Serviigo issue with 1.8 and all music
gbscobel
Post Sun Dec 25, 2016 8:35 pm
On the serviigo app, the all music section only shows up on Artists and not on album artists. The big issue with this is when you do a search, it only shows album artists and not artists so you can't get a list of all tracks from search. Is there any fix for this because I think it used to work before and it definitely works on the website. Any help would be appreciated
Jyrki
Post Wed Oct 06, 2021 8:23 am
Re: Serviigo issue with 1.8 and all music
marioinstitute wrote:
I checked the logfile on my Synology NAS and didn't find any errors there, I also found some case studies and cheap essays for sale in engineering section.
I had the same issue after updating to 1.8 on my Synology DS916+. I didn't want to move back to my pc, because I decided to try Synology NAS to save power. My solution was to remove all MP3 folders from the library and add them again.
