Derby Driver has disappeared
jimgeldermann
Post Fri Dec 30, 2016 4:55 pm
Error msg -> Cannot connect to Serviio server, it does not seem to be running
It appears that the Derby Driver has disappeared - probably my fault. I've tried installing 1.8 and get the same error. I've downloaded the Derby zip and would like to know which jar and where to install, or perhaps what you think I should do?
(117.08 KiB) Downloaded 339 times
Post Fri Dec 30, 2016 9:32 pm
Re: Derby Driver has disappeared
the derby.jar should be in the lib folder on the installed Serviio
Users browsing this forum: Google [Bot] and 45 guests
