BBC National Radio Channels (UK only)
NX3
Post Mon Jan 09, 2012 7:35 pm
The BBC provide a selection of formats for the online live streams of various national UK radio stations. On the BBC Radio / iplayer website you can select low bandwidth and normal bandwidth but it provides few details.
Looking on Tunein.com for e.g Radio 1 you get 4 options:
http://tunein.com/radio/BBC-Radio-1-England-988-s24939/
WMA 48k, AAC 128k, 56k, 48k
If you get the URL details out of the link you can feed the AAC url's into Serviio as a 'web resource'. For example Radio one AAC 128k url is:
http://bbcmedia.ic.llnwd.net/stream/bbc ... 231cc9c2bf
I found it easier to get the links from this page in the end rather than tunein.com
http://www.listenlive.eu/uk.html
Urza
Post Wed Jan 11, 2012 6:31 am
Re: BBC National Radio Channels (UK only)
Hi there,
Thanks for the info - I have created the AAC BBC Radio URL as an Audio Web Resource in Serviio, but they do not show up when I browse the Online Resource Folder. The AAC Radio URL I'm using is here:
http://bbcmedia.ic.llnwd.net/stream/bbcmedia_lc1_radio1_p?s=1326256281&e=1326270681&h=4b763798a0fa6eb6632a3861600f15cf
Do I need a .groovy plugin for this to work? I have the latest iPlayer.groovy installed, and my iPlayer video feeds all work.
NX3
Post Wed Jan 11, 2012 8:53 am
I didn't use a plugin, they just worked as is in Serviio. To double check, your in the UK ? They probably don't work outside of the UK.
Urza
Post Wed Jan 11, 2012 9:10 am
I do live in the UK. *updates profile*
If I paste the above URL into a Web Browser window, it opens Media Player and starts playing the AAC stream, so I know the link is valid.
No idea why it won't work in Serviio.. :cry:
Also, I have noticed that the URL changes every few hours - for example the BBC Radio 1 AAC URL I used 9 hours ago is different to the one I posted above. Will I need to change the Web Resource URL in Serviio every time I want to use the radio stream?
Post Wed Jan 11, 2012 10:03 am
Urza wrote:Also, I have noticed that the URL changes every few hours - for example the BBC Radio 1 AAC URL I used 9 hours ago is different to the one I posted above. Will I need to change the Web Resource URL in Serviio every time I want to use the radio stream?
Yes :(
NX3
Post Wed Jan 11, 2012 12:58 pm
I'd not noticed that....bit frustrating ! How was the AAC when it was working ? It cut out every 3 seconds for me I found, though super clear when working :) The tv reports as LPCM, I presumed it was being transcoded and cpu couldn't keep up, just guessing though.
Post Wed Jan 11, 2012 12:59 pm
Audio transcoding takes very litle CPU so that should not be that. It's possible that for LPCM playback you need a very steady incoming stream.
NX3
Post Wed Jan 11, 2012 10:00 pm
ic, I've notice that on the 2010 sony series tv I use it seems to do very little buffering. I'll try on other devices ... as the set is reporting as LPCM it is being transcoded though ?
Per the stream changing, I guess it would need a small plugin to take this stream which doesn't change to get the url u really need for serviio to start streaming.
http://www.bbc.co.uk/radio/listen/live/r1_aaclca.pls
Post Wed Jan 11, 2012 11:07 pm
btw, is this topic related to feeds or should it be moved to Audio Streams forum?
NX3
Post Thu Jan 12, 2012 9:38 am
Move to audio streams.
FYI I had a quick play via a Sony 2011 and while not perfect the drops are less and thats over wifi v the 2010 hardwired !
Urza
Post Thu Jan 12, 2012 10:22 am
NX3 wrote:Per the stream changing, I guess it would need a small plugin to take this stream which doesn't change to get the url u really need for serviio to start streaming.
This would definitely be a fantastic idea!
Post Thu Jan 12, 2012 10:27 am
in future I want to add this functionality to transparently deal with playlist URLs.
bumphere
Post Mon Nov 11, 2013 1:34 pm
zip wrote:in future I want to add this functionality to transparently deal with playlist URLs.
Hi Zip,
Did this move anywhere?
Bump
stanherbert
Post Wed Jan 29, 2014 10:16 pm
I'd also be very interested in being able to put a playlist url in as an audio feed. The inability to add the national BBC radio stations to the list is making my new audio setup hard to sell to my customer base (AKA 'wife'). :D
I'm yet to find any other radio stations which change their feed URL's dynamically in this way. Not sure why the BBC do it really!
Alternatively is there a work around to allow BBC Radio stations appear in the Audio>Online list along with all the others I've been able to add? I don't want them to appear elsewhere to maintain ease of use.
If it makes any difference I browse the library using BubbleUPNP on an Android phone and send media to various renderers around the home.
bumphere
Post Wed Feb 05, 2014 1:50 pm
I've not found a workaround as yet. TBH I've not had much time to tinker.
It would be a great feature to add for sure.
h20
Post Wed Aug 03, 2016 7:20 am
Thanks for that ! I already have this channel on my TV, but this feed is very well.
joeee
Post Thu Dec 08, 2016 7:43 am
There is a way to download BBC audio by just putting playlist URLs in the downloader(like AllMyTube) :D
mariad
Post Mon Mar 06, 2017 11:14 am
Is BBC iplayer accessible from the US?
MSGBen
Post Thu May 04, 2017 11:58 am
mariad wrote:Is BBC iplayer accessible from the US?
I don't think so, you might need a VPN for this.
MSGBen
Post Wed May 24, 2017 8:02 am
@mariad did you try it?
Return to Audio feeds
