b970000)]
0x280db800 JavaThread "ServioThread-9-CDS library notifier" daemon [_thread_blocked, id=6472, stack(0x2b790000,0x2b7e0000)]
0x280e1400 JavaThread "Notifier: Thread-82" [_thread_blocked, id=10004, stack(0x2d960000,0x2d9b0000)]
0x280e0800 JavaThread "Notifier: Thread-81" [_thread_blocked, id=1752, stack(0x2d8d0000,0x2d920000)]
0x280e2000 JavaThread "Notifier: Thread-80" [_thread_blocked, id=7524, stack(0x2d840000,0x2d890000)]
0x280e0400 JavaThread "Dispatcher: Thread-79" [_thread_blocked, id=6408, stack(0x2d7b0000,0x2d800000)]
0x280dc800 JavaThread "Dispatcher: Thread-78" [_thread_blocked, id=10148, stack(0x2d720000,0x2d770000)]
0x2778a800 JavaThread "Dispatcher: Thread-77" [_thread_blocked, id=7612, stack(0x2d690000,0x2d6e0000)]
0x2778a000 JavaThread "Dispatcher: Thread-76" [_thread_blocked, id=824, stack(0x2d600000,0x2d650000)]
0x27789000 JavaThread "Dispatcher: Thread-75" [_thread_blocked, id=6664, stack(0x2d570000,0x2d5c0000)]
0x27788800 JavaThread "Dispatcher: Thread-74" [_thread_blocked, id=9884, stack(0x2d4e0000,0x2d530000)]
0x27788000 JavaThread "Dispatcher: Thread-73" [_thread_blocked, id=5796, stack(0x2d450000,0x2d4a0000)]
0x27787c00 JavaThread "Dispatcher: Thread-72" [_thread_blocked, id=5172, stack(0x2d3c0000,0x2d410000)]
0x27787000 JavaThread "Dispatcher: Thread-71" [_thread_blocked, id=4144, stack(0x2d330000,0x2d380000)]
0x27786800 JavaThread "Dispatcher: Thread-70" [_thread_blocked, id=2420, stack(0x2d2a0000,0x2d2f0000)]
0x27789c00 JavaThread "Reader: Thread-69" [_thread_blocked, id=9508, stack(0x2d110000,0x2d160000)]
0x2778e000 JavaThread "Dispatcher: Thread-68" [_thread_blocked, id=9076, stack(0x2d080000,0x2d0d0000)]
0x2778d800 JavaThread "Reader: Thread-67" [_thread_blocked, id=9732, stack(0x2cff0000,0x2d040000)]
0x2778d400 JavaThread "Reader: Thread-66" [_thread_blocked, id=1696, stack(0x2ce60000,0x2ceb0000)]
0x2778cc00 JavaThread "Reader: Thread-65" [_thread_blocked, id=3084, stack(0x2cdd0000,0x2ce20000)]
0x2778c000 JavaThread "Dispatcher: Thread-64" [_thread_blocked, id=9020, stack(0x2cd40000,0x2cd90000)]
0x2778bc00 JavaThread "Dispatcher: Thread-63" [_thread_blocked, id=9972, stack(0x2ccb0000,0x2cd00000)]
0x27789400 JavaThread "Reader: Thread-62" [_thread_blocked, id=4828, stack(0x2cc20000,0x2cc70000)]
0x2778ac00 JavaThread "Dispatcher: Thread-61" [_thread_blocked, id=3596, stack(0x2cb90000,0x2cbe0000)]
0x2778b400 JavaThread "Reader: Thread-60" [_thread_blocked, id=1064, stack(0x2cb00000,0x2cb50000)]
0x2778c800 JavaThread "Reader: Thread-59" [_thread_blocked, id=3024, stack(0x2ca70000,0x2cac0000)]
0x27787400 JavaThread "Reader: Thread-58" [_thread_blocked, id=7260, stack(0x2c9e0000,0x2ca30000)]
0x2a39d000 JavaThread "Reader: Thread-57" [_thread_blocked, id=2184, stack(0x2c950000,0x2c9a0000)]
0x2a39cc00 JavaThread "Dispatcher: Thread-56" [_thread_blocked, id=7932, stack(0x2c7c0000,0x2c810000)]
0x2a39b800 JavaThread "Reader: Thread-55" [_thread_blocked, id=9356, stack(0x2c730000,0x2c780000)]
0x2a39c000 JavaThread "Dispatcher: Thread-54" [_thread_blocked, id=6032, stack(0x2c6a0000,0x2c6f0000)]
0x2a39b400 JavaThread "Reader: Thread-53" [_thread_blocked, id=5148, stack(0x2c610000,0x2c660000)]
0x2a395c00 JavaThread "Reader: Thread-52" [_thread_blocked, id=7216, stack(0x2c580000,0x2c5d0000)]
0x2a39ac00 JavaThread "Notifier: Thread-51" [_thread_blocked, id=9820, stack(0x2c4f0000,0x2c540000)]
0x2a39a000 JavaThread "Reader: Thread-50" [_thread_blocked, id=4492, stack(0x2c460000,0x2c4b0000)]
0x2a399800 JavaThread "Notifier: Thread-49" [_thread_blocked, id=864, stack(0x2c3d0000,0x2c420000)]
0x2a399400 JavaThread "Reader: Thread-48" [_thread_blocked, id=2608, stack(0x2c340000,0x2c390000)]
0x2a398c00 JavaThread "Dispatcher: Thread-47" [_thread_blocked, id=10196, stack(0x2c2b0000,0x2c300000)]
0x2a39c400 JavaThread "Reader: Thread-46" [_thread_blocked, id=4392, stack(0x2c220000,0x2c270000)]
0x2a396800 JavaThread "Dispatcher: Thread-45" [_thread_blocked, id=3924, stack(0x2c190000,0x2c1e0000)]
0x2a397800 JavaThread "Reader: Thread-44" [_thread_blocked, id=5344, stack(0x2c100000,0x2c150000)]
0x2a396c00 JavaThread "Reader: Thread-43" [_thread_blocked, id=6608, stack(0x2c070000,0x2c0c0000)]
0x2a396000 JavaThread "Dispatcher: Thread-42" [_thread_blocked, id=4928, stack(0x2bfe0000,0x2c030000)]
0x2a398800 JavaThread "Reader: Thread-41" [_thread_blocked, id=9476, stack(0x2bf50000,0x2bfa0000)]
0x2a398000 JavaThread "Reader: Thread-40" [_thread_blocked, id=5780, stack(0x2bec0000,0x2bf10000)]
0x2a39a400 JavaThread "Dispatcher: Thread-39" [_thread_blocked, id=9160, stack(0x2be30000,0x2be80000)]
0x2a397400 JavaThread "Reader: Thread-38" [_thread_blocked, id=2636, stack(0x2bda0000,0x2bdf0000)]
0x28412800 JavaThread "Notifier: Thread-37" [_thread_blocked, id=8052, stack(0x2bd10000,0x2bd60000)]
0x28411400 JavaThread "pool-8-thread-6" [_thread_blocked, id=516, stack(0x2bc80000,0x2bcd0000)]
0x28416800 JavaThread "pool-8-thread-5" [_thread_blocked, id=6648, stack(0x2bbf0000,0x2bc40000)]
0x28411000 JavaThread "pool-8-thread-4" [_thread_blocked, id=10020, stack(0x2bb60000,0x2bbb0000)]
0x28416000 JavaThread "pool-8-thread-3" [_thread_blocked, id=6796, stack(0x2bad0000,0x2bb20000)]
0x28413000 JavaThread "pool-8-thread-2" [_thread_blocked, id=4396, stack(0x2ba40000,0x2ba90000)]
0x2840f800 JavaThread "pool-8-thread-1" [_thread_blocked, id=7632, stack(0x2b9b0000,0x2ba00000)]
0x28414000 JavaThread "ServioThread-7-null" daemon [_thread_blocked, id=5848, stack(0x2b600000,0x2b650000)]
0x28410800 JavaThread "ServioThread-6-RendererExpirationChecker" daemon [_thread_blocked, id=8164, stack(0x2b470000,0x2b4c0000)]
0x28413400 JavaThread "ServioThread-5-DiscoveryNotifier" daemon [_thread_blocked, id=8564, stack(0x2b3e0000,0x2b430000)]
0x28414800 JavaThread "ServioThread-4-EventDispatcher" daemon [_thread_blocked, id=1456, stack(0x2b350000,0x2b3a0000)]
0x28415c00 JavaThread "ServioThread-3-SubscriptionExpiryChecker" daemon [_thread_blocked, id=8156, stack(0x2a2f0000,0x2a340000)]
0x28411c00 JavaThread "ServioThread-2-DiscoverySSDPMessageListener" daemon [_thread_blocked, id=2924, stack(0x2a260000,0x2a2b0000)]
0x28415400 JavaThread "WebServer" [_thread_in_native, id=9028, stack(0x2a140000,0x2a190000)]
0x28413c00 JavaThread "pool-7-thread-1" [_thread_blocked, id=5140, stack(0x2a0b0000,0x2a100000)]
0x28416c00 JavaThread "PluginCompilerThread" daemon [_thread_blocked, id=4464, stack(0x2a020000,0x2a070000)]
0x28415000 JavaThread "ServioThread-1-CDS library notifier" daemon [_thread_blocked, id=1936, stack(0x29f90000,0x29fe0000)]
0x2840fc00 JavaThread "ElementEventQueue.QProcessor-1" daemon [_thread_blocked, id=7552, stack(0x29d00000,0x29d50000)]
0x28396c00 JavaThread "Thread-22" daemon [_thread_blocked, id=9792, stack(0x29b30000,0x29b80000)]
0x28395000 JavaThread "ActionDistributor: Thread-21" [_thread_blocked, id=8764, stack(0x29aa0000,0x29af0000)]
0x28394c00 JavaThread "ActionDistributor: Thread-19" [_thread_blocked, id=2684, stack(0x29a10000,0x29a60000)]
0x28393400 JavaThread "ActionDistributor: Thread-18" [_thread_blocked, id=1380, stack(0x29980000,0x299d0000)]
0x28396000 JavaThread "FileManager: Thread-17" [_thread_blocked, id=4460, stack(0x298d0000,0x29920000)]
0x28395800 JavaThread "ActionDistributor: Thread-16" [_thread_blocked, id=1152, stack(0x29840000,0x29890000)]
0x28396400 JavaThread "ActionDistributor: Thread-14" [_thread_blocked, id=5464, stack(0x297b0000,0x29800000)]
0x28393800 JavaThread "ActionDistributor: Thread-13" [_thread_blocked, id=7972, stack(0x29720000,0x29770000)]
0x28394400 JavaThread "FileManager: Thread-12" [_thread_blocked, id=1304, stack(0x29690000,0x296e0000)]
0x28394000 JavaThread "ActionDistributor: Thread-11" [_thread_blocked, id=6344, stack(0x29600000,0x29650000)]
0x27f4e400 JavaThread "ActionDistributor: Thread-9" [_thread_blocked, id=8616, stack(0x29570000,0x295c0000)]
0x27f4dc00 JavaThread "ActionDistributor: Thread-8" [_thread_blocked, id=5664, stack(0x294e0000,0x29530000)]
0x27f4d800 JavaThread "FileManager: Thread-7" [_thread_blocked, id=3616, stack(0x29450000,0x294a0000)]
0x2832cc00 JavaThread "ActionDistributor: Thread-6" [_thread_in_native, id=1684, stack(0x292c0000,0x29310000)]
0x27f43800 JavaThread "ActionDistributor: Thread-4" [_thread_blocked, id=5876, stack(0x29230000,0x29280000)]
0x282eb000 JavaThread "ActionDistributor: Thread-3" [_thread_in_native, id=848, stack(0x291a0000,0x291f0000)]
0x282ad800 JavaThread "FileManager: Thread-2" [_thread_blocked, id=7192, stack(0x29010000,0x29060000)]
0x28111800 JavaThread "derby.rawStoreDaemon" daemon [_thread_blocked, id=5764, stack(0x28b80000,0x28bd0000)]
0x28083400 JavaThread "Timer-0" daemon [_thread_blocked, id=3728, stack(0x289f0000,0x28a40000)]
0x27f41400 JavaThread "Instance checker" daemon [_thread_in_native, id=1260, stack(0x28740000,0x28790000)]
0x277a8000 JavaThread "Service Thread" daemon [_thread_blocked, id=512, stack(0x27e20000,0x27e70000)]
0x27772000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=400, stack(0x27d90000,0x27de0000)]
0x27771800 JavaThread "Attach Listener" daemon [_thread_blocked, id=6800, stack(0x27d00000,0x27d50000)]
0x27771400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5536, stack(0x27c70000,0x27cc0000)]
0x27770c00 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=9072, stack(0x27be0000,0x27c30000)]
0x27735800 JavaThread "Finalizer" daemon [_thread_blocked, id=4240, stack(0x27630000,0x27680000)]
0x2772b800 JavaThread "Reference Handler" daemon [_thread_blocked, id=6016, stack(0x275a0000,0x275f0000)]
Other Threads:
0x27717400 VMThread [stack: 0x27510000,0x27560000] [id=9156]
0x27805c00 WatcherThread [stack: 0x27eb0000,0x27f00000] [id=5480]
VM state:synchronizing (normal execution)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x02f5ce50] Safepoint_lock - owner thread: 0x27717400
[0x02f5c768] Threads_lock - owner thread: 0x27717400
Heap:
garbage-first heap total 22528K, used 16509K [0x05a00000, 0x05b00058, 0x25a00000)
region size 1024K, 4 young (4096K), 1 survivors (1024K)
Metaspace used 18912K, capacity 19145K, committed 19200K, reserved 19840K
Heap Regions: (Y=young(eden), SU=young(survivor), HS=humongous(starts), HC=humongous(continues), CS=collection set, F=free, TS=gc time stamp, PTAMS=previous top-at-mark-start, NTAMS=next top-at-mark-start)
AC 0 O TS 0 PTAMS 0x05b00000 NTAMS 0x05b00000 space 1024K, 100% used [0x05a00000, 0x05b00000)
AC 0 O TS 0 PTAMS 0x05c00000 NTAMS 0x05c00000 space 1024K, 100% used [0x05b00000, 0x05c00000)
AC 0 F TS 0 PTAMS 0x05c00000 NTAMS 0x05c00000 space 1024K, 0% used [0x05c00000, 0x05d00000)
AC 0 O TS 0 PTAMS 0x05e00000 NTAMS 0x05e00000 space 1024K, 100% used [0x05d00000, 0x05e00000)
AC 0 O TS 0 PTAMS 0x05f00000 NTAMS 0x05f00000 space 1024K, 100% used [0x05e00000, 0x05f00000)
AC 0 O TS 0 PTAMS 0x06000000 NTAMS 0x06000000 space 1024K, 100% used [0x05f00000, 0x06000000)
AC 0 O TS 0 PTAMS 0x06100000 NTAMS 0x06100000 space 1024K, 100% used [0x06000000, 0x06100000)
AC 0 O TS 0 PTAMS 0x06200000 NTAMS 0x06200000 space 1024K, 100% used [0x06100000, 0x06200000)
AC 0 O TS 0 PTAMS 0x06300000 NTAMS 0x06300000 space 1024K, 100% used [0x06200000, 0x06300000)
AC 0 O TS 0 PTAMS 0x06400000 NTAMS 0x06400000 space 1024K, 100% used [0x06300000, 0x06400000)
AC 0 O TS 0 PTAMS 0x06500000 NTAMS 0x06500000 space 1024K, 100% used [0x06400000, 0x06500000)
AC 0 O TS 0 PTAMS 0x065f0c00 NTAMS 0x065f0c00 space 1024K, 94% used [0x06500000, 0x06600000)
AC 0 O TS 0 PTAMS 0x06700000 NTAMS 0x06700000 space 1024K, 100% used [0x06600000, 0x06700000)
AC 0 O TS 0 PTAMS 0x06800000 NTAMS 0x06800000 space 1024K, 100% used [0x06700000, 0x06800000)
AC 0 F TS 0 PTAMS 0x06800000 NTAMS 0x06800000 space 1024K, 0% used [0x06800000, 0x06900000)
AC 0 O TS 0 PTAMS 0x06a00000 NTAMS 0x06a00000 space 1024K, 100% used [0x06900000, 0x06a00000)
AC 0 F TS 0 PTAMS 0x06a00000 NTAMS 0x06a00000 space 1024K, 0% used [0x06a00000, 0x06b00000)
AC 0 F TS 0 PTAMS 0x06b00000 NTAMS 0x06b00000 space 1024K, 0% used [0x06b00000, 0x06c00000)
AC 0 S CS TS 0 PTAMS 0x06c00000 NTAMS 0x06c00000 space 1024K, 18% used [0x06c00000, 0x06d00000)
AC 0 E TS 0 PTAMS 0x06d00000 NTAMS 0x06d00000 space 1024K, 63% used [0x06d00000, 0x06e00000)
AC 0 E CS TS 0 PTAMS 0x06e00000 NTAMS 0x06e00000 space 1024K, 100% used [0x06e00000, 0x06f00000)
AC 0 E CS TS 0 PTAMS 0x06f00000 NTAMS 0x06f00000 space 1024K, 100% used [0x06f00000, 0x07000000)
Card table byte_map: [0x25b00000,0x25c00000] byte_map_base: 0x25ad3000
Marking Bits (Prev, Next): (CMBitMap*) 0x02e04de0, (CMBitMap*) 0x02e04e0c
Prev Bits: [0x25d00000, 0x26500000)
Next Bits: [0x26500000, 0x26d00000)
Polling page: 0x01290000
CodeCache: size=32768Kb used=4469Kb max_used=4469Kb free=28298Kb
bounds [0x02f60000, 0x033c0000, 0x04f60000]
total_blobs=2759 nmethods=2485 adapters=203
compilation: enabled
Compilation events (10 events):
Event: 50.703 Thread 0x27772000 2507 s com.google.gson.ParameterizedTypeHandlerMap::registerIfAbsent (151 bytes)
Event: 50.704 Thread 0x27772000 nmethod 2507 0x033bc408 code [0x033bc5f0, 0x033bcaf8]
Event: 50.704 Thread 0x27772000 2508 java.util.LinkedList::listIterator (15 bytes)
Event: 50.705 Thread 0x27772000 nmethod 2508 0x033bcf88 code [0x033bd0a0, 0x033bd244]
Event: 60.159 Thread 0x27772000 2509 java.nio.Buffer::nextGetIndex (31 bytes)
Event: 60.159 Thread 0x27772000 nmethod 2509 0x033bd348 code [0x033bd450, 0x033bd52c]
Event: 60.159 Thread 0x27772000 2510 java.nio.DirectLongBufferU::get (15 bytes)
Event: 60.160 Thread 0x27772000 nmethod 2510 0x033bd5c8 code [0x033bd6d0, 0x033bd7cc]
Event: 60.160 Thread 0x27772000 2511 org.serviio.delivery.subtitles.OpenSubtitlesHasher::computeHashForChunk (32 bytes)
Event: 60.160 Thread 0x27772000 nmethod 2511 0x033bd888 code [0x033bd9b0, 0x033bdad4]
GC Heap History (10 events):
Event: 41.963 GC heap before
{Heap before GC invocations=162 (full 0):
garbage-first heap total 22528K, used 17388K [0x05a00000, 0x05b00058, 0x25a00000)
Metaspace used 18818K, capacity 19045K, committed 19072K, reserved 19840K
Event: 41.963 GC heap after
Heap after GC invocations=163 (full 0):
garbage-first heap total 22528K, used 14351K [0x05a00000, 0x05b00058, 0x25a00000)
region size 1024K, 1 young (1024K), 1 survivors (1024K)
Event: 42.025 GC heap before
{Heap before GC invocations=163 (full 0):
garbage-first heap total 22528K, used 17423K [0x05a00000, 0x05b00058, 0x25a00000)
Event: 42.026 GC heap after
Heap after GC invocations=164 (full 0):
garbage-first heap total 22528K, used 14352K [0x05a00000, 0x05b00058, 0x25a00000)
Event: 42.091 GC heap before
{Heap before GC invocations=165 (full 0):
garbage-first heap total 22528K, used 17424K [0x05a00000, 0x05b00058, 0x25a00000)
Event: 42.091 GC heap after
Heap after GC invocations=166 (full 0):
garbage-first heap total 22528K, used 14363K [0x05a00000, 0x05b00058, 0x25a00000)
Event: 42.148 GC heap before
{Heap before GC invocations=166 (full 0):
garbage-first heap total 22528K, used 17435K [0x05a00000, 0x05b00058, 0x25a00000)
Event: 42.149 GC heap after
Heap after GC invocations=167 (full 0):
garbage-first heap total 22528K, used 14388K [0x05a00000, 0x05b00058, 0x25a00000)
Event: 45.708 GC heap before
{Heap before GC invocations=167 (full 0):
garbage-first heap total 22528K, used 17460K [0x05a00000, 0x05b00058, 0x25a00000)
Metaspace used 18822K, capacity 19049K, committed 19072K, reserved 19840K
Event: 45.710 GC heap after
Heap after GC invocations=168 (full 0):
garbage-first heap total 22528K, used 14461K [0x05a00000, 0x05b00058, 0x25a00000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 2.049 Thread 0x02f5e400 Exception <a 'java/lang/NullPointerException'> (0x06fa97c0) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 2.800 Thread 0x28413c00 Exception <a 'java/lang/ClassNotFoundException': sun/net/www/content/application/xml> (0x06dd1e20) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\classfile\systemDictionary.cpp, line 210]
Event: 8.821 Thread 0x28410400 Exception <a 'java/net/SocketTimeoutException': Receive timed out> (0x06b00840) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\prims\jni.cpp, line 735]
Event: 10.745 Thread 0x2a398c00 Implicit null exception at 0x0319315f to 0x03194995
Event: 19.205 Thread 0x2778c000 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x06f05018) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 23.788 Thread 0x280e0400 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x06a87708) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 23.788 Thread 0x280e0400 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x06a89408) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 29.025 Thread 0x02f5e400 Implicit null exception at 0x032185a5 to 0x0321889a
Event: 48.992 Thread 0x28412400 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x06f17c28) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\prims\jvm.cpp, line 3215]
Event: 60.148 Thread 0x28497c00 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x06ec0188) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u91\7017\hotspot\src\share\vm\prims\jvm.cpp, line 3215]
Events (10 events):
Event: 60.157 loading class sun/nio/ch/FileChannelImpl$Unmapper
Event: 60.157 loading class sun/nio/ch/FileChannelImpl$Unmapper done
Event: 60.157 loading class sun/nio/ch/Util$4
Event: 60.157 loading class sun/nio/ch/Util$4 done
Event: 60.157 loading class java/nio/DirectByteBufferR
Event: 60.158 loading class java/nio/DirectByteBufferR done
Event: 60.158 loading class java/nio/DirectLongBufferRU
Event: 60.158 loading class java/nio/DirectLongBufferRU done
Event: 60.158 Executing VM operation: Deoptimize
Event: 60.158 Executing VM operation: Deoptimize done
Dynamic libraries:
0x00830000 - 0x00863000 C:\Program Files\Serviio\jre\bin\javaw.exe
0x77360000 - 0x774e2000 C:\WINDOWS\SYSTEM32\ntdll.dll
0x76f00000 - 0x76fe0000 C:\WINDOWS\System32\KERNEL32.DLL
0x77000000 - 0x771a1000 C:\WINDOWS\System32\KERNELBASE.dll
0x76c10000 - 0x76c87000 C:\WINDOWS\System32\ADVAPI32.dll
0x74fa0000 - 0x7505e000 C:\WINDOWS\System32\msvcrt.dll
0x746b0000 - 0x746f1000 C:\WINDOWS\System32\sechost.dll
0x753f0000 - 0x754b1000 C:\WINDOWS\System32\RPCRT4.dll
0x73e20000 - 0x73e3e000 C:\WINDOWS\System32\SspiCli.dll
0x73e10000 - 0x73e1a000 C:\WINDOWS\System32\CRYPTBASE.dll
0x76e00000 - 0x76e5a000 C:\WINDOWS\System32\bcryptPrimitives.dll
0x754c0000 - 0x7561f000 C:\WINDOWS\System32\USER32.dll
0x75060000 - 0x75075000 C:\WINDOWS\System32\win32u.dll
0x75760000 - 0x7578b000 C:\WINDOWS\System32\GDI32.dll
0x74c10000 - 0x74d6b000 C:\WINDOWS\System32\gdi32full.dll
0x6fd30000 - 0x6ff3a000 C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_89c64d28dafea4b9\COMCTL32.dll
0x73e40000 - 0x74051000 C:\WINDOWS\System32\combase.dll
0x76d00000 - 0x76de0000 C:\WINDOWS\System32\ucrtbase.dll
0x753c0000 - 0x753e5000 C:\WINDOWS\System32\IMM32.DLL
0x69130000 - 0x691ed000 C:\Program Files\Serviio\jre\bin\msvcr100.dll
0x68390000 - 0x6875a000 C:\Program Files\Serviio\jre\bin\client\jvm.dll
0x74c00000 - 0x74c06000 C:\WINDOWS\System32\PSAPI.DLL
0x73e00000 - 0x73e08000 C:\WINDOWS\SYSTEM32\VERSION.dll
0x71b20000 - 0x71b44000 C:\WINDOWS\SYSTEM32\WINMM.dll
0x6aff0000 - 0x6aff8000 C:\WINDOWS\SYSTEM32\WSOCK32.dll
0x76c90000 - 0x76cf3000 C:\WINDOWS\System32\WS2_32.dll
0x718b0000 - 0x718d3000 C:\WINDOWS\SYSTEM32\WINMMBASE.dll
0x771b0000 - 0x771e6000 C:\WINDOWS\System32\cfgmgr32.dll
0x718a0000 - 0x718ac000 C:\Program Files\Serviio\jre\bin\verify.dll
0x70580000 - 0x705a1000 C:\Program Files\Serviio\jre\bin\java.dll
0x70870000 - 0x70883000 C:\Program Files\Serviio\jre\bin\zip.dll
0x75830000 - 0x76c09000 C:\WINDOWS\System32\SHELL32.dll
0x74060000 - 0x745ce000 C:\WINDOWS\System32\windows.storage.dll
0x75710000 - 0x75755000 C:\WINDOWS\System32\powrprof.dll
0x74ba0000 - 0x74be6000 C:\WINDOWS\System32\shlwapi.dll
0x76fe0000 - 0x76fed000 C:\WINDOWS\System32\kernel.appcore.dll
0x751d0000 - 0x75258000 C:\WINDOWS\System32\shcore.dll
0x76ff0000 - 0x76fff000 C:\WINDOWS\System32\profapi.dll
0x69c60000 - 0x69c76000 C:\Program Files\Serviio\jre\bin\net.dll
0x72bc0000 - 0x72c0e000 C:\WINDOWS\system32\mswsock.dll
0x721d0000 - 0x721e2000 C:\WINDOWS\system32\napinsp.dll
0x721b0000 - 0x721c6000 C:\WINDOWS\system32\pnrpnsp.dll
0x70530000 - 0x70544000 C:\WINDOWS\system32\NLAapi.dll
0x72950000 - 0x729cc000 C:\WINDOWS\SYSTEM32\DNSAPI.dll
0x74bf0000 - 0x74bf7000 C:\WINDOWS\System32\NSI.dll
0x73dd0000 - 0x73dff000 C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
0x721a0000 - 0x721ac000 C:\WINDOWS\System32\winrnr.dll
0x72920000 - 0x72941000 C:\Program Files (x86)\Bonjour\mdnsNSP.dll
0x728d0000 - 0x72919000 C:\WINDOWS\System32\fwpuclnt.dll
0x730a0000 - 0x730bb000 C:\WINDOWS\SYSTEM32\bcrypt.dll
0x72d30000 - 0x72d38000 C:\Windows\System32\rasadhlp.dll
0x71890000 - 0x7189a000 C:\Program Files\Serviio\jre\bin\management.dll
0x70570000 - 0x7057f000 C:\Program Files\Serviio\jre\bin\nio.dll
0x73130000 - 0x73143000 C:\WINDOWS\SYSTEM32\CRYPTSP.dll
0x730f0000 - 0x7311f000 C:\WINDOWS\system32\rsaenh.dll
0x722f0000 - 0x7230a000 C:\WINDOWS\SYSTEM32\USERENV.dll
0x69c40000 - 0x69c60000 C:\Program Files\Serviio\jre\bin\sunec.dll
0x72ba0000 - 0x72bb3000 C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL
0x72b50000 - 0x72b64000 C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL
0x705e0000 - 0x70725000 C:\WINDOWS\SYSTEM32\dbghelp.dll
VM Arguments:
jvm_args: -Xmx512M -Xms20M -XX:+UseG1GC -XX:GCTimeRatio=1 -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade -Dserviio.home=C:\Program Files\Serviio -Dderby.system.home=C:\Program Files\Serviio\library
java_command: org.serviio.MediaServer
java_class_path (initial): C:\Program Files\Serviio\lib\aXMLRPC.jar;C:\Program Files\Serviio\lib\commons-codec.jar;C:\Program Files\Serviio\lib\commons-imaging.jar;C:\Program Files\Serviio\lib\commons-io.jar;C:\Program Files\Serviio\lib\commons-jxpath.jar;C:\Program Files\Serviio\lib\commons-lang.jar;C:\Program Files\Serviio\lib\commons-logging.jar;C:\Program Files\Serviio\lib\concurrent.jar;C:\Program Files\Serviio\lib\derby.jar;C:\Program Files\Serviio\lib\freemarker.jar;C:\Program Files\Serviio\lib\groovy-all.jar;C:\Program Files\Serviio\lib\gson.jar;C:\Program Files\Serviio\lib\httpclient.jar;C:\Program Files\Serviio\lib\httpcore.jar;C:\Program Files\Serviio\lib\icu4j.jar;C:\Program Files\Serviio\lib\imgscalr-lib.jar;C:\Program Files\Serviio\lib\jaudiotagger.jar;C:\Program Files\Serviio\lib\jcl-over-slf4j.jar;C:\Program Files\Serviio\lib\jcs.jar;C:\Program Files\Serviio\lib\jdom.jar;C:\Program Files\Serviio\lib\jISO8601.jar;C:\Program Files\Serviio\lib\jnat-pmplib.jar;C:\Program Files\Serviio\lib\jul-to-slf4j.jar;C:\Program Files\Serviio\lib\log4j.jar;C:\Program Files\Serviio\lib\lucene-analyzers-common.jar;C:\Program Files\Serviio\lib\lucene-core.jar;C:\Program Files\Serviio\lib\org.restlet.ext.gson.jar;C:\Program Files\Serviio\lib\org.restlet.ext.simple.jar;C:\Program Files\Serviio\lib\org.restlet.ext.slf4j.jar;C:\Program Files\Serviio\lib\org.restlet.ext.xstream.jar;C:\Program Files\Serviio\lib\org.restlet.jar;C:\Program Files\Serviio\lib\padlock.jar;C:\Program Files\Serviio\lib\rome-modules.jar;C:\Program Files\Serviio\lib\rome.jar;C:\Program Files\Serviio\lib\sbbi-upnp.jar;C:\Program Files\Serviio\lib\serviio-mediabrowser-api.jar;C:\Program Files\Serviio\lib\serviio-mediabrowser-web.jar;C:\Program Files\Serviio\lib\serviio-web-console-api.jar;C:\Program Files\Serviio\lib\serviio-web-console.jar;C:\Program Files\Serviio\lib\serviio.jar;C:\Program Files\Serviio\lib\simple.jar;C:\Program Files\Serviio\lib\slf4j-api.jar;C:\Program Files\Serviio\lib\slf4j-log4
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Skype\Phone\;C:\Users\Babo\AppData\Local\Microsoft\WindowsApps;
USERNAME=Reiga
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 26 Stepping 5, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 10.0 , 64 bit Build 14393 (10.0.14393.0)
CPU:total 8 (4 cores per cpu, 2 threads per core) family 6 model 26 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht, tsc, tscinvbit, tscinv
Memory: 4k page, physical 12573812k(8997132k free), swap 13360244k(9305424k free)
vm_info: Java HotSpot(TM) Client VM (25.91-b15) for windows-x86 JRE (1.8.0_91-b15), built on May 20 2016 17:33:18 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed Nov 30 22:54:00 2016
elapsed time: 62 seconds (0d 0h 1m 2s)
can you please fix the problem?
Post Wed Nov 30, 2016 2:00 pm
Re: serviio server keeps stopping
No idea what's wrong here, it might be the file it tries to add is very big and it runs out of memory. No idea if this helps, but try to add
-Djdk.nio.maxCachedBufferSize=256000
as a system property. http://www.serviio.org/index.php?option ... e&id=21#q3
Lokotito
Post Thu Jan 25, 2018 11:53 pm
Couple of days ago I had a similar error.
Exception in thread "RepositoryStatusThread" java.lang.NullPointerException
Try to add java_opts="-Djdk.nio.maxCachedBufferSize=256000" (preserving the other values after this).
But serviio keeps stoping:
Shutting down due to severe error.
Exception in thread "pool-10-thread-2" java.lang.NullPointerException
        at org.serviio.renderer.dao.RendererDAOImpl.read(RendererDAOImpl.java:97)
        at org.serviio.renderer.RendererManager.rendererAvailable(RendererManager.java:119)
        at org.serviio.upnp.discovery.RendererAdvertisementProcessor.run(RendererAdvertisementProcessor.java:82)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
This message keeps showing until kill process.
Logs dosn't show any error related, I have to run manually from console but this error persist.
Using serviio 1.9, in debian stretch server. Have 8Gb of ram, 1 hhd of 2Tb, and the bigest file I serve is a mkv x264 about 15Gb more or less.
Any tip how to check wath causing this error ?
edit: My bad, was a permission issue. I shared logs with another user and by mistake change the permissions of another folder in serviio path.
Users browsing this forum: Google [Bot] and 39 guests
