Switch from Win2K to Win7 and from 0.5.0 to 0.5.1
DLNAhooray
Post Tue Mar 15, 2011 11:27 am
(I've placed this post into the Panasonic subforum but I don't really think the problem described can have anything to do with the brand of TV)
I've just left the cosy, familiar environment of Win2K after 11 years and, having never even played with either XP or Vista between times, I'm now trying to get to grips with my shiny new PC and its Windows 7 HP. This process of course includes getting Serviio up & running again.
My TV, my router and the Ethernet connection to the TV remain exactly as they were with the Win2K PC, with the change of PC, the change of Windows version and the new Serviio version being the only new factors in my setup.
I had installed Serviio 0.4.2 on my Win2K PC and later upgraded it to 0.5.0 without any problems whatsoever, so it was with no trepidation at all that I saw that 0.5.1 had been released just about the time that I changed over to my new Win7 PC. I installed 0.5.1 and went through the normal settings in the Serviio Console.
In "Status", Serviio reported my TV as an "Unrecognized device" with a "Generic DNLA profile" (I can't remember how it was reported on my Win2K machine, but I don't recall being obliged to make any manual adjustments). I tried manually changing the "Generic DNLA profile" to "Panasonic Viera" to reflect the actual TV, but this change didn't stick after a reboot, so I deleted the entry via the "Remove" button and replaced it via the "Add" button with the same IP address as found by Serviio and chose the name "Panasonic TV". I then changed the profile to "Panasonic Viera" and this time the settings were retained after a reboot.
So far so good, but after selecting the "Media Server" function on the TV, it takes over half a minute to display the Serviio logo (but at least it sees Serviio). I don't recall the TV taking so long to connect to Serviio on the Win2K PC, though.
Then I ran into the problem that prompted this post. When I select the Serviio server on the TV, the folders with the "Category names" enabled (not disabled) in "Presentation" are shown, but the TV displays no content for these folders, despite that in "Library" I had added a bunch of Video and Image folders via the "Add local..." button and saved everything. After a reboot these Library settings are retained and I have double-checked on the Win7 PC that the local folders are truly present and do indeed contain the expected files exactly as was the case on the old Win2K PC.
Any idea why I have problems using a Win7 PC having previously had no problems at all using a Win2K PC?
Post Tue Mar 15, 2011 12:39 pm
Re: Switch from Win2K to Win7 and from 0.5.0 to 0.5.1
DLNAhooray
Post Tue Mar 15, 2011 2:50 pm
2011-03-15 15:41:30,694 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-15 15:41:30,894 INFO [WebServer] WebServer shutting down
2011-03-15 15:41:30,894 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-15 15:41:30,894 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-15 15:41:30,894 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-15 15:41:32,019 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-15 15:41:32,300 INFO [DatabaseManager] Shutting down database
2011-03-15 15:41:32,394 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-15 15:42:19,408 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-15 15:42:19,423 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-15 15:42:19,423 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-15 15:42:19,423 INFO [MediaServer] http://www.serviio.org
2011-03-15 15:42:19,423 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-03-15 15:42:19,423 INFO [MediaServer] OS Windows 7 x86 6.1
2011-03-15 15:42:19,423 INFO [MediaServer] File encoding: windows-1252
2011-03-15 15:42:19,423 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-15 15:42:19,486 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-15 15:42:19,517 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-15 15:42:20,422 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-15 15:42:20,609 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-15 15:42:20,687 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-15 15:42:20,734 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-15 15:42:20,765 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-15 15:42:20,812 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-15 15:42:20,843 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-15 15:42:20,905 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-15 15:42:20,921 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-15 15:42:21,046 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-15 15:42:21,233 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-15 15:42:21,280 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-15 15:42:21,311 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-15 15:42:21,342 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-15 15:42:21,358 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-15 15:42:21,373 INFO [WebServer] WebServer starting on port 8895
2011-03-15 15:42:23,011 INFO [Device] Created UPnP Device with UUID: b906a219-7f3b-3ced-a37a-0b43b7a52961, bound address: 192.168.2.105
2011-03-15 15:42:23,027 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-15 15:42:23,027 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-15 15:42:23,027 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-15 15:42:23,027 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-15 15:42:23,027 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-15 15:42:23,027 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-15 15:42:23,027 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300200143027, LastAccessTime = 1300200143027, getTimeToLiveSeconds() = -1, createTime = 1300200143027 ]
2011-03-15 15:42:23,027 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-15 15:42:23,043 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-15 15:42:23,043 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-15 15:42:23,043 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-15 15:42:23,043 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-15 15:42:23,043 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-15 15:42:23,043 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-15 15:42:23,043 INFO [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-03-15 15:42:23,043 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-15 15:42:23,043 INFO [EventDispatcher] Starting EventDispatcher
2011-03-15 15:42:23,043 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-15 15:42:23,043 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-15 15:42:23,043 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-15 15:42:23,089 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.105, timeout = 0
2011-03-15 15:42:45,406 INFO [ServiioConsole] Starting Serviio Console
2011-03-15 15:42:45,466 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-15 15:42:46,400 INFO [Messages] Loaded console message bundle for locale: en
2011-03-15 15:42:47,726 INFO [Messages] Loaded console message bundle for locale: en
2011-03-15 15:42:47,835 INFO [UpdateChecker] Checking if a new version is available
2011-03-15 15:42:51,766 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-15 15:42:51,766 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-15 15:42:54,138 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-15 15:42:54,356 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
Post Tue Mar 15, 2011 3:32 pm
There is no list of added files. Make sure the folders are shared correctly and the user running Serviio service has got read access to the folders.
DLNAhooray
Post Wed Mar 16, 2011 7:44 am
Just FYI, to be able to send you a clean log I uninstalled Serviio, rebooted, reinstalled Serviio, adjusted settings and library and rebooted.
Not wanting to display all my personal image and video filenames on a public forum, I changed all these in the log to xxxxx.jpg or xxxxx.avi (offline naturally - didn't change the actual log).
My situation remains the same as described in my original post: Serviio and its folders not disabled under "Presentation" are displayed on the TV, but no library folders or files are displayed in those Serviio folders.
Here's the "cleaned up" log (I hope it meets your needs!):
2011-03-16 07:00:16,131 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-16 07:00:16,131 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-16 07:00:16,131 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-16 07:00:16,131 INFO [MediaServer] http://www.serviio.org
2011-03-16 07:00:16,131 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-03-16 07:00:16,131 INFO [MediaServer] OS Windows 7 x86 6.1
2011-03-16 07:00:16,131 INFO [MediaServer] File encoding: windows-1252
2011-03-16 07:00:16,225 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-16 07:00:16,287 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-16 07:00:20,655 INFO [DBSchemaUpdateExecutor] Updating DB schema
2011-03-16 07:00:25,538 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-16 07:00:25,710 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-16 07:00:25,788 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-16 07:00:25,819 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-16 07:00:25,850 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-16 07:00:25,897 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-16 07:00:25,928 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-16 07:00:25,991 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-16 07:00:26,006 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-16 07:00:26,115 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-16 07:00:26,318 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-16 07:00:26,365 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-16 07:00:26,396 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-16 07:00:26,630 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-16 07:00:26,630 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-16 07:00:26,677 INFO [WebServer] WebServer starting on port 8895
2011-03-16 07:00:28,315 INFO [Device] Created UPnP Device with UUID: b906a219-7f3b-3ced-a37a-0b43b7a52961, bound address: 192.168.2.105
2011-03-16 07:00:28,346 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-16 07:00:28,362 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300255228362, LastAccessTime = 1300255228362, getTimeToLiveSeconds() = -1, createTime = 1300255228362 ]
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-16 07:00:28,362 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-16 07:00:28,362 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-16 07:00:28,362 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-16 07:00:28,362 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-16 07:00:28,362 INFO [CompositeCacheConfigurator] Finished configuration in 0 ms.
2011-03-16 07:00:28,377 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-16 07:00:28,377 INFO [EventDispatcher] Starting EventDispatcher
2011-03-16 07:00:28,377 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-16 07:00:28,377 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-16 07:00:28,377 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-16 07:00:28,441 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.105, timeout = 0
2011-03-16 07:00:56,708 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-16 07:00:56,708 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-16 07:01:45,138 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-16 07:01:45,338 INFO [WebServer] WebServer shutting down
2011-03-16 07:01:45,338 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-16 07:01:45,338 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-16 07:01:45,338 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-16 07:01:46,759 INFO [DatabaseManager] Shutting down database
2011-03-16 07:01:47,727 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-16 07:02:30,310 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-16 07:02:30,320 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-16 07:02:30,320 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-16 07:02:30,320 INFO [MediaServer] http://www.serviio.org
2011-03-16 07:02:30,320 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-03-16 07:02:30,320 INFO [MediaServer] OS Windows 7 x86 6.1
2011-03-16 07:02:30,320 INFO [MediaServer] File encoding: windows-1252
2011-03-16 07:02:30,320 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-16 07:02:31,060 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-16 07:02:31,090 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-16 07:02:31,970 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-16 07:02:32,150 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-16 07:02:32,230 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-16 07:02:32,270 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-16 07:02:32,300 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-16 07:02:32,360 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-16 07:02:32,380 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-16 07:02:32,460 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-16 07:02:32,480 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-16 07:02:32,600 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-16 07:02:32,790 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-16 07:02:32,840 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-16 07:02:32,870 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-16 07:02:32,910 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-16 07:02:32,920 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-16 07:02:32,930 INFO [WebServer] WebServer starting on port 8895
2011-03-16 07:02:34,542 INFO [Device] Created UPnP Device with UUID: b906a219-7f3b-3ced-a37a-0b43b7a52961, bound address: 192.168.2.105
2011-03-16 07:02:34,557 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-16 07:02:34,573 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300255354573, LastAccessTime = 1300255354573, getTimeToLiveSeconds() = -1, createTime = 1300255354573 ]
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-16 07:02:34,573 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-16 07:02:34,573 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-16 07:02:34,573 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-16 07:02:34,573 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-16 07:02:34,573 INFO [CompositeCacheConfigurator] Finished configuration in 0 ms.
2011-03-16 07:02:34,573 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-16 07:02:34,573 INFO [EventDispatcher] Starting EventDispatcher
2011-03-16 07:02:34,573 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-16 07:02:34,589 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-16 07:02:34,589 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-16 07:02:34,653 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.105, timeout = 0
2011-03-16 07:02:48,261 INFO [ServiioConsole] Starting Serviio Console
2011-03-16 07:02:48,321 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-16 07:02:49,435 INFO [Messages] Loaded console message bundle for locale: en
2011-03-16 07:02:50,793 INFO [Messages] Loaded console message bundle for locale: en
2011-03-16 07:02:50,902 INFO [UpdateChecker] Checking if a new version is available
2011-03-16 07:02:56,658 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-16 07:02:56,877 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-16 07:03:03,132 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-16 07:03:03,132 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-16 07:04:19,747 INFO [RendererManager] Stored a new renderer: uuid='74451456-0d24-4861-a003-2820555566f1', name = 'Unrecognized device', ipAddress='192.168.2.106', profile = '1'
2011-03-16 07:05:18,780 INFO [RendererManager] Stored a new renderer: uuid='9de2f13c-b79f-4ae6-a972-c74a4f31da54', name = 'Panasonic TV', ipAddress='192.168.2.106', profile = '12'
2011-03-16 07:05:18,784 INFO [WebServer] WebServer shutting down
2011-03-16 07:05:18,784 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-16 07:05:18,784 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-16 07:05:18,784 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-16 07:05:19,644 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-16 07:05:20,252 INFO [WebServer] WebServer starting on port 8895
2011-03-16 07:05:20,252 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-16 07:05:20,252 INFO [EventDispatcher] Starting EventDispatcher
2011-03-16 07:05:20,252 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-16 07:05:20,252 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-16 07:05:20,311 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.105, timeout = 0
2011-03-16 07:06:51,338 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-16 07:06:51,620 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-16 07:06:51,620 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-16 07:06:52,779 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:53,078 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:53,208 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:53,444 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:53,682 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:53,903 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:54,107 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:54,294 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:54,481 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:54,669 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:54,856 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
2011-03-16 07:06:55,043 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.jpg' (title: xxxxx) to Library
(Lines with similar content cut because of forum error message:
"Your message contains 137538 characters. The maximum number of allowed characters is 60000"
2011-03-16 07:15:03,415 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:15:24,560 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:15:45,839 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:15:53,525 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:16:03,303 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:16:11,233 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:16:31,049 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:16:48,986 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:17:20,256 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:17:49,472 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:18:13,343 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:18:40,555 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-16 07:18:40,783 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-16 07:18:40,783 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-16 07:19:23,550 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:19:57,241 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:20:16,688 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:24,566 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:20:27,296 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:20:27,608 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:30,385 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:31,134 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:20:34,332 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:36,375 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:38,466 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:20:43,832 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:51,227 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:56,780 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:20:57,513 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:20:59,994 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:21:04,284 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:21:06,530 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:21:11,257 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:21:13,223 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:21:16,819 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:21:25,732 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:21:34,281 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:21:34,714 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:21:54,093 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:21:59,488 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:22:11,351 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:22:16,376 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:22:16,381 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:22:22,323 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:22:22,832 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:22:44,269 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:22:45,641 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:22:56,889 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:23:05,001 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:23:08,464 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:23:11,085 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:23:13,534 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:23:17,887 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:23:33,799 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:23:38,806 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:23:48,058 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:23:55,722 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:24:05,765 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:24:11,319 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:24:25,951 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:24:31,470 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:24:47,454 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:24:52,627 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:25:09,676 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:25:09,840 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:25:13,902 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:25:28,902 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:25:34,145 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:25:40,678 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:25:46,339 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:25:46,548 INFO [LibraryAdditionsCheckerThread] Added file 'xxxxx.avi' (title: xxxxx) to Library
2011-03-16 07:26:04,945 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:26:25,252 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:26:45,182 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:26:48,630 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:26:57,488 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:27:04,007 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:27:21,589 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:27:39,405 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:27:59,569 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:28:17,874 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:28:34,304 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:30:28,966 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-16 07:30:29,270 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-16 07:30:29,270 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-16 07:30:38,453 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-16 07:30:38,637 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-16 07:30:38,637 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-16 07:32:16,194 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:18,785 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:21,109 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:23,729 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:24,795 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:32,185 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:38,290 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:43,487 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:44,729 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:46,439 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:32:52,426 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:33:11,614 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:33:31,294 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:33:38,622 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:33:42,266 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:33:46,612 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:34:06,067 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:34:24,995 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:34:26,844 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:34:29,079 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:34:31,186 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:34:49,729 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:35:08,371 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:35:17,593 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:35:36,177 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:35:55,038 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:36:13,858 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:36:17,359 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:36:35,839 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:36:41,399 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:36:45,311 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:37:02,931 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:37:22,243 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:37:41,026 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:37:44,200 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:37:52,453 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:37:58,433 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:38:15,220 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:38:32,612 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:38:52,356 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:39:10,325 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:39:26,246 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:39:44,497 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:40:03,602 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:40:22,939 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:40:24,007 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:40:26,168 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:40:32,597 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:40:50,950 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:40:52,644 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:41:01,730 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:41:03,899 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-16 07:41:04,799 INFO [WebServer] WebServer shutting down
2011-03-16 07:41:04,799 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-16 07:41:04,799 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-16 07:41:04,799 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-16 07:41:06,205 INFO [DatabaseManager] Shutting down database
2011-03-16 07:41:07,765 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-16 07:41:45,762 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-16 07:41:45,772 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-16 07:41:45,772 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-16 07:41:45,772 INFO [MediaServer] http://www.serviio.org
2011-03-16 07:41:45,772 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-03-16 07:41:45,772 INFO [MediaServer] OS Windows 7 x86 6.1
2011-03-16 07:41:45,772 INFO [MediaServer] File encoding: windows-1252
2011-03-16 07:41:45,772 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-16 07:41:45,842 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-16 07:41:45,872 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-16 07:41:47,262 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-16 07:41:47,462 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-16 07:41:47,572 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-16 07:41:47,622 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-16 07:41:47,662 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-16 07:41:47,712 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-16 07:41:47,742 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-16 07:41:47,812 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-16 07:41:47,832 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-16 07:41:47,952 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-16 07:41:48,142 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-16 07:41:48,202 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-16 07:41:48,232 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-16 07:41:48,272 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-16 07:41:48,282 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-16 07:41:48,302 INFO [WebServer] WebServer starting on port 8895
2011-03-16 07:41:49,917 INFO [Device] Created UPnP Device with UUID: b906a219-7f3b-3ced-a37a-0b43b7a52961, bound address: 192.168.2.105
2011-03-16 07:41:49,932 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-16 07:41:49,948 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300257709948, LastAccessTime = 1300257709948, getTimeToLiveSeconds() = -1, createTime = 1300257709948 ]
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-16 07:41:49,948 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-16 07:41:49,948 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-16 07:41:49,948 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-16 07:41:49,948 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-16 07:41:49,948 INFO [CompositeCacheConfigurator] Finished configuration in 0 ms.
2011-03-16 07:41:49,948 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-16 07:41:49,948 INFO [EventDispatcher] Starting EventDispatcher
2011-03-16 07:41:49,948 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-16 07:41:49,963 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-16 07:41:49,963 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-16 07:41:50,020 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.2.105, timeout = 0
2011-03-16 07:42:17,211 INFO [ServiioConsole] Starting Serviio Console
2011-03-16 07:42:17,257 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-16 07:42:18,193 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-16 07:42:18,193 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-16 07:42:18,724 INFO [Messages] Loaded console message bundle for locale: en
2011-03-16 07:42:19,613 INFO [Messages] Loaded console message bundle for locale: en
2011-03-16 07:42:19,722 INFO [UpdateChecker] Checking if a new version is available
2011-03-16 07:42:25,082 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-16 07:42:25,313 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-16 07:43:52,020 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:43:59,393 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:44:04,326 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:44:21,071 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:44:37,254 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:44:42,675 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:45:02,078 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:45:10,065 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:45:27,442 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:45:46,032 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:45:53,334 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:46:12,533 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:46:30,823 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:46:48,508 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:46:55,353 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:47:11,771 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxx AVI\xxxxx.avi) in Library
2011-03-16 07:47:23,998 INFO [LibraryUpdatesCheckerThread] Updated 'xxxxx' (C:\Users\Jim\Documents\Videos\Avi\xxxxx AVI\xxxxx.avi) in Library
Post Wed Mar 16, 2011 9:36 am
I'll need you to post DETAILED log (see link in my signature). I can see the files are added, so it's ok, but I'll need to see the detailed log of when you browse the folders. You could also confirm the files are there by browsing Serviio via AV Media Controller from Intel tools (link in signature)
DLNAhooray
Post Wed Mar 16, 2011 5:29 pm
Here at last (I hope!) is the requested detailed log (third time lucky as they say). See attachment.
Re confirming the files are there by browsing Serviio via AV Media Controller from Intel tools, I installed the tools, found the AV Media Controller but I wasn't able to make it do anything useful. My brain is too small, I suppose. If this browsing of Serviio is important to your considerations, please tell me how to get AV Media Controller to do what you want it to do.
Thanks in advance.
Detailed log DNLAHooray 16-03-2011.zip
(44.75 KiB) Downloaded 735 times
Post Wed Mar 16, 2011 6:03 pm
In the tools, you should see Serviio on the left side, you should be able to expand that and see your folders (Audio,Video,Images) and all the other categories.
Log is correct now, I can see your browse request but then it doesn't return anything, which I'm not sure why. Did you change your profiles.xml? Does this happen only for videos of also for images/audio?
DLNAhooray
Post Wed Mar 16, 2011 7:19 pm
In the tools, I don't see Serviio at all. All I'm doing is double-clicking AV Media Controller.exe and I get a dialog(?) called AV Media Controller (which is encouraging!) but just with two folders(?) called "Media Renderers" and "Content Directories", each containing the columns "Names = Values" listing "Manufacturer = Open Source", "Product Name = Media Controller", "Version = 1.0.4083.20052". None of the menus File, View or Help suggest anything useful to me (and Help calls no Help file).
I haven't changed profiles.xml - well, not manually and not via Serviio intentionally. See copy below.
My TV sees Serviio and displays the Serviio folders "Image", "Audio" and "Video" (all the other possibilities in "Presentation" are disabled), but all are empty - none of the subfolders that I still see in my PC folder and that I used to see on the TV with Serviio under Win2K
Profiles.xml --------------------------------------------------------
<Profiles version="1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://www.serviio.org/xsd/profiles/1.4/Profiles.xsd">
========================= DO NOT EDIT - start ====================================
<Profile id="1" name="Generic DLNA profile">
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ProtocolInfo>DLNA</ProtocolInfo>
<DeviceDescription>
<FriendlyName>Serviio ({computerName})</FriendlyName>
<ModelName>Serviio Media Server</ModelName>
</DeviceDescription>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/L16;rate=44100;channels=1" name="LPCM">LPCM16_44_MONO</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/L16;rate=44100;channels=2" name="LPCM">LPCM16_44_STEREO</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/L16;rate=48000;channels=1" name="LPCM">LPCM16_48_MONO</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/L16;rate=48000;channels=2" name="LPCM">LPCM16_48_STEREO</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/x-ms-wma">WMA_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/x-ms-wma">WMA_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/mp4">AAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/mp4">AAC_ISO_320</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/flac">FLAC</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/ogg">OGG</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_SM</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_MED</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_LRG</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_TN</MediaFormatProfile>
<MediaFormatProfile mime-type="image/png">PNG_LRG</MediaFormatProfile>
<MediaFormatProfile mime-type="image/png">PNG_TN</MediaFormatProfile>
<MediaFormatProfile mime-type="image/gif">GIF_LRG</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG1</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_PS_PAL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_PS_NTSC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_EU_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_NA_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_KO_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-msvideo">AVI</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-matroska">MATROSKA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-flv">FLV</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-dvr">DVR_MS</MediaFormatProfile>
<MediaFormatProfile mime-type="video/wtv">WTV</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_DTS_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_PRO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_PRO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
</MediaFormatProfiles>
<AutomaticImageRotation>false</AutomaticImageRotation>
<LimitImageResolution>true</LimitImageResolution>
========================= DO NOT EDIT - end ====================================
<Profile id="2" name="Samsung TV (B-series)" extendsProfileId="1">
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
<Detection>
<UPnPSearch>
<FriendlyName>^TV$</FriendlyName>
<ModelName>Samsung DTV DMR</ModelName>
<ModelNumber>1\.0</ModelNumber>
</UPnPSearch>
</Detection>
<MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
<!-- transcode MKV with DST audio to AC3, remux into mpeg2ts -->
<!-- transcode H264 MP4 files with LPCM audio -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<Matches container="mp4" aCodec="lpcm" />
<!-- transcode unsupported codec/container combinations into mpeg2ts -->
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
<Matches container="asf" vCodec="wmv2" />
<Matches container="flv" />
<!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
<Matches container="asf" vCodec="mpeg2video" />
<Matches container="wtv" />
<!-- transcode audio only for wmv with wmapro -->
<Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
<Matches container="asf" aCodec="wmapro" />
<Matches container="asf" />
<Matches container="mp4" />
<Matches container="flac" />
<Matches container="ogg" />
</Audio>
<SubtitlesMimeType>smi/caption</SubtitlesMimeType>
<Profile id="3" name="XBox 360" extendsProfileId="1">
<Detection>
<UPnPSearch>
<ModelName>Xbox 360</ModelName>
</UPnPSearch>
</Detection>
<DeviceDescription>
<FriendlyName>Serviio ({computerName}):1</FriendlyName>
<ModelName>Windows Media Connect</ModelName>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.XBox360ContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<MediaFormatProfile mime-type="video/avi">AVI</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
http://blogs.msdn.com/xboxteam/archive/ ... k-faq.aspx
<Video targetContainer="asf" targetVCodec="wmv2" targetACodec="wmav2" maxVBitrate="15360" forceStereo="true">
<Matches container="mpeg" />
<Matches container="mpegts" />
<Matches container="mpegvideo" />
<Matches container="avi" vCodec="msmpeg4" />
Post Wed Mar 16, 2011 8:38 pm
Re: Switch from Win2K to Win7 and from 0.5.0 to 0.5.1
DLNAhooray wrote:My TV sees Serviio and displays the Serviio folders "Image", "Audio" and "Video" (all the other possibilities in "Presentation" are disabled)
Are you saying that you only enabled Audio/Video/Images but disabled all the categories inside, like Series, Folder, Movies etc? If yes than it won't work, you have to select at least one of the subcategories as those actually include media items. Audio/Video?image only include other (sub)categories.
DLNAhooray
Post Thu Mar 17, 2011 7:15 am
Yes, I had set all subfolders to "Disable". I have now set the subfolder "Folder" in each category "Image", "Audio" and "Video" to "Display content only". I can now see everything on the TV, so thanks for the tip and sorry for having wasted your time. On the other hand maybe there should be a warning for idiots like me not to set all subfolders to "Disable? If the possibility is there, someone is going to use it.
I am, however, pretty sure that I had disabled all those subfolders in 0.5.0 under Win2K. Could my memory be playing tricks? Or in other words did you make any changes in this area for version 0.5.1?
Also, as I already stated in an earlier post in this thread, my recollection is that my TV found Serviio much more quickly with 0.5.0+Win2K than is the case now with 0.5.1+Win7. Is needing 30-45 seconds on a wired connection normal would you say? Once Serviio is found, all my media files are available instantly, with no noticeable delays when switching the TV from one file or folder to another.
(Currently I still have the old Win2K PC in storage until I'm absolutely satisfied with the new Win7 machine. When that day comes, I plan to retrieve the Win2K PC, reconnect it to wipe all its HDDs and then dispose of it, but I don't know when this will be. I will have a look at the Serviio console and check whether my memory is right or wrong regarding the above)
Post Thu Mar 17, 2011 9:41 am
No change there.
It might be down to the network or try changing update Serviio service startup options to "Automatic (Delayed)" viewtopic.php?f=5&t=1931#p10477
DLNAhooray
Post Thu Mar 17, 2011 11:41 am
Changing Serviio to "Automatic (Delayed)" causes it not to start at all.Instead, the message with the heading "Serviio Error" and the text "Cannot connect to Serviio server, it does not seem to be running" is displayed. No idea if that message comes from Serviio or from Win7, but I presume the latter. Manually starting the Serviio service in Services seems to work OK in that "Started" is displayed, but there's no sign of a Serviio icon in the system tray or indeed anywhere, so I wasn't able to call the Console. Inserting a Bound IP address doesn't help in avoiding this behaviour.
After reverting Serviio to "Automatic" in Win7 Services and rebooting, having a Bound IP address inserted in Serviio doesn't reduce the time it takes the TV to see Serviio either. The network is the same one as previously with my Win2K PC - no changes at all.
How long a delay would you (or any forum member running a Panasonic Viera with Serviio) say is normal before Serviio is seen on the TV?
Edit: For info, the connection between my Win7 PC and my Panasonic Viera TV is operating at 130 Mbit/s
Post Thu Mar 17, 2011 6:11 pm
DLNAhooray wrote:Changing Serviio to "Automatic (Delayed)" causes it not to start at all.Instead, the message with the heading "Serviio Error" and the text "Cannot connect to Serviio server, it does not seem to be running" is displayed. No idea if that message comes from Serviio or from Win7, but I presume the latter. Manually starting the Serviio service in Services seems to work OK in that "Started" is displayed, but there's no sign of a Serviio icon in the system tray or indeed anywhere, so I wasn't able to call the Console. Inserting a Bound IP address doesn't help in avoiding this behaviour.
That error comes from the serviio console if it trys to start before the serviio service it will kick out that error. If you manualy start the serviio service you will then have to manualy start the console to or yes it will not be availible on the taskbar
The network is the same one as previously with my Win2K PC - no changes at all. How long a delay would you (or any forum member running a Panasonic Viera with Serviio) say is normal before Serviio is seen on the TV?
windows 7 is annoying the last thing it loads is the network drivers so untill the network starts serviio wont be able to be access by your tv upto a minute is about right.
i very much doubt that your tv will run at 130Mbit/s as the interface on your TV will be 10/100, so max it will run at is 100Mbit/s
DLNAhooray
Post Fri Mar 18, 2011 7:09 am
Hi Cerberus
Thanks for your comments, especially nice to see you're in Reading - lived in Tilehurst 1965-1993 . . .
Cerberus wrote:windows 7 is annoying the last thing it loads is the network drivers so untill the network starts serviio wont be able to be access by your tv upto a minute is about right.
In my case, the Win7 PC and Serviio are already up & running, then I wander through to the TV, switch it on, select Media server and the Serviio logo takes 30-45 sec. to appear. Would you still say this is normal?
Cerberus wrote:i very much doubt that your tv will run at 130Mbit/s as the interface on your TV will be 10/100, so max it will run at is 100Mbit/s
You are of course right. I was responding to zip having queried the network quality: I should have said the connection from PC to TV is standard hard-wired Ethernet (ie. not wireless) but with part of the run covered via a pair of Devolo power line units running at 130 Mbit/s (instead of their theoretical 200 Mbit/s)
Post Fri Mar 18, 2011 2:59 pm
The delay is probably caused by the initial set of multicast packets sent by Serviio is lost, the second set (a minute or so later) already finds it's way to the TV.
Does this happen when you turn on the TV while Serviio is running or start Serviio after the TV has been running?
DLNAhooray
Post Fri Mar 18, 2011 4:04 pm
If I start Serviio with the TV off, then turn on the TV and select Media Server on it, I have to wait an age (<1 min) before the Serviio icon is displayed.
If I stop Serviio with the TV off, then turn on the TV and select Media Server on it, get Mrs DNLAhooray to watch the screen, then click the "Start server" button on the Serviio Console, then within a couple of seconds I hear Mrs DNLAhooray's shout that the Serviio icon has appeared on the TV (and this shout occurs a few seconds before "Stopped" changes to "Running").
So it seems you must be right about the lost packets. Any workaround?
Post Fri Mar 18, 2011 4:30 pm
Not, unless you want to click Stop/Start server. The TV should be searching for servers on its startup and Serviio responds. The packets can get lost either way. It's just a bit weird that it happens every time for you.
You could enable detailed logging and watch changes made to the log when you start the TV. You should see some M-SEARCH requests incoming and Serviio responding to those.
DLNAhooray
Post Fri Mar 18, 2011 6:19 pm
After enabling detailed logging, I went along to the TV and - lo and behold - on my first attempt I timed the appearance of the Serviio icon at, would you believe, 13 seconds. A first for this Win7 setup. So then of course I performed a lengthy series of timed attempts and found a goodly spread from 10 or so up to 45 or so seconds, which I suppose is the norm. Please don't ask me why I saw only l-o-o-o-n-g timings before, but I did. I propose to see how it goes and will report back any recurrence of the persistent 30-45 sec delays.
Post Fri Mar 18, 2011 8:44 pm
DLNAhooray wrote:Hi Cerberus
:D im in the posh bit im in Woodley :P
yep in some cases.
that would be were your bottleneck is them power line things are pure crap.
Return to Panasonic
