[SOLVED] Re: Problem with 1.8 and Java
tstrike
Post Mon Dec 19, 2016 2:16 pm
Zip,
How are things?
Serviio is dying after startup for both Debian 8 and Centos 7 with OpenJava 1.8 version 111. Here is a thread that discussed the issue about Debian viewtopic.php?f=4&t=22425&p=111536#p111536 .
Here is what Centos said:
ec 18 08:52:39 zabbixserviio.me.org serviio.sh[20903]: Exception in thread "Thread-31" java.la...on
Dec 18 08:52:39 zabbixserviio.me.org serviio.sh[20903]: at org.serviio.MediaServer$ShutdownHook...4
Do we need to downgrade our Java (and possibly break the operating system)?
tstrike
Post Tue Dec 20, 2016 12:27 am
Re: There is a problem with Serviio 1.8 and Java
Found the problem: Centos Firewall. Forgot to register the Firewall XML needed.
tstrike
Post Wed Dec 21, 2016 6:50 am
Re: Problem with 1.8 and Java: Exception in thread "Thread-3
tstrike wrote:Found the problem: Centos Firewall. Forgot to register the Firewall XML needed.
I fixed this and the error is DEFINTELY java related on Centos 7.X . I tested 3 different versions of Centos.
I am getting the Exception in thread "Thread-31" java.lang.NullPointerException error message
tstrike
Post Wed Dec 21, 2016 11:59 am
Re: Problem with 1.8 and Java: Exception in thread Thread-31
hang one something weird with ffmpeg after turning on DEBUG tracing ....
tstrike
Post Wed Dec 21, 2016 12:31 pm
tstrike wrote:hang one something weird with ffmpeg after turning on DEBUG tracing ....
Centos 7.3 strangely changes the permissions. Remember to make sure that your ffmpeg binary is in the right location and that the permissions are properly set.
