Server keeps stopping
Jamf
Post Sat Dec 10, 2016 11:17 pm
have been using serviio for a couple of years no with no issues, but yesterday I updated to version 1.8, and ever since then I have been having major issues. The server keeps stopping, every few minutes so, constantly.
No matter how many times I reboot the pc, or reinstall Serviio, the server will always stop after a couple of minutes, over and over again.
I have tried going back ot older versions, inc 1.7, and even 1.5...the problem still remains, and I am totally unable to resolve it.
Does anyone have any ideas?
Post Sun Dec 11, 2016 10:50 am
Re: Server keeps stopping
Did your log (preferably a detailed log) tell you anything?
Grenelle75
Post Sun Dec 11, 2016 7:58 pm
I am also using serviio for several years with a quite large collection, and have issues since 1.8 update: server becomes unreachable. Probably stopped.
Post Sun Dec 11, 2016 9:48 pm
Although Serviio is stopping it may be up long enough to produce a detailed log. Turn detailed logging on, start Serviio and see if it the log file tells us anything.
Also try starting Serviio via the batch file, and try starting it a minute or two after your PC fires up.
Jamf
Post Mon Dec 12, 2016 7:58 am
Appears to be happening when I refresh the Library. Either on Auto, or using the "Force Refresh" option.
Not using either of these functions the server stays online, no problem at all.
Only started with the 1.8 update sadly
Will try and post a log later when I get some free time :)
Post Mon Dec 12, 2016 10:30 am
Just a thought - were you using the serviio.forceLibraryPoller startup switch previously? If so, remove it and then set "Use the poller mechanism for monitoring this folder" for all shared folders that need it in the Serviio console, Library, Shared folders area.
Jamf
Post Mon Dec 12, 2016 10:33 am
You have TOTALLY lost me Fella, lol
Post Mon Dec 12, 2016 8:40 pm
That's ok. If that's the case it means you weren't using it. Post your log file when you get a chance (you need to turn detailed logging on - click on the link to find out how).
Users browsing this forum: Google [Bot] and 53 guests
