Metadata : Title containing an "-" causes matching problems
Clowrid
Post Thu Dec 29, 2016 2:58 pm
I just bought a NAS (Qnap HS210) and installed Serviio (1.7.1) on it.
It tooks about a day indexing my movies (I feel like it's still working, ffmpeg proccess using 100% of my cpu, is there a progessbar somewhere?)
It did a pretty good job finding matches on tvdb.
However i have a problem with movies wich contains a "-"
For exemple, look at this :
Instead of filing movies in "Psycho-Pass", it create a second folder with just "Psycho" (and put some of then in)
More informations : My folder name is "Psycho-Pass (2012)", and my file name is "Psycho-Pass.S01E01.Criminal Coefficient.mp4" (for exemple)
How can i fix it?
Post Fri Dec 30, 2016 2:56 am
Re: Metadata : Title containing an "-" causes matching probl
You might try adding the IMDB ID number (tt2379308 for this particular series) in the folder name. It might be necessary to add it to the file names as well, but try the folder name first.
See this page for more information: http://wiki.serviio.org/doku.php?id=imb ... ata_naming
And no, there's no progress bar :)
Clowrid
Post Fri Dec 30, 2016 10:18 am
Thank you very much atc98092, it works ! :-)
That will be very useful to me.
I found a way to know if it's still working or not : I used "tail -f serviio.log". Not a progress bar ofc, but enough for my needs.
By the way, reading this log, i found that Serviio is scanning .@__thumb folders (if i understand well, there are thumbnail, but i don't know if it's my Qnap or Serviio wich generate it).
I hope this will not cause problems with deleted or renamed files, creating duplicates.
Users browsing this forum: Google [Bot] and 45 guests
